Panasonic 42" plasma - TH-42PX6U The right half of the tv went black - the left half is fine. The TV is 3 years old. My husband is great w/ electronic stuff and will try to fix himself if he knows what parts to get - any help would be greatly appreciated! susan
  • 1 more comment
  • slnutini Feb 05, 2010
    purchased the manual - thank you!
    Just wanted to clarify - of the boards listed I see only 1 Scan drive, then a Scan Out Upper and a Scan Out Lower; and also a Data Drive Lower Right and a Data Drive Lower Left. Which
    one (s) would we be looking to taking a shot at replacing? Sorry - just bugging you again because
    of the single Scan Drive board that I see listed - and we were going to do as you suggested and try
    replacing the 2 boards, going with the assumption that the other side would be going out too!
    thanks again,
    susan
    very helpful - thank you! we'll give it a go!
  • slnutini Feb 11, 2010
    Thank you again!! TV FIXED!!!!!! What a relief. =)
    President:
  • 1,077 Answers
The first thing needed is a Service Manual. This will help you take the TV apart and remove circuit boards properly without damaging anything. This Service Manual will give you factory part numbers for replacement circuit boards plus other helpful information about the TV. Here's where you can get one:
http://www.service-docs.com/store/catalogue.php?cat=278&exp=&resultpage=36&shop=1
You can shop around the net for cheaper or maybe free one. But, free Service Manuals are rare.
When you take the TV apart, I'm 90% sure the bottom left side buffer board needs to be replaced. Sometimes called a Scan Drive Board or Buffer Board. The Boards on the bottom control the vertical image and the Boards on the side control the horizontal image. The right board controls the right side and the left board controls the left side ( Well, you get the idea ). It maybe a good idea to have both bottom boards replaced. One board goes bad and the other board is probably not to far along to go bad.
Good places to find replacement boards ( at a non rip-off price ) are at Shopjimmy.com or E-bay. Just make sure the part numbers match up on the board itself or the Service Manual.
Posted on Feb 05, 2010
  • Devon Sacco
    Devon Sacco Feb 05, 2010
    Don't worry, your not bugging. :)
    I believe it would be the Data Drive Lower Right and a Data Drive Lower Left. When the board burns out, it would have a bad smell to it and it would over heat. Look for dark burn spots. It may not show any signs, but it should be the Data Drive Lower Left causing the problem since the left side of the screen isn't working. The Data Drive Lower Right may go soon since it's the same age ( just a precaution ).
  • Devon Sacco
    Devon Sacco Feb 11, 2010
    I'm glad your TV is fixed. Have a happy Valentine's Day. :)
Viore 42" plasma tv has
The tv was working fine until this morning, then the picture went out but the sound is still working.
TV is only 3 years old, no real electrical problems
Jan 29, 2011 | Toymax Viore 42 in. Plasma TV
Problem with TV image, sound is OK. My Panasonic Plasma TV is a TH-42PX6U starting from the middle of the screen, the left side does not have any image, it is divided in two, with half been white and...
if you ask me the panel its dead to lose the half of the screen means no addressing logic board dead or in the most of the cases panel :( i`m not sure but if you add some images :D with signal is it the same ?
Sep 22, 2010 | Panasonic TH-42PX60U Television
PANASONIC TH-42PX60U 42 - half of screen not working
I had the same issue. I am going to replace my scan buffer boards. The upper half of mine works but the lower half is black so I would replace the lower Scan buffer board but in case of future issues I have ordered both upper and lower for $44.
The scan buffer boards are fairly simple to locate. Open up back of tv there are two biffer boards identical. The item or product code on them contain letters either SU or SD (Scan up and Scan down)Look up tv parts and item code you will find a place to order or just get the 1 800 number from tv manufacturer.
Jun 18, 2010 | Panasonic TH-42PX60U Television
Half the screen is black
my panasonic th-58pz800u well not even come on no blinking lights at all
Apr 16, 2010 | Panasonic TH-58PZ800U 58 in. HD-Ready...
3 year old Viera with half white screen?
hello, you have a half screen what side? the fualt may be a board or a couple of boards it depends what side is off and what part, lower half, half, left or right sides. let me know i will check the results. it is servicable if your electronicaly inclined you can find the fualt by finding a service manual for this set, i have one. if you tell me what side is white and what portion i can tell you what board it is.. hope this helps
Jul 13, 2009 | Panasonic TH-42PZ700U 42 in. Plasma...
Panasonic TH-42PX75U won't turn on
Your powerboard is damaged, and need to be replaced.
Sometimes it appear the TV is working again with no problem but it is only a matter of time for the board to get completely damaged.
May 30, 2009 | Panasonic TH-42PX75U 42 in. Plasma...
Plasma TV with vertical lines
chake to make sure it is hooked up right and not lose
Feb 02, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Vertical bar on Daewoo Plasma screen
try this, can't hurt!
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
st
Sep 04, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Help! My Plasma by Magnavox is putting black verticle lines on the right side of the screen - comes and goes - and I replaced the entire Direct TV-HD unit - wires, everything - and had TV company repair - and it still came back. The TV repair refuses to take TV back because it does not show up when they come. Although I videotaped it and showed them which has the date and time - they still refused to take it - and tried to get me to sign a paper saying it was working while they were there - which of course I refused to sign - so they left and nastily said they will not be back-find someone else. I still have the lines - and do not know what to do! Can anyone help?
Jul 27, 2008 | Panasonic TH-42PZ700U 42 in. Plasma...
Televison & Video Logo
Top Televison & Video Experts
