Question about ASUS A7S8X-MX Motherboard
My computer does not start, but the ld motherboard lights up, I've tested, and the source is ok.
  • Mike Peluso
    Mike Peluso May 11, 2010
    Try this, shut down the system. Flip the power switch on the back of the power supply to off. Watch the LED on the motherboard. When the green LED goes out wait another 15 seconds. Flip the PS switch back on and power up you're system. See if you're system POST and windows loads?
    Problem Solver:
  • 6 Answers
Have you tried looking at the switch from the tower to your mainboard?
try another switch direct to the mainboard,and see if it boots.
Posted on Feb 06, 2010
  • 728 Answers
I don't know how computer technical you are, but it sounds like you know a thing or two about them. So here's the best way to find the problem:
There could be many things that could stop the board from fully booting, Determining what is wrong is like detective work. What I do, is open up the case and take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd, hard drive or otherwise) the CPU, a graphics card (only if required) and one bank of memory. (which is not required, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. If your going to load a IDE drive, make sure you set your pin setting correctly on it, meaning the drive (IDE or EIDE) your putting on the board is set to Master, or Cable Select if your using the cable placement method.
Now, turn it on, and you should get the power supply on, and the cpu fan going. If they start, then make the next step to have the single drive be your hard drive, and see if it boots. If it boots, then great, open Bios and make sure Bios is reading the board and all things are fine with it. If so, what ever you put on next make sure it one at a time so you can identify what it doesn't like.
In the case where the CPU or power supply don't power up, it's then either one of the six elements. The CPU, Power supply, Ram, Drive, graphics card (if required) or the motherboard.
The next step is to replace each one of the first five, starting with the Ram Chip, put another like chip in and see the results. Then do the same thing to each of the remaining 4 components, the graphics card (if required), then the drive(cd, hard drive or otherwise), on to the CPU, and last the power supply. Hopefully something will show it's ugly way to make a change. Also, on the drive (IDE, EIDE or SATA) , try a different cable to make sure it's not that,
Now If no changes happen after all that, then I take it one step further and usually get a like (doesn't have to be exactly the same, but a board that the components can be tested on) motherboard that I can test the first four, and make sure that they really work. If after that and you have tested all of the components and they all work, then it's save to say you have a bad Board my friend. It's a lot of work I know, but it's the sure fire way of finding out what isn't working.
Good Luck
Mark
Posted on Feb 05, 2010
No display but the computer turns on.
could be an issue with the graphics controller or with the monitor. first, verify if the monitor is actually working. try it on another computer or video source. if it works, make sure that you have a working video cable and check to make sure the video input source (dvi, vga, rgb, hdmi.. etc) selected on your monitor is the correct one that you are using. if you have ruled out the monitor, video source and cables, you can then test if another monitor will work with the computer. if same thing happens, meaning nothing on display even the manufacturer or BIOS screen does not show up when you turn on the computer, it is most likely the video controller. you may either get the motherboard replaced or install an add-in video card if the integrated video controller only has one video connector.
Jul 17, 2013 | eMachines MS-7145 Motherboard 103777
Tip
My Computer will NOT start up blank screen?
So, your computer wont start up? What to do? First disconnect all attached devices, Then we must check to see if there is any Power, Try unit in another power point, if Power Point proved OK, then try & change the Power Lead in, proved OK, then Check the Power Supply, do you see the Fan "Kick"? On the Power Supply AND the CPU Fan inside, proved OK, then Check to see if there is power to the Motherboard? Often there are LED's that show if power is ON. proved OK? We must now remove the Power from each device, DVD, Hard Drive, leaving ONLY the MotherBoard connected. OK, So we are at the MotherBoard, it still won't power up, everything else has been removed... now remove the RAM. power up, Proved OK, if NOT, then the RAM is your problem replace.it power ON, Proved OK, If not then your MotherBoard is Faulty, proved OK, then start attaching devices and re-starting & rebooting each time until you find the one that stops the PSU. That is your problem. At each step if you don't have a, proved OK, then, that last step was your faulty bit, replace or remove.
What we have to do is at each juncture we must test each item in turn, and do a reboot each time connecting & disconnecting to prove the faulty bit.
So say we have tested all from Power Socket to MotherBoard & RAM all test OK, then we start to attach the hard drive & it won't power up, or say it was the DVD, This then is the source of your problems.
on Jan 30, 2010 | Computers & Internet
I've super G3, print comes light and very very light 2 inches from left. pl help
Print the copy counter of the machine, check if the life of the drum unit is already reached. If the drum is ok, then you have to clean the laser unit. maybe dirt is blocking the light coming from the LD unit.
Apr 12, 2013 | Ricoh Aficio 1515MF All-In-One Laser...
Computer shut down continuously during start up...dell
If you've cleaned it internally make sure there are no loose connections you've knocked. Esp where the Hard drive is connected to the motherboard.
Oct 20, 2012 | Dell Computers & Internet
Custom computer build, foxconn motherboard, computer wont start
Not trying to be condesending but start simple and work your way up.
1. strip dow board to;
a. known good older processor
b. known good single memory stick
c. known good power supply
Test
move memory one slot over
Test
Move memory over one slot
test
move memory to last slot
test
You have tested the variables if still not working you have a bad mother board.
contact foxconn for replacement.
Feb 28, 2012 | AMD Computers & Internet
I have a Dell Vostro 410. It would not turn on - would just blink amber light and go "ping, ping" - So I had a technician come and he said the motherboard was bad - we put in new motherboard -...
Yes the motherboard is faulty. But it hasn't died on its own, it was damaged by something else in there - most likely the power source is defective and it has effectively fried the boards. The technician should have tested it before replacing the board. Call it again, make him test the source in front of you and if it's defective have it foot the bill for the repair.
If the source is OK then something else that is connected to the pc is defective so multiple test will have to be done.
Sep 14, 2011 | Dell Vostro 410 Desktop Computer
I have a volt meter and would like to use it to test some connections to figure out the heater does not light. Can you tell me where to place the leads?
First start at the line voltage coming into the unit. The LD model is supplied power from an external source. Once line (supply) voltage is checked, start at the transformer and trace all the circuitry. Meter set at 50 VAC should do it. The supply voltage will supply 120 VAC to the igniter. Here is a link to the PDF manual fro Laars/Jandy/Waterpik Lite2 heater
Jun 06, 2010 | Jandy Laars Lite2 Ld 400,000 Btu Heater
Won't boot....fans start, then stop right away
check if your power source is ok. it may be broken and this is why you hear the fans start and then stop right away. they are working about 3-4 seconds, aren't they?
remove and put back the jumper for clear cmos after you test your motherboard with a new ac source
Jan 25, 2010 | Biostar P4M900-M4 Motherboard
Asus A8V-E not start
Looking at this post, I think your Motherboard is bad.
Have you tried a different Video Card?
My other thought is the CPU is overheating due to incorrect seating of the FAN and heat sink.
Try cleaning the CPU off, and put new paste on the CPU, then re-seat the heat sink.
Be careful to make sure the anchors are pushed all the way down by slightly twisting or wiggling the heat sink.
Check for looseness.
Push down on all memory sticks to ensure they are seated all the way in.
They should click on both sides.
If it still gives you a red light, then contact the website of the manufacturer, and get an RMA number for a replacement.
Jul 24, 2009 | ASUS A8V-E Deluxe Motherboard
ASUS A7S8X-MX Motherboard Logo
118 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
