Question about Emerson EWF2704 TV
My tv is less than 5 yrs old when I turn it on all
My tv is less than 5 yrs old. when I turn it on all I see is dark snow . It started with the picture going hourglass shaped and now all I see is dark snow. Does anyone know what the problem is and how can I solve it? the cable is hooked up correctly but nothing happens when I turn the cable on is it going to cost much to have it fixed?
    President:
  • 2,992 Answers
The hourglass distortion is usually due to bad solder connections in an area called the pincushion correction circuit, and repairing them usually takes care of that trouble. Whether this caused anything else to go bad and led to the other troubles your set has or they are unrelated is impossible to tell without finding what's failed.
If you had just the pincushion distortion, I'd say you might be able to try repairing the set yourself if you can use a soldering iron on electronic circuitry (or if you know someone who can). But with the other troubles, your only solution is to take the set to a service shop for an estimate by a technician. Troubleshooting often needs special tools and skills as well as the manufacturer's service information, and it's possible to make things worse by trying to do repairs without experience.
Given the low cost of smaller TV sets today, you might find it's more economical to replace this set rather than repairing it. I don't know what shops are charging to do estimates these days. The shop I worked for used to charge $20 (applied to the repair) to do a check and give an estimate, and I got out of the business 10 years ago. Overall, the cost of repairing this may run over $100. Of course, I could be wrong. Maybe start with an estimate and then decide what to do based on the dollars.
Hope this helps a little. Thanks for using Fixya!
Posted on Feb 05, 2010
I have an LG tv about 5 yrs old and suddenly the screen is darker and I have adjusted it to 90 percent bright / contrast etc and still dark ...
one of the components
chip or circuit board has failed
if you cant source that part
time for a replacement
Oct 30, 2016 | LG Televison & Video
Snow on scren only Will not change chanals either using remote or tv contol Do I need a turner? if so where can I obtain same? call Tom @ 1-314=822=7373 TV about 30 yrs old think I had a power surage
any tv 30 yrs old is surely analog , these wont work in todays environment as the ole government did away with all those analog goodies , you'll need a converter to convert the new 1080P HD pictures down to the fuzzy analog signal so your tv can see them , unless its a family heirloom with a fantastic looking wooden cabinet id be looking to get a new HD tv to replace it
Feb 29, 2016 | Televison & Video
My RCA television is making a ticking sound and the screen is flickering is this worth fixing the TV is about 15 yrs old
U had this tv for 15 years but u watches or used the tv less than 8 hours everydays?Yes,than this tv set have alot of life left in it like another 5-7 years more.Yes,if the repair cost is around $500 or less.Because u will not get that kind of screen "61 size for $500 dollars.
Aug 12, 2011 | RCA D61W136D 61 in. TV/DVD Combo
When TV first turned on often has blurry dark lines
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts...
Jun 26, 2017 | Sony BRAVIA KDL-46XBR2 46 in. LCD HDTV
Snow blower wont start
carb is probably gummed up from old fuel..take it off then clean it good and i bet it fires up
Feb 05, 2010 | RTO Sno Wovel wheeled snow shovel
Suddenly SNOW on all channels
your tuner has failed;
time for another set the cost to repair is too high
May 29, 2009 | Televison & Video
TV Turning on and off by its self
You have problems with a condenser that allow the power supply to maintan an acceptable level of voltage in order to keep the TV on. take to a tech to be fixed. unfortunatelly, this problem needs a tech to take measures in the circuitry to find the component that causes the problem.
Nov 06, 2008 | Philips Magnavox TS3260C 32" TV
42EDT41 colored snow/pixels
I have the same green dots that are seen especially when the bacground picture is dark or black. Mine does not seem to be changing when it warms up, and I also get it on my digital cable as well as on any DVD's I play. Please help with any advise. I think it was always there, but I assumed that a dgital cable upgrade would fix it - I should have known better...
Thanks a bunch in advance...
Oct 22, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
65 inch Mitsubitshi hd dlp
The tv has a bad lite engine. Please call the manufacture's customer service and asked them for a concession for this repair. This a $700.00 to $900.00 repair. If you persist 95% of the time they will cover this repair for you. Use the word 'concession' that's there verbiage.Good luck.
Apr 03, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Dark picture, mostly red colors
if you set is over 4 yrs old the tube is at fault,you may try to adjust the screen settings.
Mar 27, 2008 | Zenith B25A76R 25" TV
Emerson EWF2704 TV Logo
99 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
