Question about Toshiba E-Studio 3511 Color Copier
Toshiba E-Studio 3511 error c360 - Toshiba E-Studio 3511 Color Copier
  • Toshiba Master
  • 643 Answers
C360 indicates Charger cleaner motor abnormality. Make sure the charger unit is installed & engaged to the drive gear. It is a common problem on e3511 model, where the main charger unit will loose.
Posted on Feb 08, 2010
Toshiba e studio 451c error c360
replace your toner sensor or tdk sensor
Feb 13, 2014 | Toshiba E-Studio 3511 Color Copier
Getting error sc 479627 toshiba e studio 3511
479627 is your meter not the error code.
3511 and 4511 color machines will be obsolete at the end of this month. Advise you call your local Toshiba dealer and talk to them about a trade in upgrade.
Jan 13, 2013 | Toshiba E-Studio 3511 Color Copier
Toshiba e studio 3511 F120 error need to know what this error is and how to fix?
F120] Database abnormality
(1) Rebuild the databases. (Perform 08-684.)(2) If the error is not recovered, initialize the HDD. (Key in "2" at 08-690.)
Any money the HDD is duff. Srri
Apr 28, 2011 | Toshiba E-Studio 3511 Color Copier
Toshiba 3511/4511 suddenly stopped faxing
Try use the monitor button for faxing, check whether there is tone or not.
Jul 08, 2010 | Toshiba E-Studio 3511 Color Copier
Toshiba estudio 3511 keeps giving error c360. I've checked the charger and the gears are messed with drive motor. Motor turns initially but gets to stopping point and gives error. Is there a charger...
At our repair shop we have begun to put a small (1/8" or so) washer in between the frame and the bracket the worm gear is attached to when we get this error intermittently. It seems to pull that worm gear closer to the main charge cleaner gear to give it better meshing. Hopefully this helps you!
May 27, 2010 | Toshiba E-Studio 3511 Color Copier
Ca 20 error on toshiba 3511 copier
CA20 indicates H-Sync detection error.
U need to check whether the cable (flexible flat type) between the connector (CN334) on the LGC board and connector (CN201)
on the LDR board open circuited, broken or disconnected. Try to replace another cable.
Jan 05, 2010 | Toshiba E-Studio 3511 Color Copier
F 105
How do u get in service mode on a toshiba 3511
Nov 06, 2009 | Toshiba E-Studio 3511 Color Copier
Toshiba E-Studio 3511 Check Color Toner Cartridge
there is a sensor above the coloer developer unit clean it or change the sensor
Sep 30, 2009 | Toshiba E-Studio 3511 Color Copier
My Toshiba e-studio 3511 gives me a C010 error, what does that mean??
C010 indicates main motor abnormality.
U need to perform output check 03-101(ON)/151(OFF) to off the main motor. If main motor not running under output test, probably u need to replace it.
If motor working, u might need change the LGC board.
Jun 24, 2009 | Toshiba E-Studio 3511 Color Copier
Toshiba E-Studio 3511 Color Copier Logo
1,824 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
