Question about Sony Bravia KDL-40V5100 40 in. LCD HDTV
Sony kdl-40v5100 has handshake problem
New sony kdl-40v5100 has handshake problem intermintently with Moxi DVR cable box (Charter). Pink screen with picture when TV turned on. Turn off and turn on TV or replug HDMI cable resets perfectly.Happens on all HDMI inputs with the cable box. Changed HDMI cable to Monster cable, didn't help. Changed out DVR, same result. Is it a TV problem or cable box issue?
    President:
  • 1,768 Answers
1.This issue sounds as though the TV connection circuit has an issue.
2. You have changed the DVR and the HDMI cables and you still have an issue with the video (pink screen) indicates a video circuit issue ( improper voltage or current) at the video section of the circuit.
3. This will require some troubleshooting by a qualified tech.
4. To make sure, try connecting another properly working LCD TV to the cable box or DVR an check.If you get a picture and sound properly it is the TV.
5. Usually a cable box is QA'd (quality assured) by the company and will not be sent unless tested 1st
Posted on Feb 05, 2010
  • Harleen Nash Feb 05, 2010
MY TV SONY BRAVIA MODEL#KDL-40V5100 ONLY SHOWS A BLUE SCREEN AND IT DOES NOTHNIG
Sounds like tuner fault. Contact any service technician to check and confirm. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 06, 2014 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
Just received a new moxi remote because i was having trouble with my old one. My moxi box is a silver motorola box that says broadband media center. my old remote says charter digital on the bottom and...
Do you know what model MOXI box you have? The new remotes weren't programmed to the MOXI 3012 box. If you have the Moxi MP12, BMC9012, BMC 9012F, BMC 9022 you will need to program the remote to the box.
1. Turn on the Moxi STB.
2. Press and hold the MOXI and OK buttons on the remote until the red LED at the top of the remote blinks twice.
3. After the red LED has blinked twice, release both buttons.
4. Using the numeric buttons on the remote, slowly enter 0, 0, 4. The correct entry of this code will cause the red LED to blink twice.
5. The remote is now programmed to operate the Moxi STB listed above. Go to “Programming the TV”.
Apr 01, 2010 | Televison & Video
Boston Acoustics TVee Soundbar loses the cable remote training.
get rid of that moxi before it starts on fire.
have charter send out a scientfic atlanta hd dvr, with an hdmi port on it as well. the functionality and reliablity of these boxes greatly exceed moxi. moxi is a power sucking, fire hazard, problem waiting to happen. the only thing it has that is good is the guide format. but you may feel that graphics on a tv guide outweigh the funcitonality of the device. the big square in the front of the moxi was supposed to be a dvd burner, the box has no hdmi, and has a modem in it that is disabled. so its got a bunch of junk on it that isnt and cant be used. if you dont clean the vents on the back of the box monthly it will surely fail.
senior catv tech/supervisor
ALL OF US INSTALLERS DESPISE PAUL ALLEN FOR INVENTING THAT PEICE OF ****.
Jan 01, 2010 | Boston Acoustics BA735 Computer Speakers
Motorola cable box/dvr/remote problem.
I have the same problem. Any solutions out there?
Dec 09, 2009 | Motorola Televison & Video
I have a new sony kdl40v5100 flat screen. My power went out a few days ago and when it came back on there was a white screen on the tv. I saw the closed caption was off on it so I turned it on. I got the...
turn off the cable box but leave the tv on,push the menu button for the cable remote while the box is off and that white screen will appear.shut off the CC switch. It was not the tv's fault but it was in the cable box.
Oct 12, 2009 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
Sony TV KDL-32L4000 Turns Pink
My Sony tech says it's most likely a bad cable box. Try a DVD and if the DVD is fine then it's for sure your cable box. Needs to be replaced by the cable company.
May 06, 2009 | Sony Televison & Video
Charter MOXI Remote doesn't work with Sony Bravia 42'' Flat Screen
Hold down the moxi and ok button until the remote flashes twice,then enter 9910. The remote will then blink twice again.Then go back and fourth pressing the mute button and the up arrow key(the one above the ok button)this will go thru all the codes,when your tv finally mutes,press ok that means you found the correct code.Hope this helps
Mar 26, 2009 | Sony Televison & Video
Normal Picture Mode Not Available With Cox HD-DVR (Motorola DCH3416) and HDMI Cable
With an HDMI cable connected, the cable box determines the picture size. The settings on the cable box must be changed in order for you to get the correct picture size. I have some experience with Motorola cable boxes; usually to access the settings you turn the box OFF and then press the menu or settings button on the box to bring up the display menu. Hope this helps!
Mar 05, 2008 | Sony KDL-32M3000 32 in. LCD Television
Moxi box hook up to to an HDMI input
You need the dvi to hdmi cable or the 3 colored component cables.
Sep 01, 2007 | Westinghouse TX-42F430S Television
Sony kdl-40s2000
Probably need a software upgrade. Contact Sony for that information. This would be a common fix in most sistuations when using HDMI.
Dec 30, 2006 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia KDL-40V5100 40 in. LCD HDTV Logo
943 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
