Question about Refrigerators
Hi i have a problem with the above fridge/freezer all the lights are on it makes the appropreiate noises at the right time the fan is working fine no previous problems but now the fridge and the freezer are no longer functioning the freezer has defrosted and the fridge no longer gets cold . Help anybody?
    President:
  • 1,515 Answers
Hi, if the freezer fan is on, you need to get behind it and remove the panel where the compressor and condenser coil and fan motor are located. They both should be up and running also. If not, feel the top of compressor and see if it is hot but Carefully, they can get very HOT. If the fan motor is not running, that will be the problem. If it is, see if the front of the coil is dirty, like a sheet of dirt on it. Clean it. If the compressor is hot and off, and fan is running, the compressor is off on external overload. Locked up.If it tries to start you can hear it click off and back on. This is the overload. More then likely, the compressor will be faulty. If the motor is off, replace it and it will work as soon as the compressor cools down. Unplug it if the motor is bad. You can get one at a appliance parts store. Take all part, model, serial, numbers along. Check these out and keep me posted.
Sincerely,
Shastalaker7
Posted on Feb 05, 2010
Fridge freezer probs
From the sound of it I would looking at the evaporator fan in the freezer. This is what circulates air and actually cools the refrigerator as well as the freezer
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 21, 2012 | Maytag Refrigerators
I HAVE A CLICKING NOISE THAT I THINK IS COMING FROM THE BACK OF THE FRIDGE. I PULLED THE FRIDGE OUT TODAY AND DID A THROUGH CLEANING. TOOK THE BACK PANAL OFF AND CLEANED THE FAN .AND EVERYTHING I COULD...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101 .
Nov 02, 2010 | Maytag MZD2669KE Side by Side Refrigerator
I have a monogram ZIS420 the freezer works fine
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 24, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
Freezer working fine (no ice buildup), refrigerator warm
make sure your cond under ref is clean allso check your door gaskets if its getting moisture in it i have seen the damper stick from ice from door gasket and when your defrosting evap its clearing damper
Jul 05, 2009 | Roper RT14DKX Top Freezer Refrigerator
Top sections of Freezer and Fridge not Cold at all
check fan is free to rotate and that it has continuity. also check you have power to the fan.
you may just need to replace the fan motor
Oct 19, 2008 | KitchenAid KSRS25IL Side by Side...
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Loud buzzing noise from inside Jenn Air 2389G fridge
i don't know jennair specifically being from england.
however, there is often a fan inside the back panel and the noise you heard was the fan hitting ice. the reason now not heard and fridge not working may be that the ice has built up so much the fan is jammed
Jun 25, 2008 | Jenn-Air JCB2388G Side by Side...
Samsung american style fridge/freezer needs repairing
Spray a good quantity of WD-40 on the spindle of the fan motor where it enters the motor itself. This should get the fan working smoothly with no noise. This will probably solve the other problems, as the fan prevents various components from overheating and shutting down.
Apr 01, 2008 | Refrigerators
Ge fridge
you have 2 fans one underneath by compressor ,one in freezer make sure one in freezer is running
Dec 14, 2007 | GE GDS20SBS Stainless Steel Bottom Freezer...
Refrigerators Logo
103 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
