Question about Lexmark X5470 All-In-One InkJet Printer
Paper doesn't feed - Lexmark X5470 All-In-One InkJet Printer
  • Official Brand Answer
  • 3,344 Answers
Hi, The problem could be an object inside the Auto document feeder that could be blocking the path of the paper or preventing the feed roller from feeding the paper. You can try the following, Turn off the printer, unplug it from the power cord, then remove the paper and then turn the printer upside down and shake it a little bit, sometimes this will help remove any objects inside the printer.
Posted on Feb 09, 2010
I tried this (turning the printer upside down and tapping on it), and, guess what? It worked! Thank you!
Posted on Jun 28, 2010
Canon ip4300 manual
hello,maybe the paper feed is jammed try to see if it has something that stops the paper to go in and if you are asking for the service manual for the ip4300 printer you can download it from the below link:
http://goo.gl/ZYxxU
Good luck
May 25, 2013 | Canon PIXMA iP4300 InkJet Photo Printer
Doesn't feed paper....shows "P" on screen.
Verify and clean the paper feed rollers and the paper fee drive mechanism.
Feb 15, 2013 | Canon NP 7130 Black and White Copier
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
Paper jam but no paper is jamed in printer
I have had this issue before. I hope this helps you. Try these steps:
1) Open the the top cover; then close it..read the message on the screen. If it doesn't resolve..
2) Remove paper and insert a fresh stack of paper. Making sure that edges are smooth..no creases or wrinkles.
3) Open paper feed area. If you have pipe cleaners available, clean each opening. You can use the fine hose attachment from a vacuum to do the same thing, if needed. Proceed to close the paper feed compartment..read the message on the screen. If it doesn't resolve..
3) Turn off the printer for a few minutes; then power it back on. Printers 'read or sense' the paper as the printing job occurs. Even the smallest shred of paper can cause the printer to identify it as a paper jam
I hope this helped you.
Apr 02, 2012 | OKI C3530N Color MFP Printer
Paper feed results in a clicking and no feed
This sounds as if the paper pick up assembly is not lifting the paper-up to meet the rollers. This is like a ratcheting sound when lifting. When the paper gets high enough it hits a sensor arm and the copier will indicate paper in the cassette. If it doesn't lift it will quit but will never indicate paper in cassette. Does the other paper cassette feed? I know I've had to replace the paper pick-up assembly before because of this problem and is very expensive. Good luck.
Sep 27, 2011 | Canon imageRUNNER 210S Copier
PAPER DOESN'T FEED THROUGH
check on the panel of the printer if the selected paper tray is the lower tray or the upper tray put paper on both tray mark the paper so you can see which tray is being feed,
Aug 04, 2011 | Canon LaserCLASS Fax 710 Printer
Hi, my calculator casio hr 8tec shows the message " e P" and it's doesn't print anything. It`s like it's stuck.... Thanks
It thinks it's out of paper.
Pull out and re-feed the paper.
If it's out of paper, put more in.
If that doesn't help, remove the paper, and take a look at the paper out sensor, and make sure it's functioning ok, and re-insert the paper.
Jun 27, 2011 | Office Equipment & Supplies
Paper won't feed from both tray and manual feed tray...motor starts, attempts to grab paper, but doesn't
THERE IS TWO REASONS. PICKUP SENSOR PROBLEM OR IN THE FIXING UNIT HEATER SECTION PROBLEM. SOMETIMES HEATING ELEMENT BURNED. CHECK THE BOTH ITEMS .
Jun 18, 2011 | HP Office Equipment & Supplies
I put paper in the printer, but it will not recognize that there is actually paper in the Machine.
The paper feed sensor is malfunctioning.. I would suggest cleaning if that doesn ot work..and it still does not feed you will need a new sensor.. Rate me by advice only Thanks
May 20, 2009 | HP Photosmart 7450 InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
125 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
