Question about Mitsubishi VS-60611 60" Rear Projection Television
VS 6061 I have a picture aroung the outer edge of screen..big black box rest of screen..i do not have owners manuel..if i hit display on remote twice i have picure. help
  • 476 Answers
Press the cc key on the remote control once at a time until the close caption feature displays off. you will see the display will take you through cc1,cc2,text1,txt2 etc. just keep hitting the key until it says cc is off. you should get the block out after this and view your tv normally.
Posted on Feb 05, 2010
On our mitsubuishi vs-5041 50 inch there is a black box aroung the picture of the tv. I dont have the remote, so how do i get the television picture back?
Hello.
You can use buttons that are located in front of the TV as well.
Press "menu" button and locate "picture" or "video submenu. You can use some buttons as directional ( they have arrows that indicate where you can move highlighter on menu). To choose option you can press "Select/enter" button.
More info in your TV owner's manual.
Regards.
Russ.
Dec 01, 2010 | Mitsubishi Televison & Video
Tip
Mitsubishi parental lock removal/v-lock redo
Models:
Color Televisions
CS-20EX1, CS-20301, CS-26EX1, CS-26201, CS-26301, CS-2725R, CS-27EX1,
CS-27MX1, CS-27TX1, CS-27200, CS-27201, CS-27301, CK-27304, CK-27306,
CS-27401, CS-27403, CS-3135R, CK-3136R, CS-31AX1, CS-31FX1, CS-31MX1,
CK-31MX2, CS-31301, CK-31302, CS-3525R, CK-3526R, CK-3527R, CS-3535R,
CK-3536R, CS-35X7, CS-35AX1, CS-35FX1, CK-35FX2, CS-35MX1, CK-35MX2,
CK-35MX3, CS-35201, CS-35201A, CS-35203, CS-35205A, CS-35301, CS-35401,
CK-35402, CS-40FX1
Projection Televisions
VS-40VA2, VS-4517S, VS-45VA1, VS-45VA2, VS-4561, VS-4562, VS-5016R,
VS-5017S, VS-50VA1, VS-50VA2, VS-50VF1, VS-50VF2, VS-50VX2, VS-50VX3,
VS-5061, VS-5062, VS-6017R, VS-6026R, VS-60VA2, VS-60VF1, VS-60VF2,
VS-60VX2, VS-60VX3, VS-6061, VS-7017R
This system locks only the entire TV. The TV will display a screen that
will indicate "Parental Lock ... Now the lock is on" and request the
personal four digit code when the TV is powered on.
IMPORTANT> You must use the original remote control that came with the
TV to release the Parental Lock, you cannot use a remote
that came with a VCR, Audio System or from any other
manufacturer.
1. Depending on which remote came with your TV, press the button at
the top labeled TV,OR set the TV/VCR switch in the upper left
corner of the remote to the TV position. .
2. Press the button on the remote labeled POWER.
The TV will turn on and display an information
screen that indicates "Parental Lock ... Now the
lock is on" and ask for the four digit personal code.
3. Press the #9 and the QV buttons at the same time.
The TV will turn on.
4. Press the button labeled MENU.
The "TV Main Menu" will be displayed.
5. Press the ADJUST UP or DOWN button to move the arrow next to the
"Advanced Features" selection and then press ENTER.
The "Advanced Features" menu will appear and
indicate that the lock is ON.
6. Press the ADJUST button to move the arrow next to the "Parental
Lock" option, and then press ENTER.
The screen will change to indicate "Parental Lock
... Now the lock is on" and ask for the four digit
personal code.
7. Press the #9 and QV buttons at the same time.
The screen will return to the "Advanced Features"
menu and indicate that the lock is off.
8. Press the MENU button twice to return to normal viewing.
The original lock code has now been erased and the lock canceled.
on May 16, 2010 | Audio Players & Recorders
Need caption taken off
Hi, the only other way would by going into the menu or display mode by pressing the corresponding key located in the front of the TV(if available) and using the other keys to scroll down the list to where you can access the audio features. you'll have to look for the caption heading once in the audio select menu and keep pressing the select key untill the cc feature says off, this should eliminate the black box blocking the picture.
Apr 20, 2010 | Televison & Video
Big black box while trying to play movies
Hello there, sorry to hear about your issue. Usually this indicates that someone has hit the CLOSED CAPTION button or possibly the PIP (picture in picture) button on the TV remote. There is nothing wrong with the xbox, it is actually a setting on your TV. Check the remote to see how you can disable closed captions.
Oct 14, 2009 | Microsoft Xbox 360 Console
Black spot on screen
Your son turned on the closed captioning text mode. The black box is where it would appear if there were any text. Go into your setup menu and turn off the captioning, or restore the factory presets.
Jul 20, 2009 | InFocus ScreenPlay 61" Rear Projection...
Mitsubishi vs5003r troubleshoot
I found this in another website... i hope this can help you. I'll try too...
Found this on the web, hope it helps.
Thank you for contacting Mitsubishi Digital Electronics America, Inc. We
are pleased to be able to assist our customers via our website. Here is the
information that you have requested:
TV Lock #8
Models:
Color Televisions
CK-35402, CS-40FX1
manufacturer.
personal code.
Oct 26, 2008 | Televison & Video
A black box appears on the screen
Just happened to see your black box problem associated with your T.V.; Thought I would pass along an idea for you to check into, and let me know if it helped...Check into whether or not it has a onscreen text block mode, if it gets into this mode by accidentally pressing the wrong buttons on the remote and or TV, it could and I have seen, at least with zeniths, a big black box which will cover the whole screen except for a 2 to 4 inch border around the box and outer edge of the screen...if this is the case, find someone familiar with the correct setting for the set associated with this problem, and get it back into the right mode....Hope this helps..T.
Jan 15, 2008 | Haier 20" TV/DVD Combo
Black box on screen
This happened to me and it turned out the closed captioning on my TV were activated somehow. I never even touch the controls on the TV but I had to manually check the settings on the TV and found that the captions were on.
Sep 16, 2007 | Mitsubishi VS-6041 60" Rear Projection...
Tv picture
Your closed captions are on and set to TEXT. Go into the menu, turn off the closed captions and the black box will vanish.
May 22, 2007 | Zenith SY2768S TV
Televison & Video Logo
23 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
