Question about Jenn-Air JES8750 Electric Kitchen Range
My elderly parents purchased a range 2 years ago and appear to have misplaced the manual. They are unable to get the oven delay timer to work and manny more of the range features. I am unable to locate the model number, however, it looks very similar to the model above. Can you please advise how to locate a user manual. Thank you!
  • 146 Answers
SOURCE: oven panel
First try unplugging or turning off the breaker and see what happens. If that fixes it your good to go if not you probably need a control board. Some of the boards have a fuse but no one changes it as it is soldered onto the control board.
Posted on Dec 21, 2007
  • 25 Answers
SOURCE: kitchen range random chatter noise
could be clock motor or fan motor keeps running.
Posted on Feb 12, 2009
jumptrout51
  • 3361 Answers
SOURCE: we have a twenty year old electirc jenn-air range
The problem may well be a loose NEUTRAL wire to the range. At the wire terminal on the range check for power from each supply leg(L1 to N) and (L2 to N) to neutral(should read 120 volts) and across each power leg (L1 to L2) should read 220 volts.
If you in fact have 220 volts into the range with good neutral contact the problem is a bad neutral(ground) in the wiring harness inside the range.
Posted on Sep 29, 2009
  • 254 Answers
SOURCE: My Jenn Air model number is worn off and I need it
if u need just an electric burner 6" or 8" u could buy a whirlpool element it would work just fine take the part to a local parts place or if none available u could order like a mp15ya or a mp21ya or something similiar,, go to repairclinic.com and type those two part numbers in to see a picture .. then shopa round hope this helps
Posted on Jan 28, 2010
  • 19 Answers
SOURCE: Jenn-Air Electric range clock display
The problem is likely bad capacitors on the clock module. I had the same problem on a similar oven and fixed it by replacing the capacitors on the clock module. Find someone who is good with electronics to help you. The parts will be a few dollars at most. See this link for more info: http://www.badcaps.net/forum/showthread.php?t=7902
Posted on Feb 04, 2010
30 yer old caloric stove wher light pilot
http://www.partselect.com/Caloric-Stove-Parts.htm
Jan 04, 2014 | Kitchen Ranges
Maytag microwave cook delay - first minute on timer no heating, then works fine
Not a feature I've heard of.
I would do a hard reset by unplugging the oven for a minute or two, setting the clock, then trying again.
If it still does this, I would contact Maytag customer service at the number in the owner's manual.
Dec 25, 2012 | Maytag MMV6180WS Over the Range Microwaves
Owners Manual appears silent on two questions.
1) Question posted under Jasco GE timers.Timer is otherwise not identified as type, model or brand.Certainly this information shows on product manual.
2) Copy following link to help identify timer and download possible manual:http://waterheatertimer.org/GE-timers-and-manuals.html
3) Upward operational temperature for digital timers usually ranges 120-155 F. So this should not be issue in garage until global warming eliminates all electronic gadgets, batteries, and seriously affects electric transmission lines from power plant.
4) Downward operational temperature for digital timers vary widely by type and model number of timer.Some become unreliable at freezing. Some last 1 month in freezing. Some are rated to zero F. Some rated minus 10-40 F.
5) Smart plan is analog timer instead of digital timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#applianceThis type timer will operate on electric power, and not be affected by temperature fluctuations. However timing is not down-to-the-minute 7-day as with digital timers.Note appliance watt rating before buying timer.
6) Two-outlet plug-in timers are not 2-channel timers or 2 circuit.2-channel timer means that the timer can be programmed for two separate timing programs, with each timer program controlling separate load with separate schedule for each load.
7) Example 2-channel timer: Intermatic 1125 digital timer.Note operating temperature -40F to +155, making this especially hardened timer, with wide range timing applications excluding delay functions, But with 1 year limited warranty as is typical with most timers.
http://waterheatertimer.org/pdf/024_ET1100-sell-sheet.pdf
Dec 05, 2012 | Jasco 15079 SevenDay TwoOutlet Digital...
Electrical panel went blank. Hence can't operate the oven. Stove works fine.
Hi. Interesting. My Figidaire Gallery Professional gas stainless went blank 2 days ago. Model FGF379WECS. So I'm googling...
Your Service Manual is located at (document #2 in link):
http://www.retrevo.com/support/Frigidaire-GLEFM397D-Ranges-manual/id/2367bh351/t/2/
Part Number
316418704
Description :
Clock/Timer, electronic, w/mini oven, ES510
Rick
May 15, 2010 | Frigidaire Gallery GLEFM397DS Electric...
My Kenmore oven won't work there is a PF 5AB error
The PF on your control indicates a power failure and should be removed by pressing the cancel button. The 5ab code indicates the range is in the SABBATH mode.
If a power failure occurs when the SABBATH mode is set, the oven will return to the OFF mode and will turn the power OFF to the oven.
To ENABLE SABBATH mode:
* Open the oven door
* Press STOP/CLEAR
* Press both the HOUR "UP" and "DOWN" arrow pad at the same time - and hold for 5 seconds.
SAB ON will disappear from the display.
To disable SABBATH mode: Repeat the steps above and SAB OFF will appear.
To set the SABBATH mode for use during the SABBATH/Holidays:
* Press BAKE
* Pres TEMP "UP" and "DOWN" Arrow pad to enter a different temperature other than 350 degrees. (Between 170F and 500F)
* Press COOK TIME
* Press HOUR/MIN "up" or "down" arrow to set cook time
* Press DELAY START to set a delayed cook time (optional)
* Press and hold TIMER OFF for 5 seconds
SAB will appear on the display indicating it is ready.
* Press START
* To STOP cooking - press STOP/CLEAR
* To exit the SABBATH mode and return to normal operation - press and hold TIMER OFF for 5 seconds.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 05, 2010 | Kenmore 71414 / 71419 / 71410 / 71412 Gas...
How to set the oven timer?
To Program Oven for a Delayed Start Time and to Shut-Off Automatically 1. Be sure that the clock shows the correct time of day. 2. Place the food in the oven. 3. Push "Bake Time". "00:00" and the words "BAKE TIME" will glow in the display window. 4. Push and hold up or down arrows until the desired baking time appears in the display. 5. After the bake time has been set, "----°" will appear in the display and the word "BAKE" will flash. The display will flash and beep once until the oven temperature has been set. 6. Push "Stop time". The time when baking will stop, will appear in the display window. The words "BAKE STOP TIME" will glow in the display. 7. Push and hold up or down arrows until the time that you want cooking to be completed appears in the display. 8. Push Bake (or Conv). "---°" will appear, and the word "BAKE" will glow in the display. 9. Push and hold up or down arrows until the desired baking temperature appears in the display. 10. If the baking temperature is not set, the control will beep. "---°" will flash and the word "BAKE" will appear in the display.
Mar 11, 2009 | Electrolux Kitchen Ranges
Dishwasher
Hi lilwing,
I'm Harvey the Master Plumber.
Your question is: you have a ge dishwasher you purchased two years ago. you have misplaced your owners manual. you can only tell you it is a ge quietpower 3. you don't even know the model since you've misplaced your owners manual. it started with the timer for speed cycle set itself between 50 and 60 minutes, and you knew that wasn't right. and then yesterday it did not drain all the water out. you know there is no food particles in it because you clean them before you put them in the washer and the drain line it is hooked up to is working proberly also. can i help?
First, the model and serial numbers are in the door jam. Open the door and look right and left.
The rest sounds like a bad control board, It will require a pro. If the d/w has a few years on it you may want to consider the price of repair verses replacement.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 09, 2008 | GE 24 in. Profile PDW7800 Built-in...
Jenn-Air JES8750 Electric Kitchen Range Logo
102 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
