Question about Sony Playstation 3 (PS3) Console
I hooked my ps3 up to HD input now trying to hook it back up with tv/video input. Can not get a picture on the tv now. Any Help?
  • 641 Answers
After you hook it up..unplug it for 10 secnds,then plug it back in and when you turn it on ,hold the power button down till you see somethng on the tv..a menu will pop up..
Posted on Feb 05, 2010
Mitsubishi rear projection tv, model WS-48311 - Lost audio after moving tv and re-hooking up cables. How do I get it back?
It sounds like this TV is being used only for the PS3. We'll need to troubleshoot this through a process of elimination.
If you're using Component Input 1 and audio, try using Component Input 2 and audio instead. If this set of inputs provides working audio and video - you can stop. Or, try going back to Input 1 once more. If Input 1 now works - you may have simply made a better connection. If it doesn't - then there's probably an issue with input 1 on the TV.
If moving to Input 2 above still didn't solve the problem, you should try using a different set of audio cables between the HDFury and the TV. If it now works, the original audio cables are faulty.
You can check the HDfury setup on another HDTV with component inputs with it connected to an HDMI cable. if the HDFury wors, you know the device and all the cables work. If you do this test and it works with your PS3, then you know that the PS3 is providing good video and audio signals via HDMI. If the problem follows the PS3 - then it's the PS3 at fault. If everything works perfectly on the second TV, then there is some issue with the audio amplifier / inputs / speakers of the Mitsu TV. You could get a cheapo stereo amp and speakers - or a set of computer speakers for audio - it all depends on how much you want to spend for sound.
Good lcuk!
May 07, 2015 | Mitsubishi Televison & Video
No dvi pictur showin up on my plasma tv
try a lower video output resolution on your PS3
Nov 09, 2009 | Gateway GTW-P42M303 42 in. Plasma...
PS3 not working on reg tv's after HDMI use on LCD HD tv
Shelley,  the fix for this is simple! Hold down the power button for about 5 seconds and the system will beep. This resets the video setting for your ps3 from HD too whatever the current cables are that you are using too hook up too the tv. This works on my PS3 which I just bought about 3 months ago and should work with the older ones.
Jun 05, 2009 | LG 37LC2D Television
PS3 Video Connection--Lines on TV
this may be due to the fact that your ps3 will be set up to hd. go into video settings when you switch it on and this should solve the problem. i had similar problems and bought a hdtv until someone pointed this out to me. however once you have experienced ps3 in hd you will not go back!!! hope this helps
Jan 13, 2009 | Sony Playstation 3 (PS3) Console
No picture or sound on ordinary TV after hooking up with HD TV
You system is still out-putting through the HDMI cable. Press & hold the "on" button after the system is already on, it should go back to regular factory settings & show up on your screen.
Dec 14, 2008 | Sony Playstation 3 (PS3) Console
No Picture, Only sound
You need to tell the PS3 that you are now using the new video method. It is still trying to output video on the yellow cable, not the component. If you go to settings>video and tell it to use component, and then switch the cables real quick, it should work.
An easier solution is to do a backup from the system menu, then a "restore" (quick restore is fine), and then power it off, hook up the new cable, and it will detect the video method when it turns on for the "first" time (since the restore).
You do have component input on your TV, and that is the input you are on when you are trying this, yes?
Jul 22, 2008 | Sony Playstation 3 (PS3) Console
No sound or picture
PS3 is The amazing device by sony but it has some common problems like sound problem, video problem etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Jul 14, 2008 | Sony Playstation 3 (PS3) Console
PS3 wont show up on TV
you will have to find an hdtv to change it back.
Mar 08, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
43 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
