Question about Watches
I have a watch that has a few years on it, but I would like to wear it again. I have tried to have it fixed at some cost but each time that I do the same problem comes up, The problem is this the sleeve that holds the stem for changing the time, does not hold the stem. I can pull it out for use in changing the time but it comes all way out.The watch has the following numbers on the back.Q519212 7-005668 Joseph P. Kestner E-mail joekestner@yahoo.com
  • 3,230 Answers
Well the number you give (Q519212 7-005668) is a serial number and not seems the model number....... can you please tell us the Brand and Model number......... so we can help you in details.........
Thanks
Posted on Feb 05, 2010
I bought this watch 1.5 years back.I have started using that.It worked properly.For the last few months I didn't wear it.Now the watch is not working. So the problem is in the battery ?
On average, I've found that analog wristwatches that use a silver oxide (or alkaline) battery last about a year after a fresh battery has been installed. Digital watches, because they have no moving parts, will typically last longer on a set of batteries if you're not using the alarm or backlight function. Watches that use lithium batteries generally last two years or more between battery changes.
Based on your model watch, I would guess that your battery has run down too far to power the movement. A fresh battery will probably fix your watch. Hint: in the future, if you aren't going to wear your watch for a while, pull the stem out into the "set" position. That will stop the movement and extend the life of your battery. When you want to wear the watch, simply set the time (and date, if you have a date window) and push the stem back in.
Jun 27, 2011 | Armitron Now Collection Crystal Accented...
Watch winding is not holding
Two words: Wind it! When any self-winding (automatic) watch runs down from not wearing it you have to manually wind it to get it going again. Once you've done that the movement of your wrist will cause the self-winding rotor mechanism to keep it running as long as you are reasonably active and wear it everyday. Just wind it about 40 turns and you'll be good to go. Oris is a great watch company and you should enjoy it for many years.
Apr 16, 2010 | ORIS Watch TT3 Day Date 63575887067MB
When I started wearing the watch it would stop at least once a day and I would have to pull out the reset time button, fix the time and push the button back in again to get it started. It happened 4 days...
If it's a quartz watch, replace the battery. If it's a mechanical watch, even a "self-winding" model, wind it manually - unless you're very active it needs a manual winding if you don't wear it all the time. If it's more than a few years old it may need cleaning by a watchmaker.
Apr 09, 2010 | Pulsar Bracelet PXQ502 Wrist Watch
IT IS RUNNING SLOW EVEN THOUGH IT'S BEEN WOUND.
If your watch is less than 2 years old then they may service it for free, and if it is that new I would take it back to point of purchase for assistance. Even though Rolex's are Chronometers they are not known for their ability to keep near perfect time. If you are losing only 6 seconds a day then you are still over 99% accurate and it does not really get much better than that (that means you may loose a couple mninutes a month. A watch winder that you set your watch in while not wearing can keep it spinning/ winding and therefore may increase accuracy.
If your watch is loosing a lot of time (half an hour a day) or if the watch is more than 5 years old, it likely needs some servicing. Oils can harden and thicken within your watch and this will affect the performance. Rolex recommends servicing your watch every 5 years or so to keep it in peak condition. A usual service entails a cleaning, oiling and regulating; this usually costs from $350 to $700 depending on where you go and if nothing else is wrong with your watch.
But again, if you are only loosing a few minutes a day, then your watch is still in good shape and I would not recommend paying the money to get it to work only a small bit better.
Oct 20, 2009 | Rolex Watches
Model JR3XXX/Cal. No. C650. Stop wearing it and
The same thing happened to me. The fix is in the instructions. If you don't have them download them. You will probably need to do a full reset to get it working again then reset the hands to the "0" position so both the analoge and digital times match.
Sep 25, 2009 | Citizen Watches
Seiko Self winding 200M Divers Watch Stopped Working
your watch needs a good service.disassembling cleaning oiling and reassembling!this must done every three to four years in automatic watches!try in a authorized seiko service center!
Jun 28, 2009 | Seiko Divers Automatic watch
Automatic Watch Stops
There can be hundereds of causes why your watch isn't working properly, so, I'll not name them.
One is clear- without help of skilled watchmaker your watch will NEVER work properly.
NOTE: It may sound very strange, but mechanical watches do NOT like to be left without job.
Next time you decide to leave mechanical watch aside for long time- do not forget to wind it up once in a 2-3 days even if you are not wearing it.
This will help to prolong watch movements life and keep timekeeping steady and accurate.
Regards
Arthur
Dec 15, 2008 | Invicta (2540) Wrist Watch
Rolex watch
Hello Kristy
You need to add this underneath the the person you are talking to by clicking COMMENT below their post. Fixya gets 7 million posts a year, so the chance of the person seeing it are non existent. Your original post is in the link.
I have a Chinese Rolex Submariner clone. It gained 5 minutes a day when I first got it. Your body's electrical energy and magnetism can affect timekeeping and you can have the watch demagnetised.
Rolex watch stops only when wear it
May 12, 2017 | Watches
Prague 49011G, automatic wind watch - stopped ticking
I also have a Prague automatic watch (not the same model) which I purchased in 10/06 and have had it repaired twice. If you purchased the watch new, a little white warranty paper should have accompanied it. If not, you might be out of luck. Anyhow, each Prague has a two year warranty. My warranty instructed me to send the original receipt, a check for $10 (for return shipping) and the watch to Croton Repair; 195 Anderson Avenue; Moonachie, NJ 07074. There of course is no phone number to call them. Make the check out to Croton Repair. The warranty also says they do not guarantee they will fix the watch, but they guarantee they'll send you the watch back if it cannot be repaired. It took about 5 weeks and my watch came back repaired. Unfortunately about 6 months later it broke again, same exact problem (no long self-winds, ticks or keeps time, my watch also has a diamond at each hour, two of which fell out)... I've seen a lot of the issues people are posting seem to be the automatic watches not working. Probably duds, the inner workings seem to be very sensitive.
Dec 24, 2007 | Watches
Restarting my Citizen Promaster Eco Divers 200 Watch
Since it's eco-drive you can just wear it for a few hours and it should self-wind. The problem is that when it sits still for more than a few days it winds down. It gets its power from the natural movement of your wrist as you walk around.
Once it starts ticking again you'll just have to set the time correctly.
Dec 18, 2007 | Citizen Eco-Drive BL006056H Wrist Watch
Watches Logo
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
