Back to:
Tags:
Brother IntelliFAX 770 Plain Paper Thermal Fax
Unable to copy
posted by lee ann on Feb 21, 2008
jammed paper inside. want to remove and reset to "copy" mode It says to enter fax no. and press start key.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Mar 14, 2008
Not Rated (0)
viziks
Rank:Wiz Wiz
Rating: 84%, 149 votes
You need to open the cover and see the document you were trying to fax.Just pull it gently.
Samir
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on unable to copy:
I don't want to Accept this solution
Can you Help with these Fax Machines problems?
Brother IntelliFAX 770 Plain Paper Thermal...
How do I install my new ink cartridge into my Brother...
I have the Intellifax 770 and moved from Florida to...
When trying to copy I get a grinding sound from the left...
I don't kknow if someone changed the mode number, but the...
Error message says Page Mem. Error and none of the buttons...
Loading problems.
Repair Service
Find Fax Machine Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
