Probably stripped the one gear. One gear is made out of plastic so that if there is an unusual load (excessive load) on the motor, instead of the motor burning out, it breaks the gear. You need to open up the unit, confirm that you have a broken gear and then call the manufacturer so that they can send you a new part.
Let me know how this works out for you.
Benjamin
You need to start from the bottom of the unit to get the post off. Have you gotten the paddle off yet? You should do that first.
Have you not gotten the paddle out yet? It WILL detach, just unscrew it from the rod and you can then clean everything off. inside where the bread goes.
It should pop right off
This is a bread machine, I do not know why it says sewing machine...I did not submit that as the appiance.
The machine unit is fine, I tried to lightly put my finger in the gear without the pan in place and it was real strong. My issue is with the pan.. Do you know how to take appart the post where the paddles attach because they do not turn easily? I do not see any plastic gears anywhere.
There are no plastic gears. The bowl has rods that come up to turn the paddles and they are tough to turn, they need to be cleaned out. The bread ingredient clog them up.
It does not unscrew, I definately would have tried that first.
