Question about ASUS P4S533-MX Motherboard
No display on mainboard when booting
I recently installed an asus p4s533-mx mother board, and i get no display, i have memory installed and keyboard plugged in only?
can you help?
  • cheekymanc1 Feb 05, 2010
    I have tried reseating the ram,but still no display,the board is brand new,should I send it back?
  • cheekymanc1 Feb 06, 2010
    Hi,i have tried another psu and i have no usb`s connected at present,also tried another cpu chip,but still no display....i get all the signs of a perfect boot but no display or beep codes?
    Guru:
  • 239 Answers
Normally it's RAM or Graphic card not well seated in that slot... Remove n plug them back properly
Posted on Feb 05, 2010
Testimonial: "thanks,but i tried that already,it had onboard vga, and tried several different ram."
  • gcsltd
    gcsltd Feb 05, 2010
    hmm...
    That's may be a partly defective PSU, pls try another 1
    Pls check if u have connected the ATX power 4 pins on ur mobo.. It supplies power to ur CPU chip
    Also pls check ur USB connected to ur mobo (if there is a prob or rust on the usb ports it won't boot ur pc) remove the usb wires connected to ur mobo n try
  • gcsltd
    gcsltd Feb 06, 2010
    Try to clear BIOS by removing the jumper near the cmos battery found on ur motherboard. If it's on pins 1/2 move it to 2/3 & wait 1 minute. Then put it back in its place! good luck
I can't download soundcard P4S533-MX Motherboard
Go to the ASUS Support site and follow these steps: -
1. Select Product - Mother board
2. Select Series - Socket478
3. Select Model -
P4S533-MX and click search, it would ask you for operating system
4. Select operating system and download drivers
Hope it helps!
CreativeTECH
Dec 20, 2010 | ASUS P4S533-MX Motherboard
Asus Mother Board(P5GV-MX) display off, Boot time sound also off, The ram is OK. Processor can't check. Please give me solution.
Oct 18, 2010 | ASUS P5GV-MX Motherboard
My mother board asus p5v800-mx was having a bios corrupted.. it only display starting bios recovery..
Try these options if you mainboard is not booting!!
1. Clear CMOS. (Remove the CMOS Battery)
2. Remove your memory cards and video card, try to clean their golden connectors with a rubber, then reseat them back.
3. Remove the CPU cooler out, add some thermal paste to the CPU surface, then reseat the cooler back and keep the cooler tightly installed.
4. Keep the necessary components(CPU, one memory) onboard for a test.
Finally, recommend you to replace a BIOS battery to have a test.
Hope it helps.
Oct 11, 2010 | ASUS Computers & Internet
Need audi driver for a mother board asus p4s533 mx free where and can it be and setup.exec
heres the link to the asus site for downloads, would be nice to know what operating system you are using i got the link for Win XP.
http://support.asus.com/download/download.aspx?SLanguage=en-us
Feb 22, 2010 | ASUS P4S533-MX Motherboard
My computer won't boot on cd, i cant repair it with my XP CD, any help would be much appreciated. my processor is p4s533-mx
During the boot press the F12 key to select your boot option and choose your CD drive. Depending on your system it could be the F10 key, it should display the option during the post.
Sep 01, 2009 | ASUS P4S533-MX Motherboard
Driver asus p4533-mx
Hi, i think, there is a problem with the name of the mainboard. It should be
P4S533-MX. Then you should go to Asus. http://support.asus.com/download/download_item.aspx?model=P4S533-MX&product=1&type=All&SLanguage=en
Mar 22, 2009 | ASUS Computers & Internet
I am facing 2nd problem with my pc.
Most likely problem is an unsuppoterd cpu. Check the Asus website to see if cpu you installed is compatible with this board.
Dec 22, 2008 | ASUS P4S533-MX Motherboard
P4s533 mainboard
Reset BIOS back to default
1) remove M/board battery for 5 to 10 minutes
or
while booting press the DEL or F2 or ctrl+esc
or check lower part of screen during boot will tell you hoe to fet into BIOS
Once BIOS reset to default boot computer if OK.
you can change BIOS to suite CPU etc
Oct 29, 2008 | ASUS P4S533-MX Motherboard
Does it have a built-in system beep buzzer? or else you need to connect one. The system beep has a code and will tell you if your video is not connected or your memory is not detected.
Try to make it boot even until the bios screen. Check your video card or your monitor connector. A single beep is a good sign that your motherboard has no problems. hope this helps
Sep 25, 2008 | ASUS P4S533 Motherboard
ASUS P4S533-MX Motherboard Logo
175 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
