Question about Car Audio & Video
Have kenwood kac 7204 2 channel amp, also 2 - 4 ohm ea kenwood 3012 subs.how can i hook these components to achieve greatest possible rms to ea sub? wire subs series or parallel or ???
  • 102 Answers
Hi you run them in sterio two 4 ohm subs sterio two 8 ohm subs you can run mono or four 4ohm subs can be run in mono also
Posted on Feb 05, 2010
What amp would be better to use with what speakers/sub? I have a KAC-7202 kenwood 920W maximum power (150wX2 RMS, 4ohms) (230wX2 RMS 2ohms) and then the other amp I have is a Alpine MRP-M500 mono power...
I'm using that Alpine right now for 2-12" subs and I have compared it to 6 or 7 other amps this month and most were 4 channel 150Watt/Channel Bridged to 300Watts x 2 and found the Alpine to be superior in both sound quality and loudness. The Alpine has also not turned off even with full volume for hours at a time, Very solid amp I was very surprised due to it's size!
Apr 04, 2013 | Kenwood Car Audio & Video
My kenwood KAC-7204--- the wiring is hooked up right, I just got a 2000 watt max sub 1000 watt rms, i was running the amp in bridge mode and it ran for 1 day than it turned off. I checked it and the fuse...
when i was running my sub off bridge mode this kept happening to me. I ended up just running two subs and for some reason the fuse stopped blowing. i think there is something wrong with these amps.
Jun 04, 2011 | Kenwood KAC-7204 Car Audio Amplifier
The subs aren't pushing out bass.
Hello crobins2,
The Kenwood KAC-6202 2-channel is only rated for 60 watts RMS per channel into a 4 ohm load. That just isn't much power for a pair of 12" subs. Even the bridged output is only 200 watts into 4 ohms, still at the low end for a sub, much less to share between a pair of subs.
Assuming that your subs are 4 ohm, you could probably get more sound by driving just one of them on the bridged terminals. But to get the best power with what you have, connect one sub to each channel, set the filter switch to the far right (LPF), set the operation switch to stereo (both channels driven), set the filter frequency (Hz) to 100 or lower, and adjust the input sensitivity as far clockwise as possible without causing distortion.
But, to do the subs justice, you really need at least 300-400 watts to share between them.
Hope this helps.
Sep 27, 2009 | Kenwood KAC-6202 Car Audio Amplifier
Why does the kenwood kac-9103d has two sets of terminals if its a one channel amp so how do i hook up a dual 12 phoniex gold 1200 watt sub to it
Hello damasogrizzl,
The 2 sets of terminals are connected internally. Having 2 sets just makes it more convenient when wiring multiple subs. The amp is rated for 900 watts RMS into a 2 ohm load. The specs claim that it is stable at 1 ohm but does not give a power rating.
The Radial SD competition series from Phoenix Gold are rated to handle up to 600 watts RMS. If you have the model RSdC124 with dual 4 ohm voice coils, it would be best to wire the voice coils in parallel for a 2 ohm load and connect the sub to one set of terminals on the amp. If your sub is the model RSdC122 with dual 2 ohm voice coils, you should wire the voice coils is series for a 4 ohm load and connect the sug to one set of terminals on the amp. Wiring the voice coils in parallel will result in a 1 ohm load. And, while the amp may be stable at 1 ohm, the sub will be seriously overpowered.
Hope this helps.
Sep 23, 2009 | Kenwood KAC-9103D Car Audio Amplifier
Just woundering if i could bridge one sub to front and one to rear the subs are kenwood w3514 dvc subs the amp is kenwood kac-x501f
Hello bigmac208,
Yes, that would be the best connection for both the subs and the amp.
I'd wire the sub voice coils in series since the amp will not be stable at 2 ohms when the channels are bridged. The power will be somewhere between 100-200 watts RMS to each sub. While it's not pavement pounding, it should provide pretty good bass, especially if you tweak the crossover and boost settings for best bass response.
Hope this helps.
Aug 28, 2009 | Kenwood KAC-X501F Car Audio Amplifier
Kenwood kac-7204 1000w amp with 12 in sub what size wires nedded to use
bigger the better my friend. Look at your Peak RMS output, and how long of wire you need. Then you could make the judgment call on how thick or what gauge you need. (2 involved factors power + distance). id say 10 gauge and you would be fine.
Jun 03, 2009 | Kenwood KAC-7204 Car Audio Amplifier
How too hook my kac 7201 up to my two dual 4 ohm Alpine type Rs
Hello manbearpig65,
Well, that's a 2-channel amp, so it's really best used to power a set of regular speakers.
The best power solution, for your existing components, is to wire each of your subs voice coils in parallel, resulting in a 2 ohm load, and then run each sub off a separate channel from the amp.
The amp is stable only to 4 ohms in bridged mode, so you would series the sub voice coils (8 ohm load) and then parallel them (4 ohm load) to the amp bridged connection. This will result in less power to each sub than if you ran them separately.
Hope this helps.
Apr 10, 2009 | Kenwood KAC-7201 Car Audio Amplifier
Adjusting wattage on kenwood kac 9103 class D mono amp
That amplifier is 900W x 1 @ 2ohms.
If your subs are 4ohm SVC wired Parallel, resulting in a 2 ohm load, each sub will only see 1/2 of the rated power. (450W ea.)
Your gain (sensitivity) setting should be between 75% and 85% to max. You will be fine.
Jan 02, 2009 | Kenwood KAC-9103D Car Audio Amplifier
Car Audio & Video Logo
109 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
