Question about Samsung 226BW Monitor
I have a Samsung Syncmaster 225BW. It has been working great. I usually leave it on 24/7 but last night I turned of the power to the screen while the computer continued to defrag. when I turn the power switch back on on the monitor, it came on dimly for about 5 seconds then went black. So turned power back off for about 10 minutes and tried again; same thing. Tried again 4 more times; same result. now I have to resort to using my laptop, but i need to access my PC; ANY IDEAS Bob
  • foresite Feb 05, 2010
    I just tried hooking the monitor up to another 2 different computers while waitng for your answer to arrive; same result. It appears to be the monitor not the computers.
  • 10,594 Answers
I would check leaky electrolytic capacitors in power supply board of this monitor for these symptoms.
Please check any leaky/ swollen top/ bulged capacitor in power supply board and replace them.
Hope this info will help you to solve the monitor power issue.
Thanks.
Posted on Feb 06, 2010
  • 4,281 Answers
For that when you power up the computer press F8 key then if you are able to see safe mode and other menu then enter in "enable vga mode" then go to display property then change screen resolution to 1024*768 then apply.
But if you are not able to see it then when you power up the computer press F1 or F2 or "del" key to enter in bios.
Then make sure your harddrive is recognized there.
if still same issue then open cpu cabinet.
Reattach the RAM memory.
Pull cmos cell from motherboard for 10 minutes.
Reattach both connection to harddrive then check.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Feb 05, 2010
  • So You need to repair your monitor screen.
    Some issue with monitor circuit board.
    Repair it at nearest service center.
    Thanks for using Fixya.
Samsung Syncmaster 225BW startup problem
reinstall the driver. what was the last update that you applied in general. revert back to LKGC last known good configuration.
Mar 07, 2014 | Samsung SyncMaster 225BW 22-Inch LCD...
I have a SyncMaster 225bw, approx 3 years old but havnt used it much in the last year and a half. it started having a problem starting back up it seems. if i can get it to stay "lit up" it will...
This type of monitor problem is usually cause by a failure of the capacitors in the power supply board. What is happening is the power supply is not starting up correctly so the back lights are not coming up to full brightness. Here is a link to a repair guide that will show you how to dis-assemble the unit and repair the power supply board. http://www.ccl-la.com/blog/index.php/repairing-the-samsung-225bw-22-monitor/
If you can do a little soldering then you can do the repair yourself.
Apr 15, 2011 | Samsung 225BW LCD Monitor
My SyncMaster 225BW 22 inch does unpredictable displays when my PC is first started up, or awakes from sleep mode. (display is shifted to the right, or brightness is stuck on very low, etc.). Before, I...
The brightness issues with this model are usually caused by a power supply that is starting to fail. There are parts called capacitors that start to fail, when this happens the power supply can not get to the correct voltage outputs that it needs to properly run the back light bulbs. This type of problem causes either the dim display that you have or a wavy display until the unit can stabilize the output voltage. It is repairable if you can do a little soldering. You will need to replace the 5 capacitors on the power supply board. Here is a link to a repair guide for that unit that shows what needs to be replaced.
This is an easy fix, about 15 minutes once you have the parts.
Feb 04, 2011 | Samsung 225BW LCD Monitor
Blank lcd screen when turned on . Wonder if backlight problem
A blank screen is usually caused by the power supply not giving the right voltages to the back light inverter, the bulbs last a lot longer than the power supply board. If you can do a little soldering then you should be able to do the repair yourself. Here is a link to a repair guide that shows how to dis-assemble the unit and get to the power supply board. There are 5 capacitors that will need to be changed and in most cases this will fix the type of issues you are having with this monitor.
I hope this helps, if so please rate my solution.
BuddyMc
Dec 22, 2010 | Samsung 225BW LCD Monitor
Monitor is ghosting, white trails.
You might want to try detaching the monitor and trying it on another computer unit to see if the problem still exists.  If it only occurs on your unit, then try updating the drivers on your system and see if that solves it.
Jun 30, 2010 | Samsung 225BW Monitor
Syncmaster 913v not optimum mode
I just resolved this problem for my SyncMaster 913N.
It seems to be a known issue, however it can take quite some time for the problem to occur. In my case about 3,5 years, so well out of warranty.
Short term solution: unplug your monitor from power. The switch on the front is not good enough. Pull the plug and leave it for an hour or so (all night if you can). Good chance the monitor will work next time you power it up.
The problem will is likely to come back..
Permant fix requires some basic soldering as per this video:
I just managed it and it has been ages since I soldered a resistor so you may very well be able to do it. I spent $25 on tool and part and saved me from buying a new monitor.
Mar 20, 2010 | Samsung SyncMaster 913N 19" LCD Monitor
Samsung syncmaster 225bw 22'' when turned on has a white screen after about3 min i sut it off in the back of the screen for about a min it came back on like nothing was wrong. what is the problem.
This is a symptom indicating the power supply is about to fail. We have a step by step repair guide posted on our web site at: www.ccl-la.com Th repair will require replacing 5 small parts that will need to be soldered on the board. If you don't want to do the repair yourself we do offer a repair service for this model for $30 plus return shipping. If you have any questions contact us at: tech@ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 08, 2010 | Samsung 225BW LCD Monitor
Prior to this past week my Samsung SyncMaster 225BW monitor's display came on almost instantly when turned on. Now it takes at least 30 seconds to reach full brightness. What is the most likely cause ...
kmzwolski, NO, NO, NO!!!! Do NOT wait. Use your warranty NOW!!! Do not let them off the hook. Could be any of the things you mentioned, plus "cold", intermittant solder joint, thermally/vibration fracture of solder joint on printed circuit board (SMPS/inverter circuit) Let me know how you fair with SAMSUNG. lmistyrel on aim.com or 12fixlouie on fixya.
Dec 16, 2009 | Samsung Computers & Internet
Hi, i have Samsung SyncMaster 225BW monitor and while using Microsoft word it stop working. On off button blinking with blue light.. However when i plug/unplug the video cable nothing happens. Regards...
There r problem with your CPU not from Monitor might be any hardware failure at that moment.Pls restart the system after that if display is coming or not if display is not coming might be RAM chip is faulty replace it with goods one.If display still not coming then problem with your Motherboard.pls get it repair by vendor.
Nov 17, 2009 | Samsung SyncMaster 203B LCD Monitor
Open Questions:
See all Samsung 226BW Monitor Questions
Samsung 226BW Monitor Logo
126 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
