Home
My Products
Sign In
Back to:
All Products
Jenn-Air
JED8430 Electric Cooktop
Troubleshooting
Tags
how to adjust
temperature
out of range
replace switch
high temperature
Can't adjust temperature on solid elements
posted by
glenzo
on Feb 21, 2008
Report abuse
cooking range has solid element cartridge on both sides.one side will just stay on high and not be able to adjust temperature.swapped elements and the same side still stays on high. this range was put in in 1989.Model # C228
Solve This!
I have the same problem.
X
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
OK
Solution #1
posted on Jul 02, 2008
Guest
Rank:
Apprentice
Rating:
0%, 0 votes
replace the switch!
Was this solution helpful? Show your Appreciation by rating it:
Inappropriate
Thanks for Trying
Helpful
FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on can't adjust temperature on solid elements:
I don't want to Accept this solution
Done
Suggest a new solution for this problem
Can you Help with these Kitchen Cooktops problems?
Jenn-Air JED8430 Electric Cooktop
Jenn-Air 4340B Cooktop Problem
Only the right front (large) burner operates. The lights...
Answer This...
crack in Jenn-Air stove top
I just found in a two-inch hairline crack curving along...
Answer This...
tripping breaker
electric breaker tripped, attempted to reset and observed...
Answer This...
Spark from burner
I have a gas cook top from Jenn-Air..It is abt. 16 yrs old...
Answer This...
Answer This...
Let Our Experts
Solve
Your Problems
Ask!
Loading problems.
Avior
Guru
Let FixYa Experts
Solve Your Problem
Ask!
Repair Service
Find Kitchen Cooktop Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
Find Parts
Order Jenn-Air Kitchen Cooktops Parts Here
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
No
Yes
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
