Please help me my hp printer does not work. I cannot print, or fax I can copy. It is an hp officejet 5600
  • 17,970 Answers
Try this:
* Click the Start button.
* Click Control Panel.
* Click System and Maintenance.
NOTE: This step is not required when using Classic view in Windows Vista.
* Click Administrative Tools.
* Double-click Services.
* On the User Account Control window, click Continue.
* Click Print Spooler.
* Click Stop to stop the Print Spooler.
* Click Start to start the Print Spooler.
* Then right click and click restart to Restart the Print Spooler
* Click OK.
Restart the service at a command prompt
1. Click Start Start button , click All Programs, and then click Accessories.
2. Right-click Command Prompt, and then click Run as Administrator.
User Account Control permission If you are prompted for an administrator password or for confirmation, type your password, or click Continue.
3. Type the following commands at the command prompt. Press ENTER after each command.
net stop spooler
net start spooler
EXIT
Make sure you restart your computer too.
Also, if you have received some error message, can try with the HP Support
Hope thats help.
Posted on Feb 05, 2010
My HP OfficeJet 4315 All-in-One printer defaults on FAX mode for some reason. How do I change it to print?
To better help you I did the work for you... I copied this from the HP forum which if you google your issues most of the time you find the answer!
Copied from: http://h30434.www3.hp.com/t5/Other-printing-questions/HP-officejet-4315-all-in-one-printer/td-p/411239
There are generally two print devices set up when an all-in-one with a fax is set up - one is the fax device and the other is the printer. Make sure you have the print device set as the default printer and/or that when you want to print that the printer and not the fax is selected.
Setting the proper printer as default would depend on your operating system, but for most versions of Windows you would go to the printers folder, right click on the non-fax version of the Officejet 4315 and select "Set as default".
Jun 17, 2011 | HP Officejet 4315 All-in-One Printer
IseMY Hp all in one 4355 printer is unable to scan
The HP Officejet 4355 can print, scan, copy and fax.
You need to install the printer software to print and scan. Copy and faxing does not required software installation.
Regards,
Rizwan
Feb 11, 2010 | HP Officejet 4355 All-In-One InkJet...
HP OfficeJet 5610xi Solution Center Download?
Please go to www.hp.com and put officejet 5600 in the search bar and you will find the software program for it. If you can't find it there contact me and I will get it for you. 713-204-9111 or 585@snet.net.
Please leave me good feedback if this helped you.
Jul 10, 2009 | HP Officejet 5610 All-In-One InkJet...
HP6110 All in one
When the HP Office jet series all-in-one front panel screen displays Memory Full, the HP Office jet all-in-one is not able to send, receive or forward faxes. Copying will also not work. WORKAROUND: Though the memory buffer should clear itself automatically after proceeding with the next task, like receiving a fax or starting a copy job, these suggestions below may help you clearing the memory buffer by:
  • Add paper to the HP Officejet series paper tray
  • Clear a possible print jam and proceed printing the fax.
  • Reduce the copying or faxing resolution via the front panel's menu.
  • Use the HP Manager to send a (group) fax or making a copy. More memory is available this way, as the HP Manager utilizes the PC memory. When sending a group fax, the HP Officejet all-in-one's memory is filled to capacity. To copy in color is only possible from the HP Officejet Manager.
  • Press START to clear the message. If this message persists, unplug the power cord, and after at least 15 seconds plug the power cord in.
CAUSE: The HP Officejet series memory may be full due to: Copying on Photo quality or sending a group dial, which will use an extensive part of the internal memory's capacity. No paper in the paper supply tray, while receiving a fax. This may result that the data remains in the buffer. Print jam while receiving a fax or copying. The data is still stored in the buffer. System error displayed on the HP Officejet display window. SUMMARY: The HP Officejet series will not fax or copy without sufficient memory to store the data of the page in the buffer before printing the receiving fax or the copy.
May 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Two sided copies
see your hp all in one help section should be installed as part of your printer software
Apr 09, 2009 | HP Officejet 5610 All-In-One InkJet...
Can't receive faxes
well... check the telephone cable or conector...Rj11 conectors...
Dec 10, 2008 | HP Officejet 5610 All-In-One InkJet...
Hp 5610 won't print
If you need Vista drivers for your printer, go to HP.com to get them and see if that works.
Jun 17, 2008 | HP Officejet 5610 All-In-One InkJet...
Printing
hi,
here are the things that i want you to follow to somehow resolve your issue.
1. On your computer, click on start then go to control panel
2. inside control panel open the PRINTERS and FAXES (XP) or PRINTER (VISTA).
3. make sure change the default printer icon to the HP Officejet 5600 series.
- right click HP Officejet 5600 series and choose "set as default printer"
4. then try printing,
note: the reason why you encounter that problem is because the default printer icon is the "HP officejet 5600 series fax".
best regards
adonscott
Apr 04, 2008 | HP Officejet 5610 All-In-One InkJet...
32 people viewed this question
k24674
jasbo
jasbo
