Question about KitchenAid Kitchen Ranges
Oven cleaning mode quit in middle of cycle. unit
Kitchenaid slide-in gas range almost 5 year old. oven cleaning mode quit in middle of cycle. unit is getting power. panel no longer lit and door remains locked.
  • 254 Answers
Prob blew the high limit thermostat in the rear of the unit, pull unit out remove back panel and check that thermostat for continutiy with a meter.. hope this helps
Posted on Feb 06, 2010
Kitchen Aid KGRA806PSS
hmmm....that interlock is dependent on a temperature sensor, to ensure that no one opens that door when it's too hot inside. I'm assuming that it's still locked, even after the temperature has dropped off?
Feb 26, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Whirlpool RS385PXBQ0 slide in range/oven won't work after self-cleaning cycle.
Check the wiring on the door lock. If that looks good you need to replace the door lock but that part is no longer available.
Oct 22, 2013 | Kitchen Ranges
I have a kitcheaid gas range. just used the quick, self-cleaning cycle/2 hrs. 30 mins./went out came back no display and door will not open/
The temperature cut-out thermostat at the back of the oven has failed. You will need to pull the oven out and remove the back panel. Thermostat should be at the top in the middle. Once replaced oven will be back to normal.
Feb 26, 2011 | KitchenAid KGSA906PSS Gas Kitchen Range
We put this unit on self clean and now it wont turn on nor open.
I had the same problem with a Superba wall oven. In my case, the bracket mount for the door lock warped due to the heat of the self clean cycle. We were able to open the door by inserting a coat hanger into the slight opening at the top of the door and sliding the lock lever to the left. It was a pretty easy self-repair - 1) turn off breaker 2) slide oven out 2-3" 3) remove oven front trim pieces 4) remove screws that mount control panel 5) this should give you access to the door lock mechanism.
good luck
Feb 01, 2010 | KitchenAid Ovens
Kitchenaid Range KGRA806PSS Control Panel Not Functioning
You're right about not using the self clean option. Your oven gets up to over 800 degrees when you use that feature. You can choose to simply keep your oven wiped out, rather than self clean it. The timer is most likely going out if the "stop" button doesn't work after cleaning. Please call or email us and we will be sure toget the right part for you. I hope this solves your problem. Ella
Sep 09, 2009 | KitchenAid KGSI901PBS Gas Kitchen Range
My Electric Frigidaire Convection Oven just locked it's own door! I heard a continual beep..then "Err" "F9" flashed, then beeping stopped and the illuminated "padlock" symbol lit up and the door locked...
I have a similar problem with my electric Frigidaire convection oven, which flashes ERR F9 and beeps after finishing a cleaning cycle; if you haven't had to have it repaired professionally by now you might try cutting the circuit breaker to the oven for a few seconds and then turning it back on. My oven takes a few minutes to reset, after the circuit is turned back on, but then will unlock the door and let me reset the clock and continue cooking as normal. . . until the next time I set the clean cycle.
FW
Seattle WA
Dec 15, 2008 | Frigidaire 30" Self-Cleaning Slide-In...
Oven glass shatter on kgst307gwh0
You would need to contact Kitchenaid about any possible product issues
Mar 05, 2017 | KitchenAid KGST300 Gas Kitchen Range
KGRA806PSS00 oven dead after self cleaning
heres the part number for the saftey thermostat 8300802
Mar 24, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Self Cleaning ShutDOWN HELP
i had the same problem... the thermal circuit in the back had blown,,little rond thing the size of a quarter with two black wires plugged into it. had trouble getting the door open though,,good luck
Aug 17, 2007 | KitchenAid KGSA906PSS Gas Kitchen Range
Open Questions:
Kitchen Ranges Logo
121 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
