How to disassemble a Mackie SR24 4 2 Mixing console for cleaning, and how to properly clean pots, faders, switches and inputs. Thank You, Don
Can't help with the disassemble, but I restore vintage receivers, so I can help with controls. Your local guitar shop should carry a product called "Faderlube", or you can order it on line. There are two versions, the 10% solution and the 100% solution. Spray the 10% first, and work the pot or fader from one limit to the other 50 times. Repeat with another spray and workout. Then follow up with the 100% solution. The 100% provides lubrication. You have to make sure you get the fluids inside where the sliding resistive parts are. You can usually tell if it's working because the fluid will cause the pot to turn or the slider to slide more freely. This process will cure 90% of your problems. When you test, you may find some of the controls are still dirty, and you have to go back and repeat the process, but before you do, try just working them 200 turns and see if that does the job. There are cheaper cleaning products, but don't mess with them. Shell out the bucks for the real thing.
Posted on Feb 05, 2010
Testimonial: "Thanks for the advice.Figured out the disassemble.The products you suggested worked extremely well.Saved me a bunch of money doing it myself.Thanks DS"
How do i hook up monitors to mackie1604 vlz pro to where you can hear music and mike.
Plug either a powered monitor or amp and then speaker into one of the aux sends. Now adjust the monitor mix using the appropriate aux send pot on each of the channel strips you want to send to the monitor. Think of the aux send pots as faders for the monitor mix the same as the main fader for the ain mix.
Aug 15, 2014 | Mackie 1604 Vlz3 16 Channel Mixer
Right fader knob doesn't do nothing. No sound come out from my right speaker when I turn the right knob up
PV series mixers from peavey suffer from horrible sliders pots quality, so be prepared to change that pot, it is pretty easy to change, real difficult comes out when you are trying to reach it, let me know a bit further to help you out troubleshoot accurately the issue.
Jan 18, 2013 | Peavey Pv 20 USB 20 Channel Mixing Board...
Static on left side of output
Loose connection or fader/pot needing cleaning. Try selective tapping and wobbling until you locate it. You could try contact cleaner if it's a pot/fader otherwise it's out with the iron unless it's just a loose lead internally.
Nov 24, 2011 | Mackie Music
I have a mackie cfx 16 mixing board.My problem is that , the only way I can get a good signal to the led's for each channel (0 db) is to turn the gain up so high on the channel that it constantly...
No reason to worry about getting signal to the LED's... you set the trim gain so the loudess sound or signal that can happen barely clips or is slightly less. That is the starting point. Watch videos on mixer setup on YouTube. DOn't worry if their mixer is different as the principles are the same.
Mixer fadrs should be around 80% up when system is balanced. ALWAYS use BALANCED cables... eithrt XLR or TRS.
Aug 21, 2011 | Mackie CFX 16 mkII 16 Ch. Compact SR Mixer...
Would you know how to correctly open a CFX20 to clean the pots?
Yopu do NOT clean the pots... if you have noisy sliders, get some CRC226 at Home Depot in the electrical dept. Spray a small bit in the center of the slot for the slider and run the slider up and down. Use sparingly and apply a tiny amount once more. The sliders are NON_REPAIRABLE if this won't fix them and major disassembly is required involving removing the round knobs, fader knobs, screws and other nuts on the jacks. Hours of work. Pots require desoldering tool and use of soloder wick and plunger type removal tools often causes damage to the circuit board.
May 27, 2011 | Mackie cfx20 mkII compact mixer
My mackie 1604 vlz 16channel has a problem, it changes sounds during the use and faders need to be cleaned. why is it changing sounds on me...?
If the faders have become noisy, they may be changing due to poor contact. Try putting a small amount of CRC226 in the center of the slot of each fader and then move fader knob to top and bottom. CRC226 is available in the electrical department of Home Depot in a small can with spout... about $2.70
Jan 16, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
Faders not working properly on am844d right channell goes in out when I wiggle the main L/R fader. Some of the channel faders are eractic. The level of volume is not responding right to fader...
You probably wrecked the faders putting De-Oit in them!!! NEVER use that in pot and faders... It is for switch contacts only.
You have ONE chance to save them. From Home Depot get a can of CRC226 in the electrical dept. Put some of that using the spout into each fader near the middle and work the faders. The CRC226 costs about $2.70 a can. Make sure it is the 226 as there are OTHER CRC products there and only 226 is the one that is suitable.
The De-Oxit will have cleaned out the lube of the faders and if you are unlucky, one or more of the wipers will have folded back which is fatal... The CRC226 is an electrical lube that I have restored faders and pots with... It has many other uses including lubing plier joints...
Dec 31, 2010 | Phonic Am 844d Mixer 8 Mic/line 4 Stereo 4...
Looking for sliders for mackie 1402 vlz pro how much are they?
You can purchase the channel faders directly from Mackie Service Dept., you can replace them yourself if you're good at soldering - HOWEVER, be advised that disassembling the unit to get at the faders to replace them will require a lot of time and patience if you've never done it before. If the faders are not moving smoothly, it's possible that the wrong type of cleaning spray was used on them and there's a possibility that they could stop moving and controlling sound.
Jul 27, 2009 | Mackie Music
No volume control with 2 faders on Mackie CR1604 mixer
If all other functions work for those channels, the most likely problem is the fader itself. These can fail and operate more like switches rather than faders. Without witnessing the behavior, I can not state that for sure. While these mixers are not the hardest to work on, they are time consuming. The faders can be purchased from Mackie directly. If you need to have this repaired, any shop that repairs audio gear should be able to erpair this for you. Where are you located?
Dan
Feb 09, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
How to hook the eq up??
take output from left and right from equalizer and go to line in any two channels inputs in peavey mixing console and adjust your level with faders and other control knobs.
Mar 02, 2008 | Phonic PEQ3400 2x15-band Graphic Equalizer...
439 people viewed this question
 Grubhead
Grubhead
