Question about Cell Phones
Phone turns off browsing internet
I have an LG Cookie KP500, when I'm surfing the internet if I hit certain buttons(like hitting the search button on search engines, or hitting 'yes' when prompted to save a password on my facebook or not) the phone automatically turns itself off, then back on. it also does this when I exit the browser. is this something I can fix/get fixed?
In the settings of the internet we choose (wap) or (mms)
I would choose "WAP" because this will give you a better browsing experience.
Feb 28, 2011 | LG KP500 Cookie black on T-Mobile U-Fix...
Internet not work.
The user can surf the internet as the KP500 cookie mobile phone supports HTML/XHTML and WAP 2.0 web browsing technologies, providing speedy connections. The EDGE and GPRS technologies provide not only a speedy service but a good quality of service especially for data transfers. The user can connect their LG KP500 mobile phone with ease to other compatible devices with the USB and Bluetooth with A2DP technologies. The KP500 operates on a Quad-band network and covers GSM-850/900/1800/1900 enabling the user to use the roaming facilities as and when abroad. The LG KP500 supports a document viewer which enables the user to view documents in XLS, DOC and PDF formats.
To Setup the Access Point
  1. Go to the Main Screen
  2. Select Menu (the 4 dot button)
  3. Select the Settings tab
  4. Select Connectivity
  5. Select Access Points
  6. Select Add access point
  7. For the Connection name enter The Name for the connection. Use the default or make up your own.
    ">#Profile
  8. Set Authentication to This option varies on devices but typically is similar to the setting provided.
    ">#Authentication
  9. For the Username enter The Username for the connection provided by the Carrier.
    ">#Username
  10. For the Password enter The Password for the connection provided by the Carrier.
    ">#Password
  11. For the APN enter Access Point Name - Similar to the server the connection uses for the connection. Different APNs provide different services.
    ">#MMSAPN
  12. Select Save
To Setup the Internet Profile
  5. Select Internet profiles
  6. Select Add profile
  7. For the Title enter The Name for the connection. Use the default or make up your own.
    ">#Profile
  8. Set Use proxy to AT&T:
    • On
    T-Mobile:
    • Off
    • Alternative: On
      Note the proxy only needs to be on if using the Alternate settings
    ">#Proxy
  9. For the Proxy server address enter The Server address to use for the connection.
    Some devices require the address in the format of 000.000.000.000. (ex: 011.012.013.014)
    ">#MMSProxy
    if the Proxy is on
  10. For the Proxy server port enter The Port number used by the connection.
    ">#MMSPort
    if the Proxy is on
  11. Set the Access point to the profile created above
  12. Select Save
To Setup the Browser Profile
  3. Select the Utilities tab
  4. Select Browser
  5. Select Settings
  6. Select Profiles
  7. Select Add profile
  8. For the Title enter The Name for the connection. Use the default or make up your own.
    ">#Profile
  9. For the Homepage enter Can be set to anything if an Internet Plan is on the account such as www.google.com
    ">#Homepage
  10. Set the Internet Profile to the profile created above
  11. Select Save
  12. Select Yes to Activate
  13. The internet should now be configured
Jan 25, 2011 | LG KP500 Cookie black on T-Mobile U-Fix...
Internet connection
Hi Joanne.
Your Virgin Home network I am guessing is wireless???
This may be a big problem.
The KP500 Cookie is not a WiFi enabled handset so connecting to ANY Wireless internet connection is NOT going to happen. Sorry!
When you search manually for a Network what you are actually doing is searching for another mobile phone network.
The mobile phone network is the only way the cookie can connect to the internet.
Jul 19, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
Phone will not switch on
i have a lg kp500 and it will not turn on i have to take battery out then put it back in
Jul 14, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
Phone switches off when exiting internet browser.
maybe ur phone just is no working or u need 2 get another one that does not have the internet.
Feb 22, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
How to apply theme to LG KP500 mobile
u should download themes frm internet site r www.zedge.net u can get it.....
Aug 29, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Maximum limit applications reached ( LG cookies)
When you see that push the middle button. then tap the purple arrow in the top right corner and hit end all. I'm still trying to figure out a way to to allow more applications. But it's certainly better than having to turn your phone off. hope this helped it's my first comment :^)
Jul 31, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Download skype on lg kp500 - lg cookie
Using pc suite transfer it to lg kp500 and then try installing on ur phone
Jul 03, 2009 | Computers & Internet
Cell Phones Logo
59 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
