Question about Canon PIXMA MX700 All-In-One InkJet Printer
Printer started printing with a line running down the page that was either skipping or missing ink and then at times a line will be unreadable because it is jumbled up and in italics
  • tomshirleyhu Feb 05, 2010
    I am also getting an error code 5100 now. That may have something to do with the problem since it is a carriage issue according to the internet
  • Canon Master
  • 19,396 Answers
Hi.
First ensure that this is not a driver issue. Please download update drivers from Canon clicking here and following instructions here :How to download driver for a Canon printer.
Test also using a different USB cable.
If that does not fix the problem, then the symptoms are those of a faulty controller board on the printer.
Try installing drivers first. If that does not work, then there may be a major fault, in that case contact Canon at the number listed on the manual or on Canon website if you want to arrange repair.
Regards.
Posted on Feb 05, 2010
  • Ginko
    Ginko Feb 05, 2010
    If this is an ink carriage position issue, the what you refer as italic characters are instead badly printer characters because the position of the ink carriage is not detected properly.
    The ink carriage position is sensed using the encoder strip, that is that plastic strip running behind the ink carriage, near to the traction belt.
    If the strip is dirty, it can be cleaned using isopropyl alcohol and cotton. If that does not fix the issue, then the strip may need replacement, or there is a faulty control board. Error 5100 can also be caused by other traction problems, but the encoder strip is the most frequent reason for this error.
    Regards.
Black ink is skipping lines
Take out cartridge put in a sandwich baggie and shake it; then re-install
Sep 25, 2014 | Canon PIXMA MP610 InkJet Printer
My pixma mp500 is skipping lines when printing
If you have refilled with non genuine ink this could be the problem. Or you could test print a few pages in case there is a blockage
Sep 20, 2012 | Canon Pixma MP500 All-In-One InkJet...
My mp mP830 prints some lines (or partial lines) Consistantly misses the same rows each page
Sounds like the ink is running out at the same time each printing. Check the ink supply. The printer may not be letting you know the correct amount remaining. It could also be the ink jets themselves getting clogged and not distributing the ink enough to compensate for the amount of printing ink, on the page, in time to print all of it in succession. Do a test of no printing except where it seems to be missing and just print that area (print: selection).
Sep 16, 2010 | Office Equipment & Supplies
New ink cartridges installed and sometimes prints with missing horizontal areas(blank lines about 1/8 inch thick 20 plus randome down the page. The next time printing may be fine. Color is washed out...
Replace the print heads for the coloured inks you replaced, run the align printer head diagnotic from the printer menu. This should correct the print problem.
May 21, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
Printer prints every second line or prints 4 lines then skips a line or only prints half a line.....the top part of the line is missing.
Hello sir; I believe it's time to clean print head and ink cell, power on the machine open the cover ( as you replace cartridge) , when carriage move to the center , then UNPLUG the power cord. then you may move carriage freely by hand all the way to left, noe you can clean up ink cell easily.
Sep 25, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Skipping while printing
STEP: Disconnect and Reconnect the Printer Power Supply
Additional Information
1.
Unplug the power cord from the wall socket.
2.
Disconnect the power supply from the back of the printer.
3.
Wait 15 seconds.
4.
Reconnect the power supply to the back of the printer.
5.
Plug the power cord back into the wall socket.
STEP: Perform a nozzle clean on the printer.
The following steps will guide you through running a nozzle clean on the 922 printer:
1. Press the Scan Button and the Up Button at the same time to enter diagnostic mode.
2. Use the Up Button or Down Button to navigate to Clean on the LCD and press Menu to begin the nozzle clean.
3. Check the nozzle clean printout and make sure that it is clear of defects and that all expected color bars exist on the page.
STEP: Clear NVRAM on the 922 Printer
1.
2.
Use the Up Button or the Down Button to navigate to the option for Clear NVRAM on the LCD and press Menu to confirm.
3.
Press Menu again when asked if you are sure.
4.
Press Menu again when asked if you are really sure.
Ink Cartridge and Print Quality Issues on Inkjet Printer
STEP: Verify the Paper Settings and Change the Quality Level
1. Click the Start button, point to Control Panel, and then click the Printers and Other Hardware menu item.
2. Click the Printers and Faxes menu item.
3. Right-click the Dell AIO Printer Model Number icon, where Model Number is the model of the printer to troubleshoot.
4. Click the Properties menu and the Printing Preferences menu option.
5. Click the Quality/Copies tab.
6. Click the Paper Setup button.
7. Choose the appropriate paper type based on what is being used in the printer.
STEP: Verify the Printer Ink Levels
Quality problems are most often caused by low ink levels or one or more colors in the color cartridge being completely depleted. Perform the following steps to determine the current ink levels and to check for missing colors.
1. Click the Start button, point to All Programs, and then click Dell Printers.
2. Click the model number of your Dell printer.
3. Click Dell Printer Solution Center.
4. On the main window of the solution center you will see two ink tanks in the lower right hand corner. Verify that the ink cartridges are not empty
To ensure that the quality problem is not caused by one color missing print a test page and verify that the colors in the CMYK boxes appear correct. To do so, perform the following actions from the solution center window:
1. Click the Maintenance button on the left-hand side of the window.
2. Click Print Test Page.
3. Verify that the Cyan, Magenta, Yellow, and blacK colors are printing without streaks.
Apr 22, 2009 | Dell 922 All-In-One InkJet Printer
HP J5780 Problem-Line on printed pages
most likely you have a flat spot on the roller.
that is exactly what is going to happen, when the paper hits the flat spot or a low spot. the paper stops and skips. them the print is coming out smeared.
you can get a repair kit or replacement roller from HP.
Jan 04, 2009 | HP Officejet J5780 All-In-One InkJet...
Full ink cartriges print a few lines and skip a few lines
well..did you run a test page?
or clean the print heads?
or recalibrate them?
recommend all these steps for you
and as my 2200th solution, you are entitled to a FREE tuneup for good. find out more about that service here
Mar 23, 2008 | Canon PIXMA iP90 Mobile Printer
Epson Printer - Skipping When Printing Black
If you try the print head alignment or head cleaning wizard under the maintenance tab, they may help!
Dec 18, 2007 | Epson Stylus CX3810 All-In-One InkJet...
Canon PIXMA MX700 All-In-One InkJet Printer Logo
old marine
old marine
