Question about Whirlpool Washing Machines
How to access control panel on top load whirlpool washer (model LSR8444LQ0)
duby1990
  • 370 Answers
SOURCE: control panel locked on my whirlpool duet washer
Hold the end of cycle signal for 3- 5 seconds.
Posted on Dec 11, 2008
  • 130 Answers
SOURCE: TOP LOAD WHIRLPOOL WASHER MODEL#LLR6233AWO
Check the agitator dogs, and the motor coupling
Posted on Jan 26, 2009
jsrock516
  • 5911 Answers
SOURCE: How do I access the inside of my washer?
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Now...a washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
Take note of your symptoms:
1. Washer fills, may or may not agitate, will not advance to the rinse cycle, and will NOT drain - lid switch.
2. Washer fills, does NOT agitate or spin, but WILL drain - motor coupling.
If you still have questions, please let me know. I hope this information is helpful to you.
Posted on Jul 03, 2009
  • 180 Answers
SOURCE: Whirlpool Cabrio top loading washer F1 Error
F1 means the control board is shot. Call whirlpool and they should take care of the parts and labor even though your machine is out of warranty.
Posted on Nov 27, 2009
SOURCE: Help with Model #GHW9400SU0 Whirlpool Duet Front Load Washer
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED status light turns off.
Posted on May 17, 2010
How do I install the control board part # W10180782 in a whirlpool washer
Since you did not mention the model number to your washer or whether it is a top or side load washer, I have attached a youtube video for you to watch to get the general idea of how to gain access to the control board on top-loader whirlpool washers; although it is not specific to the part number you are replacing. Repair clinic offers self-help videos on side load washers as well in case yours is a side loader.I hope this helps.
Feb 20, 2015 | Whirlpool Washing Machines
How do I remove the control panel on Kenmore washer 110.27642600
Hello, welcome to FixYa.
I understand you have a Kenmore washer model #11027642600 you'd like to access the control panel, correct ? The info you'll find below is for changing the lid switch, but it will also guide you in how to open the control panel...hopefully it helps.
http://www.youtube.com/user/RepairClinic#p/search/0/MFsvLiuTniU
( this is based on the most common Whirlpool, Estate, Kitchen-Aid, Roper, Kenmore, Inglis top-load washer, not necessarily applicable to ALL...skip to 0:52 of the video for your model)
If this is something you think is not within' your scope of expertise please call a pro. I think you'll be fine with the tutorial video.
Good luck.
Thank you for choosing FixYa. Please take a moment to rate the info I provided and a short testimony is appreciated.
Regards,
Macmarkus :)
Oct 12, 2011 | Kenmore 24032\24036 Top Load Washer
How to access top control panel on model wtw58esvw0 washer
This video will show you to open the console(and remove cabinet)
Aug 14, 2011 | Whirlpool WTW5850S Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer were is the drain filter
Hi.
With Whirlpool top loader models the pump is located at the bottom of the appliance. The pump is accessed from underneath the appliance. Some model may have an access panel at the back. I think that with the Ultimate Care models the pump must be accessed from underneath. Here a repair video.
Here parts and diagrams.
Aug 07, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Timer/control knob on front panel has come loose from the inside, Any help on opening panel and reattaching unit to the panel
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Next, see the following for how to release the console:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=fcfcd31a8e8aeeccda85d0c7abd587ba
NOTE:
Some Kenmore washers don't have removable end caps with screws underneath. These models usually have a spring clip mounted under where the end caps would be. In that case, use a thin putty knife to slip under the ends of the console to release the clips.
Also see the following Whirlpool / Kenmore Service manual for top load, direct drive washers. It details the two types of timers and how to access them.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Jul 29, 2010 | Kenmore 24622 Top Load Washer
My Whirlpool LSR8444LQ0 will not spin. It fills up with water, washes but will not spin
Probably a broken lid switch.9530b79.jpg You can bypass the lidswitch for testing purposes to see if that is the problem. Their are 3 wires.c5cb942.gif A green ground wire and 2 live wies. Jump them to see if that washer will run. Check out this nifty video:
MANUAL AND MORE HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 22, 2010 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool top load washer won't wash after filling
The hinge on the left side activates the lid switch. The hinge will have to be repaired or replaced.
Use a putty knife or a old CD to slide under the control panel on the right and left sides,where the control panel front meets the washer top.
This will release the clips that hold the control panel to the top cabinet.
Fold the cabinet to the rear.
Unplug the lid switch in the top of the cabinet on the left side.
Remove the brass clips holding the cabinet to the rear panel.
The cabinet will come off so that you can access the underside for the hinge and lid switch.
Jan 07, 2010 | Whirlpool Washing Machines
Lid activator switch is broken. How do I remove the top of the machine to access this. prying up at the corners doesn't work, I can see little screws in there, but would be difficult to access...
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Look in the component section for cabinet and/or control panel.
Following is a description of how to remove the cabinet on Kenmore / Whirlpool top load, direct drive washers.
ILLUSTRATED DESCRIPTION OF REMOVING CABINET THRU TRANSMISSION.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Oct 04, 2009 | Kenmore 22422 Top Load Washer
Washing Machines Logo
42 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
