Question about Pentair Challenger 3/4 Hp In Ground Pool Pump
I am trying to fill the pot strainer with water so I can start the pool pump
  • 106 Answers
If the pot is higher than the pool, it will never fill to the top. Just fill it to the inlet level and it should be enough.
Posted on Feb 05, 2010
Closed and opened shut off valve to strainer housing basket, no water in strainer, how do you know if shut off knob actually opened or just broke the knob?
if the basket fills with water once you open the strainer lid then the valve is opening properly. If you open the valve and the strainer lid but you see no water flowing in then you can believe that the valve is not opening and needs to be fixed or replaced.
May 20, 2015 | Hayward Pool Products Hayward Power Flo LX...
How do I get water in the strainer housing basket?
guess you need to add some water they do not self fill usually .
How do you prime it?
Hi Tom:
Priming is essentially the action of getting the air out so that the pump can push water. Sometimes there is a plug at the top of the pump. If you remove it, either air and then water will come out, or nothing comes out and you can see no water inside. Fill it with water, put the plug back in, and it should work. If the pump is higher than the water level in the pool you will have a bigger task.
We'll cross that bridge if we need to.
Apr 09, 2015 | Pool & Spa
Diamond pump model 560549...will not draw water out...checked for air leaks an replaced inline see fill strainer? Back pressure ??
Is it running backwards? Check with inlet line open and see if there is any suction there. Is gasket on strainer good and sealing completely. Start of with some water in the strainer to prime and to avoid seal damge by running dry.
Dec 11, 2014 | Pool & Spa
Why is the pump pulling water but blowing air as well as water in the pool?
look for small crack in strainer housing or missing o-ring on cover , i use a eye dropper of blue dye on outside !! of strainer housing , a quick look at pool return and you'll see where the crack is , dry out housing 1st but superglue has saved many a cracked strainer from replacemnet
May 08, 2014 | Pentair "Pentair" In Ground Pool Pump ...
Losing pressure after about 15 mins pool pump stars really well but then seems to lose pressureleaf catcher before pemp seems to get air in it is this pump or pipes
If the inlet strainer gets air in it, the pump will lose prime. Fill the inlet strainer basket with water, make sure the cover is on air tight. Start the pump and watch the inlet strainer, the amount of air trapped should not increase, if it does, you have a leak somewhere on the piping between the pool and the pump.
Nov 19, 2010 | Plumbing
I replaced CVA-24 VALVE....now when I turn on pool filter no water being pulled through..no water being pulled through to pump
Your pump has probably lost its prime. This is either because it got too much air or not enough water. Try priming. This should make your pump start working again. Any time pool pumps have to be services, they need to be re-primed. In case you are not sure how, remove the pot lid and fill the pot with water. Re-add and clamp the pot lid. Open the air release valve on the filter and stand clear. Turn on switch or time clock. When water comes out of the air release valve, close the valve. If it is a two speed pump, make sure it is on high speed.
Aug 20, 2010 | Pentair 3hp Whisperflo Pool Pump In -...
We do not know where the air filter valves are
Air filter?
Remove the strainer basket cover ... fill with water ... check the gasket ... replace if questionable ... close the cover and SNUG the top down. Start the pump ... it should run just fine.
If you are sucking air, tighten the strainer basket cover a little.
Still sucking air? You will have to find the air leak. You might plug the leak with plumbers putty.
May 29, 2010 | Jacuzzi Cyget In Ground Pool Pumps
Pentair Challenger 3/4 Hp In Ground Pool Pump Logo
127 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
