Question about Microwave Ovens
My Touch pad does not work, can someone help? kenmore mocrowave model 721.62624200 microwave buttons work sporatically. if i push in a downward motion they work sometimes microwave blew a fuse a couple of weeks ago and replaced. all function buttons work but numbers are hit and miss' please help
  • rednblack7 Jan 06, 2009
    On our LG 2.0 touch pad, the 0 & 1 won't work alone.  If you push 30 or 21, they work!  What do we do?
The vent under the micowave to pull the moisture in doesn't seem to be working i can feel the blower on the top blowing really good. when i boiling a pot of water my micowave gets all wet due to the moisture.. Anyone help please
Posted on Dec 17, 2013
  • 2,130 Answers
It sounds like the keypad is worn out. The fact that you can get them to work sometimes by what direction you push on them, tells me that the contacts are not working correctly.
Did you have this problem prior to the fuse blowing or did it start after you replaced the fuse?
I don't believe the fuse blowing is related to the keypad problem. I also don't believe that you have a microprocessor problem because you say that the function buttons work but the number keys don't work right. If the microprocessor was faulty, it would not be able to read any of the keys.
The fact that the number keys are not working doesn't surprise me. When you go to cook something, you will press the number keys several times, while only pressing start or stop once. This is why your number keys have worn out first. These keys have a limited number of cycles (presses) and it sounds like its time for a new keypad.
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
Posted on Feb 21, 2008
Kenmore Elite Microwave Model No: 79080373310 giving E-11 error code
I do not know what an E-11 code is on that unit. But the fact you say no buttons are working gives me a clue that you may have a bad touch panel. Could be a Goofed up Microprocessor on the board. A Lot of units will give a code for a bad pad. If an air pocket in a pad colapses, the microwave thinks you are pushing and holding down a pad, so it will give a error code. An E-11 code may mean a bad touch panel on your unit. Try to unplug the unit, give it a minute and plug it back in, try to set the clock first and see what it does. When setting the clock try all of the number pads and see if they all respond. If one doesnt that mey be your bad pad. Or if a number comes up on its ownwithout pushing it, that pad could be shorted.
Aug 18, 2017 | Kenmore Microwave Ovens
The kitchen timer button does not work on my Kenmore circular wave microwave.
If it has membrane switches, you might have a bad switch. Or, you could have a bad connection between the touch panel and the circuit board. Or the circuit board itself could have a problem.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Jul 25, 2016 | Kenmore Microwave Ovens
WHY WOULD THE "START" BUTTON NOT RE RESPOND WHEN EVERYTHING ELSE WORKS
Either you have a bad door switch (and the microwave thinks the door is still open), or else you have a bad touch-pad (keyboard).
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Jun 25, 2014 | Kenmore Microwave Ovens
Why will my Kenmore model 401.85053010 mocrowave door will not latch?
Check the door latches that stick out from the door. Push them up. Is there any resistance? If not, then the spring that pulls them downward either broke or came of its catches. You will need to call a repairman who will have to take the door apart and either replace or re-fasten that spring.
Jun 11, 2014 | Kenmore Microwave Ovens
Work light and fan stopped working
sounds as if your touch pad ,and,or the circut boaed it's connected to is going bad.
Nov 08, 2013 | Kenmore Microwave Ovens
Kenmore microwave model 721.80039700. microwave starts beeping on its own. Display screen displays 1 then 2 then 3 then 4 over a short period of time. key pad hs stopped working. cannot start of turn...
SOUNDS LIKE A BAD TOUCH PAD THINKING YOUR PRESSING EITHER THE 1-3 PADS, IT WONT TAKE OTHER PROGRAMING CAUSE IT THINKS YOUR PRESSING THE 1-3 PADS. REPLACE TOUCH PAD
Feb 26, 2018 | Microwave Ovens
My Kenmore Elite model 66463 has the following buttons that stopped working....1-7, soft, melt, bread defrost, express defrost, frozen entree, frozen vegatables. All other buttons and microwave heating...
Sounds like a bad touch panel. They run silver oxide traces through that panel and they couple a lot of them together. So if a trace common to those pads breaks you lose all the pads connected to that line So Probably need to get price and availability on a new touch panel.
Aug 12, 2017 | Kenmore 66463 Stainless Steel 1200 Watts...
Kenmore over the range microwave 721.67600 will not cook
One of two thing happened here...
1. most likely...One of the interlock switches has malfunctioned. Micro. will NOT opperate unless ALL switches are working properly for safety
2. possible...the start button on the touch pad has failed in the circuit.
Feb 23, 2009 | Kenmore 62702 Microwave Oven
Microwave Ovens Logo
479 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
