Question about Lexmark X6650 4-In-One Wireless InkJet Printer
X6650 paper jammed how do i remove it - Lexmark X6650 4-In-One Wireless InkJet Printer
  • 163 Answers
If you lift the access door (the door that you lift to change the ink cartridges), you should be able to free the paper from there but be careful of damaging other components of the printer.
Hope this helps!
Posted on Feb 05, 2010
Lexmark x6650 won't take paper correctly
Leading cause of paper jams or misfeeds is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
Jan 23, 2012 | Lexmark X6650 4-In-One Wireless InkJet...
Printer paper pulled half through then stops
Leading cause of paper jams or misfeeds is debris or foreign objects that fell accidentally in the paper feed area. Try to remove the sheets of paper from the feeder. Grab a flashlight and look into the feeder for any obstructions.
Also, try to open the printer cover and make sure the paper path is free from foreign objects or debris.
Re-insert your cartridges and make sure they are properly seated in the carrier.
Dec 23, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Paper Jam
Hi Matt,
Here's how to:-
  • First turn the printer off and on.This is known to automatically clear paper jams by pushing the stuck paper out.
  • Remove all the papers from the feed trays.
  • Remove the cover from the housing of the printer to gain access into the inside of the printer.
  • Check for the jammed paper inside and gently pull it out.
  • Press on the flashing paper jam button to make the clearing easy.
  • If this doesn't clear the jam,unplug the printer from power and try removing the stuck papers firmly.
  • Plug the printer back and try printing now.
Check out these video tutorials for more on the same.
Hope this helps.Thanks!
Dec 16, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Not able to get envelope out, paper jam
Try to open the printer cover. You may be able to get a better hold of the paper jam in the cartridge area.
Firmly hold the stuck paper and carefully remove it. Avoid tearing or leave torn pieces of paper in the printer as these can cause future paper jams.
I hope this information has been helpful.
Oct 15, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Paper jams in the feeder on the left side , tried to opentop cover does not allow me to open back. how do I GET THE ROLLER from curling the paper?
One reason for paper jams is due to some obstructions in the paper path. Remove the sheets of paper from the feeder. Grab a flashlight and look into the paper feeder. Clear the feeder from any foreign objects or debris that could cause "curling" of the paper. If feeder is clear, open the printer cover and ensure the paper path is clear in the cartridge area.
Unplug and replug the printer into the power source to reset it. When the printer turns on, try to print again. If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Jul 28, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
There is a paper jammed in the printer how do I get in to pull it out?
If you're having difficulty pulling out the jammed paper from the feeder, open the printer cover and access the cartridge area. You should be able to see the paper jam. Carefully remove the paper and make sure not to leave any torn pieces to prevent this from happening again.
Apr 25, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
My Lexmark shows always paper jam even without paper in the printer.
Just needs reset hold down power button for three seconds shold work or unplug and plug back in.
Oct 31, 2010 | Lexmark X6650 4-In-One Wireless InkJet...
Lexmar X6650 It is saying paper jam but no paper in printer
Reset once you printer again install drivers on computer again ... keep it disconnect from computer and from power coard for at leat 1 hr then first put on power coard and do as driver installer say to do so..thank you
Jun 24, 2009 | Lexmark X6650 4-In-One Wireless InkJet...
Paper lost in printer
if printer not show any error message (and in ready mode) then place a art sheet in tray and print a page attend paper forcefully by hand to remove lost paper with this art sheet if printer show any error message like paper jam try to remove with open the front door
Jun 14, 2009 | Lexmark X6650 4-In-One Wireless InkJet...
Lexmark X6650 4-In-One Wireless InkJet Printer Logo
292 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
