Question about Lexicon Lambda Usb Desktop Recording Interface Sound Card
No gain Can't increase the gain. Checked the mikes, bought new cables, etc. My Toshiba Satellite meets all the requirements (504 meg of ram, 1.6 gHz processor). But even with the level wide open I get very little signal on both Mic 1 and 2. Mics used: Rode NT1-A and Shure SM58. I know about phantom power. I even re-read the manual (such as it is). No more ideas. Would appreciate any help.
Happened to me too, I just fiddled with the phantom power button (wiggled it a little while it was pressed in) and my gain came back *shrug*
Posted on Mar 10, 2008
Video controller for windows 7
From Microsoft:
If you want to run Windows 7 on your PC, here's what it takes:
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
IF your Notebook meets all other specs you would need the the above device/driver. which may or may not be compatible with the Toshiba, which was pre loaded with Windows XP.
Thanks!
Jimm
Nov 22, 2012 | Toshiba Satellite A40-S161 Notebook
Pasos para instalacion de web camvx2000
Hola amigo primero que nada devemos saber que systema operativo usa tu computador Windows Xp Vista or Windows 7
Esta Web cam es configura automaticamente per piensa tambien en los requerimientos del su systema. aqui algunos tips.
Habla en espanol y solo pregunta ok
Techbelkin
System Requirements Operating System For Windows®-based PC
Requires a PC that meets the requirements for and has installed one of these operating systems
Processor Windows® 7
Mmimimum: Intel Pentium 4 (3 GhZ), 1 GB of RAM; recommended: Intel Pentium (Dual-Core 1.8 GHz), 2 GB of RAM, 1250 MB free Windows Vista®
Windows® XP with Service Pack 2 (SP2) or later
Other CD-ROM
USB 1.1 (2.0 recommended)
16-bit color depth or higher, 2 MB or higher video memory
Windows-compatible speakers or headphones Internet Broadband Internet access may be required for certain features. Local and/or long-distance telephone toll charges may apply.
Internet functions also require Internet Explorer® 6/7 for installation; 25 MB hard-drive space typically required.
Nov 03, 2010 | Microsoft LifeCam VX2000 Webcam
I have a compaq presario c700 running windows vista. On my previous laptop I was able to record successfully using Audacity. Now, however, recordings are very poor - the sound comes and goes, and is of...
Stuart, make sure have the System requirements Here are the recommended memory (MB or GB of RAM) and processor speed (GHz) requirements for using Audacity with different versions of Vista:
Version Recommended RAM/
processor speed Minimum RAM/
processor speed Vista Home Basic 2 GB / 1 GHz 512 MB / 1 GHz All other Vista versions 4 GB / 2 GHz 1 GB / 1 GHz
Note that the minimum system requirements as defined above (i.e. those that allow the operating system to run, ignoring what is required to run applications) are much greater than for Windows XP. If your computer does not significantly exceed these minimum requirements then you may have problems doing more intensive tasks in Audacity such as recording for long periods or editing a large number of long tracks, or may need to close other programs and processes before you can do so. Please be aware that the cheapest "deals" for new Vista machines may well only include the Vista Home Basic Edition and system specifications little in excess of the Vista minimum requirements.
Other things being equal, 64-bit versions of Vista will require more RAM than 32-bit versions. While some users report Audacity runs fine on 64-bit Vista with 2 GB RAM, this depends on the number of tracks being worked with and the number of other programs and services running on the computer. Memory is now very inexpensive. The general recommendation for 64-bit Vista is to install a minimum of 4 GB RAM - and for very best performance, install the maximum RAM that your motherboard supports.
If you meet the min system requirements. Uninstall your sound card drives and try the beta version for Windows Vista.
http://audacity.sourceforge.net/download/
WBTech
Jan 19, 2010 | Apple iMic, USB Audio Interface Sound Card
I have an opportunity to get a free Compaq Presario 1260 with no OS, but I don't know if it's possible to load Windows XP Pro on this type of machine, and I have not tried out my Ubuntu linux disk yet....
My old Toshiba Satellite 490 is even older and has much less processor power and I run XP on it just fine. In fact XP runs faster on it then 98 did.
Known Problems Compaq Presario 1200 laptops are often found with damaged power jacks. Some of these power jacks appear to have been blown in half due to some sort of short; others rip their copper traces off of the motherboard due to stress placed on the power jack. Presario 1200 laptops typically have four tiny copper rings embedded in the motherboard behind the power jack that can be used to reattach a slightly damaged power jack and repair the failing unit.
The LCD Power Inverter cable (which runs through the hinge from the base to the screen), is very susceptible to damage, given the strain of bending when closing the lid. The cable is a 6-strain ribbon variety, and therefore soldering is all but impossible.
Dec 16, 2009 | Compaq Presario 1260 Notebook
Why do my toshiba satellite only show 191 of ram when i have a 256 ram installed
There is nothing wrong. Your RAM may be special RAM that the computer uses some of the memory for something else.
Sep 23, 2009 | Toshiba 15.4-inch 1.6GHz 60GB Laptop PC...
CPU upgrade for Satellite 5205-S505
You would only get a marginal performance increase. If your laptop has 256Mb of RAM, increasing the RAM up to 1Gb (this model laptop cannot support more than 1Gb RAM) would boost the performance of the laptop.
Jun 20, 2009 | Toshiba Satelite 5205-S505 Notebook
Toshiba Satellite A215-S7407 ram upgrade
Try to disconnect the new ram you just bought one at the time to see which one is defective. Also, 32 bit operating systems won't detect 4 Gb or ram, but they will show 3 Gb (even though they will use all 4 Gb). To resolve this issue, make sure that if you are using windows Vista to download the latest service pack 1.
Apr 03, 2009 | Toshiba Satellite A215-S7407 Notebook
Toshiba Satellite 1805-s253 memory upgrade
Usually this means it supports 512 mb of "Single sided" ram, which is rarer and more expensive... the usual ram you buy now is double-sided.. which will often only see one of the sides in older machines.
Mar 13, 2009 | Toshiba Satellite 1805-S253 Notebook
Toshiba Satellite Pro M15-S405 Memory upgrade problem
This usually happens when the laptop is not able to take more then a certain amount of memory, as the system BIOS does not support higher. By saying ACPI as the blue screen, that tells me that the power subsystem does not 'like' having more then 512MB of RAM. I am 95% sure this is your BIOS because of that information. Check and see if you can find a BIOS upgrade for your computer model, and that might fix the issue, if an update is available.
Jan 21, 2009 | Toshiba Satellite Pro M15-S405 Notebook
Lexicon Lambda Usb Desktop Recording Interface Sound Card Logo
161 people viewed this question
Top Lexicon Computers & Internet Experts
Tony
aftab Nawaz
aftab Nawaz
Alun Cox
Are you a Lexicon Computer and Internet Expert? Answer questions, earn points and help others
