Question about Panasonic DMR-EZ47V DVD Recorder/VCR
Using FRec to record on DVD-which mode does it record in?
I just recorded 2 programs from cable onto a DVD. Each program was approximately 45 mins long. Instead of recording in SP (as I should have), I thought I would try the F(flexible) Record instead, for the first time.
After I got done recording, I named and finalized the disc. When I turned it over, it looks like less than half of the DVD was written to. I tried to find out which mode it was recorded in by playing it back but I couldn't figure out where to find that.
Thanks!
  • 1 more comment
  • ChicagoPunky
    ChicagoPunky Feb 25, 2008
    Sorry - just to clarify - I pressed "pause" between the 1st and 2nd programs. To avoid confusion, I just should have written that I recorded a 90 minute program.
    I am also wondering if F Rec works better with scheduled (using the timer) recording rather than recording it live.
  • ChicagoPunky
    ChicagoPunky Feb 28, 2008
    Just to let you know, I finally figured it out by experimenting a lot. The FRec only seems to work with the timer or Scheduled recording. I don't know why I didn't think of that before because it does make sense as you are telling the DVD Recorder how much room you will need on the DVD.
    With non-programmed recording, it reverted to EP and not just the 6 hour EP I had set in Set-Up but an 8 hour EP.
  • ChicagoPunky
    ChicagoPunky Mar 23, 2008
    Thank you so much for all the explanations, xmarine2847!
    I think that I was on another input on the TV and that is why I did not see the message.
  • 47 Answers
You seem to have fixed your own problem. Yes, the Flexible recording function only works on scheduled recordings. However, you should be able to do direct recording with FR - but when you press the F.Rec button for a direct recording a notification should come up on-screen asking you the amount of time to record. This is on page 16 in the manual. If you started the recording without being on the correct input for the DVD recorder on the TV, you would not have seen this message and the unit would default to EP 6 or 8hr. (based on settings).
Obviously the FR swaps between bit-rates to fill the disc completely, so you would see the recording tracks had almost completely filled the disc when done.
Also, some older DVD players, even if the disc type is compatible and finalized, do not read VBR recorded DVDs - so that my be another issue.
Hope this helps.
Posted on Mar 05, 2008
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
[ENTER].
Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
5
Using [
K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
7
Hit [PLAY
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP
C] to stop the
recording.
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
I'm trying to copy old family videos from VCR to DVD. I'm using the correct disc type (DVD-R) and there's no copy protection. I've tried both Sony and HP discs. Each time, it seems to be working but...
First, try to refinalize the disc if it failed the first time by going into the edit menu. Sometimes finalization just fails the first time.
If you are recording on 2-hr mode, and the length of your recording is an 1hr 50 min or more, there will not be enough space left on the disc to finalize. Going forward, your best solution would be to record in 3- or 4-hour mode for every 2 hrs worth of recording (6-hour mode for 3-5 hours of recording, etc.). Just to quickly decipher recording modes: 2-hr mode (sometimes called SP Mode, depending on DVD player) will record about 2 hours worth of material on a standard blank DVD (but some extra space would be required for finalization); 4-hour mode would record 4 hours worth of material on a standard DVD; 6-hour mode would record 6 hours, etc.
As far as salvaging the recordings you have already made - load the burned, yet unfinalized DVD's into your computer. Copy the files onto the desktop or some easy-to-find location on your computer. Then use a program, free or otherwise (I personally reccomend Nero or Roxio), to re-burn the discs. The newer version of Nero automatically finalizes the disc, but some software requires you to select an option that allows you to "close disc" or "finalize" the disc. (In computer lingo, "closing" means the same thing as "finalizing").
-Tha Mp3 Doctor
Mar 04, 2009 | GoVideo Go Video VR3840 DVD Recorder/VCR
Recording from VHS to DVD
First, you will need to know if the program was recorded in XP mode, SP mode, LP mode, or EP mode. To find out how much room there is left, put the dvd in the tray and press the Disc Menu/List button on the JVC remote. This will display the title and how long it is - write that number down. It will also say either "XP,SP, LP, or EP" - write down that mode. In XP mode, a DVD will hold 1 hr and 20 mins worth of prgramming - MAXIMUM. SP mode = 2 hours. LP mode = 4 hours. EP = 6 hours. So, if your program is one hour, and you recorded in LP mode, you have 4 - 1 = 3 hours of space left for recording on that disc.
If you finalize a disc, you will no longer be able to add more programs to that disc, unless the disc is a + or - RW disc. Also note that finalization requires some disc space, so if you recorded a program that is exactly 1hr and 20 mins long, and you recorded it in XP mode, then the disc will probably not finalize correctly.
That being said, the finalization directions are on p. 23 of your manaul: Title --> Finalize --> => --> find finalize --> Enter --> OK --> Enter
Now it will play on other players.
Here is a link to the user manual:
http://resources.jvc.com/Resources/00/00/93/LPT1133-001A.pdf
-Tha Mp3 Doctor
Dec 31, 2008 | JVC DR-MV7 DVD Recorder/VCR
I am recording fron VHS to DVD. When I am finished and push the stop button, How can I tell how much space is on the DVD to record something else and how do I finish the dik so it can't be recordered over
JVC DVD Recorder – Finalizing and disc space
-Tha Mp3 Doctor
Copy recorded pgms off DVD HDD to DVD+RW
the manual specifies that if you select for recording the FR mode the machine automatically adjusts the recording mode for the program to fit on a 4.7G dvd. If you use a dvd DL if will auto detect that you have this type of dvd and the FR mode will automatically allow you to make full use of the available space. Depending on the space needed on the dvd the picture quality will be good to excellent (refer in the manual to Recording Modes..)
Aug 30, 2008 | Panasonic DMR-EH57 HDD Recorder Player
Cable box, digital service, channels not appearing
connect the RF lead from the wall to your cable box then out from that to your dvd then out from your dvd to your tv. now connect a scart lead from the cable box to AV 2 on the DVD then connect AV 1 on the DVD to your TV if you have a second scart on your tv connect that to the cable box. NOW on the DVD select AV2 now whatever is on the cable box will be recorded onto DVD/VCR. Put the DVD recorder into VCR mode and set it to auto tune all the Digital Video Broadcasts. You cannot physically tune the cable boxes own channels into the DVD via RF it has to be via a scart.
Apr 27, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
How to burn from TV onto DVD
Idealy would be to have a DVD-recorder, so you can record TV program (and signal from other sources, of course). Also, you can program it by timer to record TV program. You can by DVR with hard disc, or cheaper without HD and record it to DVD+/-RW (you can rewrite it up to 1000 times).
Sep 29, 2007 | NAD T512 CD Player
How long can I record using a DVD-RAM disc?
• Extra Fine mode (3-9Mbps record speed): Approx. 20 min. minimum per side. • Fine mode (6Mbps record speed): Approx. 30 min. per side (1 hour total). • Standard mode (3Mbps record speed): Approx. 1 hr. per side (2 hours total).
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
61 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
