Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Where do i buy the bulb - Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
    Scholar:
  • 130 Answers
The best place to buy the lamp is Discount-Merchant.com!
They usually have sales going on, and you'll get the OEM for your TV which is made by Philips Lighting of North America. If you have the original lamp in your TV it's made by Philips... a P22h if you've got an LCD projection.
These lamps should last 2-3 years at minimum.
Always buy from authorized distributors and buy original OEM parts whenever possible.
Posted on Feb 05, 2010
Hear a pop like a firecracker and then no picture
It is likely that the bulb has failed. The bulb can be removed as an assembly from the rear of the unit. Carefully inspect the lamp and confirm that the glass bulb has failed. the pop could be the bulb fracturing. Careful for broken glass. Suggest that you buy a direct manufacturing equivalent. I have found they are the brightest.
26120369-qhrtjxzbaepf4lgqc41ptsvr-3-0.jpg You can buy just the bulb or the whole lamp assembly as pictured above. I recommend buying the assembly
\The link is from the owners manual providing the instructions to replace lamp.
http://www.manuals365.com/swf/mitsubishi/638-c10_bib.html?page=28#manual
Hope this has helped?
Mar 06, 2016 | Mitsubishi WD60638 60" inch 3D Ready DLP...
Mitsubishi dlp tv won't turn on
My family's house once had a older model Mitsubishi DLP TV that went out (which I found out they are famous for). The problem was the projector bulb had died. Your problem is either that or a ballast problem (something more complicated that I do not know how to solve).
Open up the bulb housing on the back of your TV and check to see the condition of your current bulb. NOTE: the bulb housing contains mercury so handle with care. Also, if the bulb is broken/dead, there might be shattered glass sitting inside the bulb housing.
The only way to fix it was to buy a new bulb (search amazon for wd-65837 lamp" you will find a few results). This temporarily fixed our problem. However, for some reason, the aftermarket bulbs do not last anywhere near as long as the original one. So if you do end up buying a replacement bulb, buy something with a good warranty. If this doesn't work just send the bulb back.
Hope this helps!
Nov 10, 2012 | Televison & Video
I want to change the dash board light bulb in my cars but cant find out how to do it or whas bulbs to buy
the bulbs are led and are built into the dash gauge cluster, non replaceable i believe, best bet call dealer and ask for bulbs
Jun 08, 2012 | Cars & Trucks
Trying to change upper light bulb in fridge
Make sure you unplug fridge from wall power socket,remove bulb cover if one is fitted.Carefully twist or gently try to unscrew bulb. If successful take bulb to electrical parts shop and buy a new one.You may of course use your Fridge until you buy a new lamp,Refitting is simply the reverse of removing bulb.Good Luck!
Nov 23, 2011 | Refrigerators
Bulb replacement
Ok, you can buy the bulb separately and it will save you money. I will have to warn that , installing this bare bulb will be tricky and you can not touch this bulb with your bare hands. it will damage it. Other than that, it is possible to purchase the bare bulb alone. i will post a link to your replacement bulb without the housing below.
CLICK HERE FOR YOUR BARE BULB WITHOUT HOUSING.
Please rate and have a great weekend:)
May 16, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
How to replase turn sign bulb in side mirror.
Find out how to open it up, then take out bulb and buy replacement at Auto Good stores like Kragen which might tell you how to do it.
Nov 06, 2008 | 2004 Acura TSX
Zenith replacement bulb
I would suggest to remove the lamp from your TV and check it. You can also just buy the lamp without the other hardware.
This site seems to have good prices.
Let me know if you need any more assistance.
Mar 26, 2008 | Zenith E44W46LCD 44" Rear Projection...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
