Question about HP Deskjet 6980 InkJet Printer
Deskjet 6980 - Windows 7 ? 64 bit ? 802.11 connection to printer Printer works fine until computer is re-booted Printer is grayed out and is ?off line? after booting computer ? can?t get it back on line Trouble shooting says to contact my IT administrator ? don?t you love it!!! Can ping the printer and connect to it in via the browser ? not errors I?ve tried configuring the printer IP manually & installing the 6980 as a local printer Another laptop PC with windows 7 (32-bit) has no problems with this printer - also using same wireless connection. Thanks, Lynn
jaylex
  • 417 Answers
SOURCE: connecting Toshiba laptop using windows vista to C7180
Hi there i know that HP are updating a lot of the drivers at the moment you could try the following websites
www.hp.com (Free download)
www.drivers.com (Small charge)
I hope one of those helps but also try the XP driver as may vista might work on XP driver technology.
Thanks J
Posted on Jan 19, 2008
SOURCE: deskjet 970cxi will not print
I need to get the driver software Dekjet 970cxi
Can I get driver software.
Posted on Feb 29, 2008
IB4G2008
  • 3587 Answers
SOURCE: HP Deskjet 6980
start with a fresh set of US based drivers, and follow those instructions. get em here
Posted on Mar 09, 2008
Bubbabear64
  • 2794 Answers
SOURCE: How to change black ink cartridge of HP Deskjet 6980
Lift the cover up.
The ink jet carriage should park in the center of the carriage.
Gently lift on the front of the ink jet until it removes. Some you have to lift up and some you have to lift down on. Just be careful.
HP inkjet cartridges tell you on the front of the stick by a dot weather it is tri color or black.
Posted on Jun 13, 2008
  • 114 Answers
SOURCE: HP Deskjet 6980 Printer. prints on half page
you'll need to reset the print mode to single-sided, also check the print/text size
Posted on Oct 25, 2009
Where to find driver for HP Deskjet 6988 printer in Windows 7 ?
You'll find any available drivers for the HP Deskjet 6988 on the support page for the 6980 series printers: https://support.hp.com/us-en/drivers/selfservice/hp-deskjet-6980-printer-series/468002/model/3422864 .
The Windows 7 driver should be found by Windows Update when you connect the printer with a USB cable. If you are using the printer in a network, you need to manually add a printer (using the wizard) from the Printers and Devices Control Panel. Start this after you have the printer connected to your router or switch. See https://support.hp.com/us-en/document/c01796879 and expand the section for Wireless or Wired Connection (Windows 7, Vista).
I hope this helps.
Apr 14, 2017 | HP Office Equipment & Supplies
I have an HP Deskjet 6980. After changing the black ink cartridge i tried to print. The printer takes the paper but doesnt print, just the Power and the resume lights are blinking. If I press the resume...
The printer might be working but the cartridge is not connected properly. Just open your printer, remove the cartridge and replace it back in its right position.
Mar 25, 2011 | HP Deskjet 6980 InkJet Printer
Which way should i connect the hp deskjet 6980 to network
You can connect it to any of those but I would suggest connecting it directly to your router or a hub on your network for easiest installation.
Nov 17, 2009 | HP Office Equipment & Supplies
I had bought a hp deskjet 6980 and it had been working fine but now when i try to print it will not do anything.
Does the computer still detect the printer? If so then it sounds like the driver may have gone corrupt
Try to uninstall and reinstall the drivers.
Be sure that the device is not connected to the computer until the software prompts you to plug it in
Sep 27, 2009 | HP Deskjet 6980 InkJet Photo Printer
Hp deskjet 6980 - green light on key beside the lock
it can be the problem of cartridges got faulrty so that needs replacement any of the two cartridge can be faulty. or the wire less connection issue.in that caee just conmnect the printer with a usb wire and check out.if same problem in connecting wire then its cartridge issue foir sure.
Feb 26, 2009 | HP Deskjet 6980 InkJet Printer
Lift the cover up.
Jun 13, 2008 | HP Deskjet 6980 InkJet Photo Printer
Hp 6980 printer
Follow this link and you'll find the user manuel (windows 2000) on page 10.
http://h10032.www1.hp.com/ctg/Manual/c00591373.pdf
Apr 04, 2008 | HP Deskjet 6980 InkJet Photo Printer
HP Deskjet 6980
Mar 09, 2008 | HP Deskjet 6980 InkJet Photo Printer
HP Deskjet 6980 InkJet Printer Logo
123 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
