Question about Canon PIXMA iP90 Mobile Printer
Canon ip90: paper won't pull through rollers. Rollers are turning and nothing seems to be lodged in printer. The case is not bent in any way.
    President:
  • 2,306 Answers
It's a plastic case and you can't see without removing covers. If it's been packed in luggage, any weight put on top it can bend and you can't see it from the outside. When the top is bent you might see from the front, but sometimes the bottom gets bent upward which also stops paper from going thru. The covers are plastic and return to normal shape after bending the inside parts.
Posted on Feb 05, 2010
Canon ip90 will not take paper through the printer
I have had similar problems with Canon and Epson printers. Standard solutions are not earth shaking, but worth a try. Use paper heavier than 20 lb, get a roller cleaner paper from the manufacturer
and run it through to clean the rollers.
Jun 04, 2014 | Canon PIXMA iP90 Mobile Printer
Ip90 printer makes a vibrating buzzing noise upon start up
something is obstructing the rollers.something such as an office pin or pen/cock or any other thing might have fallen inside.open the machine and clear the jam.
Dec 26, 2013 | Canon PIXMA iP90 Mobile Printer
Canon pixma mp495 rear tray rollers only pulls paper in on one side then it jams
When the paper does not feed straight, dirty or sticky rollers can cause it to jamb or crinkle, also failure to remove all traces of paper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these pieces of paper. The rollers may be dirty or sticky and causes the paper to not feed straight.
Try cleaning the rollers with methylated spirits.
Mar 30, 2013 | Canon PIXMA MP495 Wireless Photo...
Paper keeps jamming on my canon mp 480 . I have already turn upside down and looked for small bits of paper nothing came out when i try and print it makes a small buckle in paper just off center to left...
Small bits of paper lodged near the gears at the back of the rollers are difficult to see and remove. This causes the paper to jamb and crumble.
You most likely need to dismantle the printer to find the bits of paper.
When you pull paper from a fresh jamb out of the printer, do it slowly and avoid tearing the paper, if you do make sure you have all the pieces of paper.
Apr 03, 2012 | Canon Pixma MP480 All-In-One InkJet...
Paper jam
This seems to be fault in the transport of the paper in the rollers. So if you have used any adhesive sticker printing, it is possible that some glue has got clogged into the rollers. If not there can be some jammed paper in the rollers or the mechanism.
So start this work only if you are mechanically able with the right tools.
Remove the covers to get access to the mechanism . Remove the motor drive assembly , the fitting of the motor to the mechanism. Once this is removed the rollers can be turned manually so that you will be able to feed a paper to see the progress of the movement while studying if there is any obstruction or damage to the paper.
There is a in-detect sensor, usually an opto-coupler , make sure this is not clogged or dirty as this IR detection feeds the signal to the processor for starting the motor drive feed.
Reassemble but make sure the rollers are aligned to be in equal gap to feed the paper without a side pull. Now you must print and see if the fault has changed. If not repeat the above work to confirm the area of obstruction.
Check this link for tips;
http://www.ehow.com/how_113761_clear-printer-paper.html
Thank you for using Fixya
The advice/tip given is with the belief that you are competent. You must attempt to do it yourself only if you are technically/logically able, especially when dealing with delicate devices, damaging while trying to open, Probing electrical/electronic circuits with high voltage or delicate components. Since the advice given by me is with the inputs provided and not based on a visual inspection, there can be further reviews required in some cases.
Sep 23, 2011 | Canon PIXMA iP90 InkJet Printer
Adf takes more than one page per feed
Sheet detector sensor has been damaged or bent probably by a paper jam (assume you have set the paper weight in the printer dialogue box to the correct media). Best solution, check the feed path of the paper and see if there are any rollers or grippers bent out of true and try to straighten them gently.
Jul 18, 2011 | Canon PIXMA MP780 All-In-One InkJet...
Before printer begins it does not pull paper to priny on
If you look at the inside edge of the paper tray, you should see pick-up rollers. Check to see if those rollers turn when the printer begins. If not, you probably have a mechanical problem like a bad belt, gear, or pulley. If the rollers do turn, make sure that the paper is properly seated against the inside edge of the paper tray. Also make sure that the inside paper edges are not bent or creased. Sometimes it also helps to pull out the stack of paper, fan the inside edges by running your finger or thumb from top to bottom, and reinsert the paper.
2)
Oct 21, 2010 | Canon PIXMA MX310 All-In-One Printer
After a paper jam, my canon mp140 does not print at all. It says to clear paper jam, but i have remove paper. Is there a solution?
Is is possible that bits of paper is lodged into the roller or into the sensor area that is showing it as a detect.
The rollers may be jammed and so it will be good to release the motor drive with a manual twist.
So disconnect printer, then open panel and remove motor to turn the rollers.
Once it is free , reset to test
Sep 13, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Canon ip90 printer wont grab paper
The most likely culprit is that the rollers that pull the paper are dirty. Use the steps below to clean the rollers.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
1) Confirm that the printer is powered on.
2) Remove any paper from the printer.
3) Press and hold the <Resume/Cancel> button.
4) Release the <Resume/Cancel> button after the Power lamp blinks three times.
Note: The Power lamp will blink and the paper feed roller starts cleaning itself by revolving.
5) When the Power lamp lights in green, repeat Steps 3 and 4 up to two additional times. (Please wait approx. 30 seconds for paper feed roller cleaning to complete.)
6) To confirm whether cleaning has been performed properly, set a blank sheet of plain paper (8 1/2 x 11 Letter size) in the sheet feeder or cassette.
7) Press and hold the <Resume/Cancel> button and release it when the Power lamp blinks three times. (The paper set in the printer is picked up and fed.)
8) Repeat the process as necessary
May 12, 2008 | Canon PIXMA iP90 Mobile Printer
Canon PIXMA iP90 Mobile Printer Logo
146 people viewed this question
old marine
old marine
