Question about Zanussi ZCG7902X Gas Kitchen Range
Display not lighting up therefore oven inop.Can still use rings ok.Model : ZCG 7902X
Nie dziala piekarnik i zegar
Posted on Aug 27, 2010
Westinghouse oven model WFE946SA, purchased only 4 mnths ago. No lights display
main control board,take it back,its expensive,1 year warranty
Jul 26, 2015 | Ovens
Why does the fan mode on the bottom oven on my zanussi Zou575 not working?
Because in Main Oven Cavity (large) around the convection fan is very powerful ring heating element 2500W (not visible) who works in the Fan mode. Therefore, it is not necessary that all heaters work because it will overheat the oven.
Dado
Aug 25, 2014 | Zanussi Ovens
Why won't my microwave oven work?
No, it's not worth the effort required to replace the control module - unless it is a commercial model.
May 25, 2014 | Sharp Microwave Ovens
My oven is not heating up but the fan is working - any ideas?
I dont know your model but generally the problem would be that the ring element around the fan has blown or less likely the thermostat has failed.Normally if you can see the light on the control for the oven temperature control light up and can hear a click from it as you turn up or down the the thermostat should be ok.You will have to get the ring element out and check with a multi-meter if it is blown and replace.
Hope this helps.
May 20, 2010 | Ovens
Vulcan convection oven model SG4d-1 will not ignite burners
Gas does not ignite. No spark. No Ignition light is not ON.
1. Shorted electrode on igniter/flame sense.
2. Igniter cable (high voltage) OPEN.
3. Heat relay malfunction.
4. Centrifugal switch in blower motor inoperative.
5. Transformer inoperative.
6. High limit thermostat open.
7. Interconnecting wiring malfunction.
8. Ignition module malfunction.
Sparks but gas does not ignite.
1. Gas solenoid valve off or inoperative.
2. Manual gas valve closed.
3. Gas supply OFF or insufficient gas pressure.
4. Inerconnecting wiring malfunction.
5. Igniton module malfunction.
Feb 23, 2010 | Vulcan Convection Oven - VC44EC-208-1
Inoperative oven electric elements
It could be contact problems where elements are pushed into in oven. Elements are usually plugged into heavy copper lugs at the end of both element ends. should look at manual for this unit to see how to remove and check for blackened ends. {Make sure to unplug before any work}
Nov 28, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
Most of the LED display is inop
Give me the complete model # from the sticker inside the microwave so I can look into this for you.
Nov 15, 2007 | Jenn-Air M439 Microwave Oven
Zanussi ZCG7902X Gas Kitchen Range Logo
48 people viewed this question
Top Zanussi Kitchen Ranges Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Zanussi Kitchen Range Expert? Answer questions, earn points and help others
