Question about Acer Aspire RC500 PC Desktop
Wont boot Hi I have a RC500 Aspire had numerous problems from the start, mainly faulty CD Drive(cd drive will not open hasn't for 2 years, unable to remove also) faulty power suppy even though most uptdate drivers used the tv/fm mode shows a blank screen and when in PC mode the Aspire tv/fm programmes do not recognised the instaled hardware. Anyway apart from the above it has been working fine. Tried to switch it on this morning light turns fam whirs(very noisy) then nothing no screen no "Beep" just the constant fan noise. Do I have to reset the Motherboard?
  • Sydney2008 Feb 21, 2008
    What i meant was to reset the cmos or whatever it called,
    I took it back numerous times and acer repaired it twice outsode the warranty period.
  • 83 Answers
DO YOU KNOW WHAT A MOTHERBOARD IS?
IT MIGHT BE A PROBLEM WITH THE CPU....TAKE TO A COMPUTER REPAIR SHOP
IF THESE CONDITIONS WERE FROM THE BEGING, WHY DID YOU NOT TAKE IT BACK TO WHERE YOU BOUGHT IT FROM, IT MIGHT BE DEFECTIVE....ALL CD DRIVES ARE REMOVABLE.....SOME ARE JUST HARDER....
Posted on Feb 21, 2008
How do i remove the internal CD drive in my Acer Aspire RC500 ?
I assume you are talking about the cd drive into a desktop aspire ...The procedure is to remove the side cover and have access inside teh desktop ..(the left one ) ..after that locate the drive ,.,remove the power source cable and the ide controller...and after that it will have 2 screws on each side (repeat procedure by removing the other cover-right one ) ..and after all 4 screws are removed..the cd drive will slide out ..in forward ..(it is mounted on a slide )
For some desktops it will not be held in place with screws ..but it have a locking mechanism and you need to pull aside or back ...and it will unblock the drive and will slide out toward front side ..
Jul 22, 2011 | Acer Aspire RC500 PC Desktop
This device cannot start. (Code 10)
First, check the boot drives to make sure that the computer is not trying to boot from a different drive to the one that contains Windows.
Check that there are no CDs or DVDs 3 1/2 inch floppy discs
in the CD/DVD,3.1/2 floppydrives.
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Feb 02, 2011 | Teac CD-Rewritable W28E CD-RW Burner
I want to downgrade ACER ASPIRE M5641 desktop form vista to XP. What steps to follow? Also I have only the backup CD which I made right after the purchase , originally installed with VISTA. Understand it...
You'll have to purchase the XP software, set your computer to boot from cd (in the cmos settings), put the disk in the cd and restart you computer. When the screen comes up to "...hit any key to boot from cd" hit any key. The system will boot to the XP cd and will allow you to delete the old partition, reformat your drive, and install XP. Next go to www.acer.com and download your drivers. Finally install your programs and data on to your hard drive. Have fun!
NOTE: Make absolutely sure that you backup the programs and data that you want to keep before starting the XP install!
Aug 14, 2010 | Acer Aspire RC500 PC Desktop
Blue screen
Check booting in other computer, this will show if CD faulty. If not, CD drive may be faulty. If CD not faulty & can boot from USB drive you can copy CD to USB drive and install that way.
Apr 19, 2010 | Acer Aspire M5641 PC Desktop
My sims 2 games wont open. When i put the disk in, it spins and makes the noises that its going to start but never opens. ive checked through "my computer" and the computer is reconising the disk its just...
To verify whether the problem is with your cd drive or with your sims 2 disk, try running a different disk in the drive. If you are successful in opening and running the other disk, then your cd drive is fine and your sims 2 disk is faulty. If you've had the sims 2 disk for a while, it may be scratched.
If the other disk shows the same symptoms, I would suspect that your cd drive is bad and needs to be replaced.
Oct 12, 2009 | Acer Aspire 5735 Notebook
Dvd's & Cd's are not being read
When this happen the problem is usually the CD drive, even if a virus can cause same problem.
To test if the problem is software, go to bios or boot options, set primary bot device CD/DVD, and start the computer with a boot disk inside.When asked chose boot from CD.
If the computer does not see the dvd drive, and does not ask you if to boot from CD on this conditions, then you have a faulty DVD RW drive.
Try first removing the DVD drive and refitting it in place, after removing battery and unplugging the AC adapter cord.
If that does not work, you usually need to replace the driver, even if on rare circumstances a faulty motherboard can cause the same.
That is however quite unusual.
the most common is a faulty optical drive.
May 16, 2009 | Pioneer (DVR-K16) DVD RW Dual Layer Burner
Dell Inspiron-1520 unable to read RW DVD's.
you have a faulty disk inserted in the drive. Restart the computer and continuously press eject while the pc is booting, it should eject then.
Oct 11, 2008 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
How to install windows xp boot cd on acer aspire 4315
When you first start the machine, you need to go into the boot menu and boot from CD drive, or go into bios/utilities set up and set the boot order to boot from CD first. Make sure your XP CD is in the drive, then just follow the prompts.
Jun 20, 2008 | Acer Aspire 4315 Notebook
Acer Aspire 5050 won't boot up
ooh...no operating system. not good. ok..can you boot from CD? if that works, and it asks you to reformat the hard drive, STOP. Take the hard drive out, and then GENTLY reinstall. Maybe that will work. HD's can fail on laptops, just by a series of vibrations or shocks to the case.
got backup for your Acer?
Feb 16, 2008 | HP Pavilion dv6000z Notebook
How do you reset Acer Aspire T180-GB7Z PC
Perform a system recovery:
Does not come with recovery cd's - there is a program that allows you to burn the disks or
recover.
3 ways:
1. If in Windows - Start - Programs - Acer empowering technology - Acer E-recovery management -
click on Restore at bottom then "Restore to factory default settings"
2. Or click on Burn disks instead of restore
3. if unable to ge into Windows then Alt/F10 during boot right after Acer splash screen on startup
End User Technical Support and Service (USA only)
For end user technical support, spare parts and service: 1.800.816.2237
Dec 30, 2007 | Acer Aspire™ T180 PC Desktop
Acer Aspire RC500 PC Desktop Logo
121 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
