Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
Trying to plug in my xbox and can get sound but no picture
Trying to plug in my xbox and can get sound but only scrambled picture, tryed all inputs.
    Scholar:
  • 130 Answers
Is this the first time you've tried plugging in your Xbox?
Is it Xbox or Xbox 360?
Try plugging it into another TV yet?
I've had a similar problem where I've manually set the resolution of my television on my Xbox. I had it set up for 1080p and then plugged it into my little CRT. The picture was all scrambled and I couldn't do anything. I had to plug it into another TV to fix it. This is the original Xbox by the way.
Check the settings on the Xbox, and if that doesn't work, try swapping out the cables or put it on another TV.
Posted on Feb 05, 2010
6MTH OLD HOTPOINT PLASMA TV SUDDENLY HAS NO PICTURE NO SOUND
Hiya!
Sounds like it's on the wrong input, maybe it's analog tuner. Have you tried changing it's input?
Feb 21, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Can't use front panel input and back panle video input has grey picture and no sound
have you tried to remove power from either or both units for a while?
Nov 05, 2012 | JVC AV-20220 TV
Trying to hook up xbox 360
You should have 3 wires. 1 is for video and the other 2 are for the audio. The wires should have them labeled. Once plugged into tv. You will need to change the input until you see xbox game. New tv's have multiple input channels. So u may have to try different inputs. Also you need to make sure the the wires are in grouped inputs on the back of the tv. Let me know if u have any questions.
Dec 23, 2011 | Televison & Video
I'm connected to a dish network receiver and the picture was good until my son tried to plug in his playstation 2. Now everything is back to the way it was originally installed except there is a scrambled...
Hey there. You want to make sure that the cables are tight on the back of the receiver and also that the tv is on the correct channel or input. Sometimes, if the tv is on the wrong input, you can get the picture, but it will look scrambled. So if you are in the room with the receiver box, you want to make sure that the tv is on channel 3 or 4, and sometimes on an input like Video 1 or 2. If on the secondary tv, you will want to make sure that the tv is on channel 60 or 73. I hope that this helps. You can follow this link below if you need more clarification.
http://www.dishnetwork.com/SupportSection/bbs-screen
Becki Barned
DISH Network Customer Service
Nov 16, 2010 | Insignia IS-LCDTV32 32 in. Television
TV has no picture, but sound works fine
Are you using the AV input for the XBox or other cable? If you use AV, then use the same input that the Xbox does not show picture, plug in a DVD and see if it works. If it does not have a picture, so 100% your TV has problem.
Aug 11, 2009 | Sony Televison & Video
My xbox shows no picture but has sound
This might not help everybody but it might be a cheap fast solution to the "Xbox 360 no picture but sound ok" problem. I have old refurbished 360 that has had no problems at all. SInce I got it have used it with powerwave cooler attached to the back. This cooler has seperate Outputs for Vga, SVga, audio, component and av. Don't need the microsoft cable at all just standard cables. Always had it plugged in with VGA or SVGA cables and got great picture. I bought new 360 and put the old one in bedroom with old tv which only has av inputs. Got shocking picture that was unwatchable but sound was good. Tried all ways but no different. Seems the xbox plug has problems. If you get the powerwave cooler it splits the xbox output socket in to seperate outputs for everything so you can use it with Vga or Svga cables if your tv has those inputs and it should work fine. Only seems to be the standard AV outputs that have problems. Haven't tried the componet leads but I guess they might work as well. If you only have the old yellow, red and white AV inputs on your tv this wont help you but if you have the other types of inputs it might fix it. The powerwave cooler you should be able to buy for under $20 so it could be a cheap solution for this problem everyone seems to be getting lately. It works for me at least so get one and give it a try.
Jun 16, 2009 | Microsoft Xbox 360 Console
Connecting hd cable box to philips 60 rear projection
So, You have Five cable leads, The rgb get plugged into there corresponding colors and the other two are your Red and White Audio Input ------Correct? You do not use the in4, that is for a pc with horiz and vert sync. You use input 1 rgb and plug the red and white into the audio input.....your done!
Jun 06, 2009 | Philips 60PW9363 60" Rear Projection...
Can't get XBOX 360 to have audio through surround sound speaker
Make sure that you have the RC Cables (red and white) plugged into the audio ports that coincides with the component video inputs. If that wont work then try plugging the audio and video cables into the inputs for the satellite, since that works. That way you can isolate the issue. If it still wont work try using the XBOX 360 HDMI cable. That has both audio and video.
Jan 03, 2009 | Sony BRAVIA DAV-HDX267W Theater System...
No HD 1080i
have you got the slider switch at high definition and not TV at the connecting end at the xbox that leads to the tv input
May 21, 2007 | Mitsubishi WS-73411 73" Rear Projection...
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
194 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
