Question about Whirlpool LHW0050PQ Front Load Washer
I am using a Whirlpool washer LHW0050PQ4 and have no manual. Is one available that I could download? How can I control/select water temperature?
Go here; http://laundry.manualsonline.com/ex/thread/view/idThread/2299742
Unit has internal heater, not adjustable
Posted on Feb 06, 2010
LHW0050PQ4 whilpool washing machine goes through wash cycle but wont rinse,spin or drain
According to the service manual, if the washer won't drain or spin the drain may be clogged.
http://www.searspartsdirect.com/partsdirect/user-manuals/27552/lhw0050pq4-whirlpool-parts-residential+washer-manual
Apr 04, 2014 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool LHW0050PQ4 Front load stackable door switch eratic
Go to whirlpool.com and download manual. download from owner icon
Dec 11, 2011 | Whirlpool Washing Machines
Do i use HE detergent for the whirlpool LHW0050PQ4 ?
yes in all front loaders only HE can be used,either liquid or powder but must be HE
Aug 07, 2011 | Whirlpool LHW0050PQ Front Load Washer
I just rehooked up my washer and I only have cold water going to it. It will go for a while and then reads F-20. What do I do?
he F20 error is a no water detected entering machine error and yes it is related to the hot water not being hooked up.
Newer washers sense and control the incoming water temperature. If you select cold wash and cold rinse you may think that it will not ask for hot water so you don't need it hooked up but you can't do that on this washer.
Even on a cold wash the temperature sensor will read the temperature of the incoming water. If your cold water is 60 degrees then the control will sense this and it may cycle the hot water on to bring the temperature up to 70 degrees.
This temperature monitoring is something all the newer washers do. Both water valves must be hooked up to water.
Jan 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Error code F20
The F20 error is a no water detected entering machine error and yes it is related to the hot water not being hooked up.
Jan 11, 2011 | Whirlpool WFW9400S
Whirlpool front load washer (model #LHW0050PQ4) will not drain the water or spin. What parts do I need to look at.
look at the drain pump. to remove nay water in the machine use a wet dry shop vac,attach it to the end of the drain hose.then remove the hoses from the drain pump and look fro any obstructions.if you do not find any thing then you may need to replace the drain pump or door lock mech,
Nov 03, 2010 | Whirlpool LHW0050PQ Front Load Washer
What is the acuwash sensor
Washer temperature sensors and water level settings
The temperature of your washer's water varies with your laundry care needs. Standard washer models typically feature three temperature settings: Hot/Cold, Warm/Cold, and Cold/Cold—and higher-end models often offer as many as six or seven temperature settings. Temperature plays a key role in the effectiveness of your detergent—pairing the right detergent with the right setting for your fabrics and soil is important, as this will help reduce damage, prevent detergent residue, and provide the best wash across fabric types. For the best fabric care, look for washing machines with automatic temperature control (ATC). A sensor will control water temperature and ensure cold washes are above 60 degrees (F) to dissolve detergents, and warm washes do not exceed 93 degrees (F) to help prevent shrinking and bleeding.
The amount of water you use for each load also affects washer performance. Doing laundry is a bit like a science project. You need to make sure you are using the right volume of water, with the proper amount of detergent based on the dirt level of the laundry being cleaned. Too much of one component can result in a less-than-perfect outcome. Standard washing machines allow you to select water levels for different size loads, but some models offer more water-level options. Washers with automatic water levels use sensors to determine load size and adjust water level for best cleaning and rinsing performance. You will generally find these options in higher-priced top-loading washers. A benefit of front-loading washing machines is that most come with this automatic water-leveling feature.
Whirlpool® AccuWash™ temperature control sensor provides a temperature-controlled wash.
this is an article from the whirpool website, u can get a manual printed or downloaded by going to whirlpool.com and going to owners center and typing in ur model number.......
May 21, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a Whrilpool model LHW0050PQ4. Lights are blinking nonstop.
UR MAIN CONTROLLER NEEDS REPLACING. IT HAS A COMMUNICATION ERROR
May 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
DOSN T DRAIN
possibly debri in your pump you should need no tools the face twist off and comes apart.your catch could be clogged too.
Nov 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
814 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
