Question about Arris DSR922
Continuously resets, test lights, warmup, then channel comes, then breaks up then does reset again. Until I removed Videocipher module.
  • jzdeb Feb 08, 2010
    My question has to do with a Motorola DSR922 continually self resetting. Are you familiar with C band satellite? or 4DTV?
    This unit acts as if you unplugged it from the wall then plugged it back in, Every 5 minutes. I have removed the videocypher module. This seems to have helped.
    JZ
    President:
  • 1,284 Answers
I suspect that your Videocipher module is loading the receiver down and causing it to reset. If the receiver were at fault, it would still reset itself even with the Videocipher module out.
Posted on Mar 04, 2010
  • 5,138 Answers
What is it that you are needing help with you did not post the Model number Brand Name is this a DLP,LCD Plasma What?
Posted on Feb 08, 2010
Clutch cable rubbed a hole in the rear brake line. ABS light still on after repair. How do I reset it?
The ABS light should stay on until you reach a speed of about 3 MPH or higher.
Did you check for error codes?
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting should illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word "diag" should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carbureted)
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC's the code will be displayed or the word "none" will appear if there are no DTC's. Push the odometer reset button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC's are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC's again by repeating steps 1 to 9. If the code is current it will reappear.
9 - Press and release the odometer reset button to continue to the next module.
10 - Turn Ignition switch to OFF.
On models not equipped with a tachometer "No Rsp" will appear when the tachometer identifier is selected.
"No Rsp" will also appear if the run/off switch is in the off position when doing this procedure.
Also if the code set is a historic code (not a constant light) after 50 start and run cycles of at least 30 seconds each in duration, the light will extinguish itself as long as the error hasn't occurred again.
If it were a current code, the light would remain lit while running.
If you clear the error code (step #8), the light SHOULD reset.
Mar 24, 2014 | 2000 Harley Davidson FLHR-FLHRI Road king
Service indicator reset
insert key into key slot and press the start stop button once WITHOUT putting your foot on the break. You should see numerous lights turn on,on the dash
weight for any warning lights to go out, in some cases, like low fuel warning light, you my need to press the BC buttonon the end of the indaca tor stalk once to remove them
press and hold the black button, on the bottom left of the speedometor, but keep holding down the button untial the next picture appers then release the button.
to cycle threw one by one all of the picture optctionsfor each service press black button once. when you arive at the SERVICE that you wish to reset press AND HOLD THE BLACK BUTTON until the text RESET?is visible under the picture then let go,finily press and hold the button again to conferm the reset.
Nov 27, 2013 | Cars & Trucks
Factory reset Bush s642f
You have to enter its service mode option to do this. It is a skilled work. Just check this, and see whether you can do this or not.
Dec 30, 2012 | Bush Televison & Video
My kenmore dishwasher 665.17052400 clean light is flashing 7 times. I cannot locate the tech sheet to find out what is wrong. I have reset the panel and it will run then blink again after 15 mins or so. ...
Reset the Control Panel
A power surge or outage may cause the "Clean" light to flash continuously after power is restored. Pressing the buttons on the panel in order and within 5 seconds resets the control panel and turns off the flashing light. The buttons must be pressed in the following order: "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash." After pressing the buttons, your Kenmore dishwasher will begin a short, 12 minute test cycle and reset the control panel.
Door Switch
A broken door switch can keep a Kenmore dishwasher from operating correctly, resulting in a flashing "Clean" light. Testing the door switch requires removing the door panel to access the control panel holding the switch in place. A continuity tester can determine if the switch has failed once you remove it from the door. Replace the switch if it fails to pass the continuity test. Make sure to disconnect the electricity to the dishwasher before accessing the switch.
I hope this helps.
Jan 10, 2018 | Kenmore Dishwashers
Check engine light keep coming on after repairs
the infomation u were given is 100% wrong! if the light is coming on then a problem exists in the OBD 2 engine control system, there will be a fault code stored for the check engine light, who told u this the dealer??
May 11, 2009 | 1999 Toyota Camry
SHARP 37HV6U No picture until long warmup
Alas, it sounds like something could be quite wrong, or it could be as simple as needing a reset. Unplug the unit, wait a minute then replug it and see what happens.
Aug 28, 2008 | LG 42LC2D 42 in. LCD HDTV
Error soak and scour light comes on wont wash
press and hols start button until it resets then try again.
Feb 20, 2008 | Whirlpool 24 in. GU1500XT - Multiple Color...
Televison & Video Logo
76 people viewed this question
Top Arris Televison & Video Experts
Are you an Arris Televison and Video Expert? Answer questions, earn points and help others
