Question about Frigidaire ATF6000ES Front Load Washer
Ltf6000 affinity front load washer, can the size of the loads be changed. Can a wash a small load or do I have to fill up machine in order to be water conscious.
the dr
  • 447 Answers
SOURCE: Frigidair affinity front load washer
The water is turned off!!!!!!!!!!!!!!!!!
Posted on Jan 15, 2008
SOURCE: affinity front load washer
my front load washer won't spin water out
Posted on Jan 22, 2008
Coldcut
  • 1554 Answers
SOURCE: Frigidaire Affinity Front Load Washer
You have to remove and clean the rubber around the front of door,
, Snap it back on.
disconnect AC to prevent any accidental shock.
open the bottom access panel
screws on bottom front , open the large filter and be ready for latent water to spill out , have rags ready.
clean the inside of the filter with clorox.
finally run a strong solution of clorox when you finish.
then rinse well.
leave the door open after loads finish
the door has a child lock
black dot next to lock on door , insert coin and rotate.
keeps them from closing the door.
Posted on Feb 14, 2008
  • 240 Answers
SOURCE: accessing the door lock switch
spring clamp around boot (spring at bottom) pop off with screwdriver, pull boot off groove.
Posted on Mar 16, 2009
  • 4 Answers
SOURCE: frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
Posted on May 11, 2009
I have a frigid site affinity front loading tumble action washer. The water comes in but does not fill. Window in front shows no water accumulation. Otherwise it is functioning. The drain hose is 11 inches...
Not sure if this your first front load or not. A front load washer does typically fill up in to the window. Front load machines use a lot less water than a top loading machine.
Aug 14, 2014 | Washing Machines
My frigidaire affinity front load washer ATF6000FS1 wont fill with water
Hello hitman43 - Are the house valves turn on fully? Most common cause is a faulty switch that doesn't allow the value inside turn or a kinked fill hose. Other possibilities can be water valve faults, faulty control board, pressure switch or wiring failure. Contact a professional to move forward accurately.
Jan 01, 2013 | Frigidaire Affinity ATF6000F Front Load...
Frigidaire Affinity Glacier Stackable upright washer. Washer will not agitate and makes a buzzing sound from the pump that extracts water from the drum. Water collects and remains in bottom of washer.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
GE washer wJR4170G1WW wont wash or spin What
changing from large to small load will not cause a problem. this could be a control panel issue. unplug machine, the try rotating load size dial back and forth a few times, plug machine back in and try
Jul 24, 2009 | Washing Machines
Accessing the door lock switch
Mar 16, 2009 | Frigidaire ATF6000ES Front Load Washer
Wont fill
the rug backing is catch in pump...the unit will not fill unit pressure switch is trip,,to the empty position..we need to clear that pump..onthejob
Jan 29, 2009 | Frigidaire ATF6000ES Front Load Washer
My Frigidaire affinity washer doesn't start: the "door locked" button doesn't come on though the door is closed properly
If the washer fills with water, but will not start the wash cycle or spin, it is 1 of to things. the most common for frigidaire front load affinitys is the door lock assembly. I have had to replace numerous of these. if the door lock indicator is not on when it tries to wash, you need to replace the door lock assembly. if the door lock indicator is on, but wont wash, it is likly that you have a bad motor control board.
Dec 01, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Affinity front load washer
Jan 21, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
