Question about Radio Shack Radio Communications
Have 2 wires off inside the mic and need to know where they need to be resoldered
  • 494 Answers
Could be anything and without seeing the actual mic, no telling what wires are what. Can you supply more details such as mic type, radio it goes to and maybe a pic?
Posted on Feb 13, 2010
Sound only comes through one channel, have you any idea why? Norman Bevan
Most likely there is a broken wire inside the mic. You'll have to disassemble it to fix it, and it's not what I would call an easy job. Get a tech to help you, if you can. Chances are that it's just a wire that's broken and needs resoldering.
Also, on the following page, they talk about determining whether the problem is with the mic or headset, which should always be done first.
Sennheiser recommends sending it in for repair, and here's their site:
http://www.sennheiserusa.com/serviceandsupport_faqs_other-questions
Good luck, and hope this helps.
Nov 15, 2010 | Sennheiser K6 Professional Microphone
Audio Tech at831cw lapel mic wires disconnected
normaly when pulled out the cable is also come inside defective, probably better a new mic spare. you can spend time repairing and still no working well
Jan 02, 2010 | Audio Players & Recorders
Recently I dropped my Beta 87A mic and the 2 wires that connect the mic itself came disconnected from the mic. I want to know how to resolder the mic.Thanks in advance. Norbert
I take it they are the wires to the diaphragm not the cable (XLR) connector.Be very carefull when soldering the wires back on. A small solder iron with a pointed tip works best. The positve terminal should be marked with a small red dot.The red wire goes there and the black on the negative. Be carefull and take your time.
Apr 27, 2009 | Shure Beta 87A Microphone Microphone
Cant transmit
Hello Darren, Yes it sounds like the mic is wired bass ackwards,,! A cobra 25 mic wiring is
PIN #1- Shield or ground wire
PIN#2- Audio or Transmit modulation
PIN #3- Transmit or Dead Key
PIN #4- Receive Audio.
When your keying the mic, the RX wires are being connected to make the RX work,,,
*** Let me know how you get along with it. Either buy a new mic wired for your radio or you or someone comfortable with soldering needs to resolder the correct wires back on the mic plug,,,Like I said, let me know and have a great day,, Mechanic is back quiet!
Oct 21, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Gxl 2400 wiring connections
well best to just resolder it if you know the wire it should have a standard diaphragm with standard layout. should be asimple fix.
thanks,
Nate
Aug 12, 2008 | Audio Players & Recorders
Mic stopped working
Could be loose connection where the two wires connect to the circuit board. The mic looks like a small silver canister with two wires leading from it. Resolder if you are handy with electronics. Oherwise replace with a like mic from Radio Shack. Take the old one with you.
Jul 10, 2008 | Panasonic KX-TG5100 Cordless Phone
Astatic mic. model 636-L
http://homepage.ntlworld.com/rg4wpw/astaticbook.pdf
Mar 13, 2008 | Astatic 636L Noise Canceling Microphone...
D-104 Silver Eagle Mic Squeels
Hi, usually when they refer to putting a cap in, their talking about adding a .01mfd disc cap to the white audio lead wire up inside the bottom of the mic. Just follow the cord into the bottom of the mic, by taking the bottom off. find the white(audio) wire where it fastens to either the board or the terminal strip. Just unsolder the white wire and add the cap and resolder the other leg of the cap back where the white wire was removed. Some people even use a cap and resistor combo. Sometimes using a .001 cap from the audio line to ground then a 4700 ohm resistor will work in extreme cases.
http://www.qsl.net/wa2mzf/d1044.jpg
You can experiment with different combo to see what will work for you. Hope this helps you out, let us know,,, Mechanic
Feb 17, 2008 | Radio Communications
Radio Communications Logo
21 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
