Question about Whirlpool Duet GHW9150P Front Load Washer
It makes entire house shake when it spins even on the medium setting. How can we solve this issue?
    President:
  • 1,902 Answers
Adjust the feet on the bottom of the machine. It is off balance. If adjusting the feet does not work then you will need to make sure that the drum pulley is not bent if it is then that will need to be replaced.
Posted on Feb 05, 2010
Electric element burns high even on medium setting. Replaced entire element and still having the same problem FRIGIDAIRE STOVE , SN VF23145789 MODEL FFEF3016LWF
Hello Charles, thank you for your submission!
I understand that the element on your Frigidaire range burns high on a medium setting and it has been recently replaced. This could be a possible problem with the wiring harness or switch inside of the range. Since it could be anyone of these underlying issues I would strongly recommend having a professional technician out. This will help you avoid any unnecessary part purchases. Hopefully this information can be helpful towards your repair. -Matt
Feb 25, 2016 | Frigidaire Kitchen Ranges
Piolar Express front pivot hangs and causes derailment
There is a design flaw with the spring loaded pivot. If the wheels canter even the slightest, like on a turn, the mechanism slide locks up. I solved this problem with a medium white lubricant used for fishing reels called lubriplate. Make sure you lube both sides of the slide. Other medium consistency lubes should work just as well.
Dec 08, 2011 | Lionel The Polar Express Train Set
LG front loading washer: recently moved to a new house and laundry room is on the 2nd floor. Re-installed the shipping bolts in the back of the washer that secures the drum prior to moving the washer. But...
Make sure machine is level and all four leveling legs are solidly touching floor at the same time. Make sure leveling leg locking nuts are screwed up to lock legs in place. Check floor for firmness. (try bouncing up and down in front of washer to see if the floor has excessive give.) You may need to re-inforce floor. Wash larger loads. On bulky items, use a lower spin speed. You can re-spin at a higher speed after cycle is complete if you want them spun out better. (some models have a pump and spin only setting, on others, just turn on the power and then only touch the spin speed button to select a 14 minute pump and spin only cycle, then touch the start button.) The only other thing is that the new LG washers use a balance ring now, which makes the machine perform much smoother. (I know because I gave my old LG to my son and replaced it with the newer model, which now runs much quieter, in the exact same location as the old one.)
Jan 13, 2010 | Washing Machines
Shaking washing machine
If the shaking is during the spin cycle and you are using the High setting change it to Medium. This may fix the problem and the clothes will probably come out even dryer since the drum is not banging around.
Sep 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Neptune makes loud drums like sound 5 min before it stops.
its probably because of the way the clothes are in it. you have to make sure the clothes arent leaning to one side and that they are evenly set up. otherwise when it goes into the spin cycle itll lean and hit the side of the washers inside and make it shake and do what you said it was doing.
Jun 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Badly shakes on spin cycle. Smooth on extra high speed only.
That is what these are bad for.... they are very hard to control especially if you are on a second floor or above a basement or something.... thats why i personally dislike them...
Apr 26, 2009 | LG Washing Machines
Shakes during spin cycle
Most out of balance problems are from the clothes in it. Stop it, move the clothes around - kind of even out the load and try again.
Mar 29, 2009 | Washing Machines
Amana NAV8800AWW making noise while running and spining. It used to shake the floor while spining. But lately machine is making noise but not as shaky as it use to be. Thanks for your help.
Spin Shake is usually contributed to a weak floor support condition. Also, carpeting under the leveling legs can cause a "spongey" effect, which can produce the shakes. Prolonged shaking can cause parts to loosen and make noise.Firstly, we must determine what loosened up from all the shaking.
Remove the front panel by removing the 2-5/16" screws located at the bottom front. Pull out at the bottom to release the top retainer clips, and set aside.
Warning! Never reach inside the machine while it is in operation!
Investigate the cause of the noise by setting the washer to spin, and turn on. Inspect all moving parts for possible wear or breakage. Next, stop the machine and inspect for loose or worn suspension parts, nuts, bolts, struts, hoses banging the cabinet, etc. A protective motor cover can cause noise, or a belt slapping the base mount. Once you have conquered your noise issue, then we will have to eliminate the shakes, provided, what you repaired wasn't the cause...and usually isn't.
Carpeting under the leveling legs should be removed or cut away.
If other items in and around the laundry room shake, then you will need to add support to your floor joists. Shim the floor from under the house while the washer is spinning for best results.
Your installation instruction manual should tell how level the washer properly, after you have added support to your floor.
Good Luck! Post me back if can be of more assistance.
Dave E. (Illeagle)
May 20, 2008 | Amana NAV8800E Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
66 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
