Question about RCA F27628 27" TV
RCA TV On my 27 inch RCA tv, the color is black and white when it is hooked up to cable, through the cable converter and straight through without the converter. when I use a DVD player, throught the RCA jacks, all is fine. Any suggestions
  • 20 Answers
Hook cable directly to television ( no box ) , Then autoprogram the set if you still have the problem replace the tuner it is about $30 rebuilt from Tip Top tuners.Do not attempt if you dont feel comfortable soldering precisely. IRIONS TV & Electronics www.Irionstvshop.com
Posted on Feb 21, 2008
On my RCA TV we can't find a way to hook up our PlayStation 2 to the tv
if your model is too old , you will not find it. however download your instruc. manual from www.fitness.manualsonline.com or www. retrevo.com and looking for the instruction.
God bless you
Jul 12, 2012 | RCA TruFlat 27F520T 27" TV
How do I hook up a dvd player?
Hello Andy, Hi!, you can hook up your DVD in 3 ways. 1. using standard RCA cables, 2, using Svideo cables, and 3. using HDMI cables. Depending on your player. I suggest you buy the RCA cable. they are color coded so the yellow goes to the player Video out to the TV video in, red and white cables goes to the Left and Right channel of the player audio out to the TV audio in. thats it.
Dec 21, 2010 | RCA F27242GY 27" TV
The program light blinks all the time. I do not have a remote. I have a convertor box on the tv and an antanna but I keep getting a message saying to check antanna and connections, no sinal. I get a few...
I'm assuming you are getting more than two digital channels into the converter so the problem lies in how the converter is connected to the TV, which I presume is via a coaxial cable, right and you have the TV tuned to analog channel 3 or 4, right?
If that is all true, the RF coax cable solution is not going to work. The few channels you were getting, either side of 3 or 4 is just RF bleed.
Try this, acquire somehow a A/V hookup cable that has 3 RCA male jacks on each end. One cable will have YELLOW ends, This is composite VIDEO. There will be two others colored RED and WHITE (or perhaps black). This is for the AUDIO. The outputs on the converter and the inputs should be colored the same way. Hook the two up, noting which INPUT (1, 2 or 3) on the TV you have plugged into. Not sure of the exact number your TV has. Make sure you change the TV to INPUT whatever. You may also have to re-scan your converter. As long as your antenna is connected correctly gto the converter you should gain a lot more channels. Let me know how you make out.
Nov 24, 2010 | Panasonic PV-DF2735 27 in. TV/VCR/DVD...
Can't hook vcr to tv
on the back of your VCR there will be a yellow colored port - most likely labeled "OUT" as well as possibly a white/red pair of ports.
The yellow is for a VIDEO hookup, the white and red are for AUDIO hookups.
These ports use what is called an RCA type connection.
Radio Shack, or just about any department store should be able to sell you an inexpensive set of RCA cables.
now on the back of the TV (possibly on the side) you will also have the yellow, white and red ports.
Hook one end of the RCA cable to the colored ports on the VCR, the other end of the cable to the colored ports on the TV.
last thing - the TV most likely has multiple inputs. there is probably a input button on the TVs remote, you need to press that button to cycle through the inputs until you get to the one the VCR is hooked up to.
its easiest to put a tape in the VCR and press play - when you get to the right input, you will see your tape...
good luck
Apr 05, 2010 | Dynex DX-L32-10A 32" LCD HDTV
JVC AV27S33 tv black and white
I would guess you are using an antenna or a cable service without a set-top box.
When the TV is using HDMI or component video it does not employ the decoding for the color as like when using an RF feed. Most people of today do not use RF directly in to their TV set using the built in tuner. They feed a desk-top box that feeds a decoded picture in to the set via the component RGB connectors, or they are using HDMI.
When viewing an RF signal from the antenna or cable using the TV's internal tuner, check the video settings. make sure the setting for Color is turned up to 50% of its range to start with. If there is no color, check to make sure the Settings are correct. Check to see if the TV has a black and white mode, and this mode is turned on.
Check to see if the TV receiver section is for your location type. If you have a set from another country that uses another broadcast system for color this can be an issue.
It is also possible the TV set's color decoder for RF reception is defective. This would require proper service. You would not be able to service this yourself.
Based on the info you supplied these are the best suggestions I can think of...
Mar 11, 2017 | JVC AV-27S33 27" TV
DVD won't play movies in color
RCA cable connectors (red,white, yellow) are usually for an analog setup. You could still use these for "component" setup, but know the difference with color stamps as follows:
Component color stamps are "blue, green, red" ( blue is marked Pb, green is marked Y, red is marked Pr)
RCA color stamps your using are "red, white, yellow"
Here are the proper hook up method for "Component" using your "RCA" connectors:
On both the TV and DVD component setup:
Plug the red RCA fitting in the component port marked "Pr (red)
Plug the white RCA fitting in the component port marked "Pb (blue)
Plug the yellow RCA fitting in the component port marked "Y (green)
Be sure this setup is the same for the TV's component input ports, and the DVD's component output ports.
i-Note:
For optimum picture quality you may want to purchase component cables as the gage is thicker giving better impedance match resulting in better picture and sound quality.
Jan 25, 2009 | Vizio Televison & Video
TV without cable
Depending on how far you are from the broadcaster you can try Rabbit ears or and outside antenna.. If the set is more than two years old you may need a digital converter after Feb 17th
Mar 12, 2008 | RCA 27F500TDV 27 in. TV/VCR/DVD Combo
One channel is suddently in B &W - All rest in color
is it on a cable box? try unplug tv and box, that usually resets everything
Nov 17, 2007 | RCA TruFlat 27F520T 27" TV
Ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Jul 31, 2007 | iLO V27DMBX Television
RCA F27628 27" TV Logo
127 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
