Question about LG Televison & Video
Vhs tape ejects when pressing record - LG Televison & Video
    President:
  • 1,768 Answers
1. Rejected tapes on a VHS recorder is due to a dry belt that is the transfer belt on ejection tray is worn and needs replacement.
2. Because VHS recorder are now not so prevalent and there are so few repair shops specializing in there repair due to parts acquirement it may be best to get a new recorder.
3. Addressing the belts. The belts usually grips a pulley which in turn turns a gear that moves the ejection tray forwards/backwards when given a certain signal on from the control board. This could also be a worn gear from constant use of the load/ reloading of VHS tapes.
I hope this helps.
Posted on Feb 05, 2010
  • LG Master
  • 506 Answers
Tape ejection when record is pressed can indicate one or more of the following:
a) the erasure prevention tab on the cassette has been broken out - cover this with adhesive tape and try to record again or use another tape;
b) mode switch - it is probably dirty and/or corroded - should be replaced if corroded, but can be cleaned with commercially available electronic cleaners if dirty;
c) a logic fault to the record safety sensor on the board, but this is rare.
Replacement of the mode switch is the most reliable course of action - cleaning and lubricating it may help, but it won't last.
Make sure if you do replace this device, that it is correctly positioned/aligned to the mechanism (full eject mode with the guides retracted away from the head cylinder is best starting point).
Posted on Feb 15, 2011
2 Suggested Answers
jmgldsmth
  • 1906 Answers
SOURCE: Panasonic VHS Won't eject Tape
unplug then remove the top cover press down on the cassette release and remove the tape then rewind the part of the tape still sticking out by hand push in the button on the side of the cassette to open the cassette cover
Posted on May 21, 2009
I have a philips DVDR3510V ( DVD/VHS Recorder) which is 16 months old. The problem is that the buttons on the recorder do not work ( except power button) . We thought we had got round this as the remote...
I can only speak to getting the tape out. If all else fails, you can take the player to your local best buy and have them remove the tape for a minimal fee of no more than 30$.
Jul 18, 2011 | Philips MWD2205 DVD Player/VCR
Zenith xbv713 won't record on vhs tape
is the tab on the cassette in place? if it has been removed the cassette will eject automatically when pressing the record button.
Jan 05, 2009 | Zenith XBV713
My Sony SLV-N750 recorder works perfectly - except..
If the door is not connected to a "tape in" interlock
Jul 22, 2017 | Sony SLV-N750 VHS/S-VHS playback VCR
Magnavox TV: Somehow the record button on the remote will not record VCR. It ejects the tape and does not record. Please help. Thank you.
Try Using a new VHS tape. If the new tape ejects when press recording, the recording switch inside your VCR could be defective.
Let me know if you require further assistance.
Aug 26, 2008 | Televison & Video
Lg v181 combo problem with vcr keeps ejecting tapes when I want to record.
The tape load carriage is defective or there is something in the way inside the machine....accordianman
Feb 21, 2008 | LG V181 DVD Player/VCR
Cassette
Most VCR's will auto-rewind the tape when it gets to the end of a tape. Most will leave the tape in the unit assuming you may wish to view it again once rewound. Does the tape eject properly when you press the eject button? What does the manula say about the eject function?
- Jim
Jan 23, 2008 | Philips VR550 VHS VCR
Recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Jan 20, 2008 | Televison & Video
Tapes not playing
Hey do the tapes play at all? sometimes some tapes recorded
on other machines won't play on others. maybe you need to adjust the tracking on the VCR you are playing it on. If the tape
was recorded on a VCR that is misaligned it might not play back
on another VCR. Also the tape may have been recorded on a
super VHS VCR in et (extended definition) mode if so they won't play on just any VCR. If the picture looks scrambled like a
premium channel on analog cable then it's probably recorded in et.
and if its recorded on super VHS tape it may eject out of your VCR.
They don't make these S-VHS vcrs anymore but people still
have them around. There is also Digital VHS they're not
compatible with VHS either. A VHS recorded in et mode will
play on some more expensive vcrs it should say so on the box
or instructions.
Nov 14, 2007 | RCA VR634HF VHS VCR
I need to record a show
You have to make sure the channel on the vcr is set to 04 and the channel on your tv is set to 03. That's how mine works.
Nov 10, 2007 | Sansui VHF6010 VHS VCR
VHS player stops
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
Aug 22, 2007 | Zenith DVR413 DVD Recorder/VCR
Televison & Video Logo
192 people viewed this question
Computer Repairing
Computer Repairing
