Question about InFocus LP 850 Multimedia Projector
Just replaced bulb in projector and now have error lights
Just replaced bulb in projector and now have flashing lamp and temp lights. What is wrong??
  • 4 Answers
Try unplugging it for a period of time. And while you have it unplugged get a can of air and clean it out. When they are used for long periods of time and over time dust builds up and cause issues with all projectors. The require to be cleaned. I do mine about every month or so. More or less depends on use. Mine gets used everyday.
Posted on Feb 05, 2010
Epson 1925W projector has a brand new bulb but the lamp light flashes red. Power light is solid green and Temp is off
Reset the Lamp Hours, see if that helps. Also clean the filter and reset filter hours too
Nov 08, 2016 | Epson 1925W Projector
Red power, blinking red temp
if the Lamp error and Temperature error lights are flashing red this means that there are two separate errors.
  • A flashing lamp light means the lamp failed to ignite. It could be a lamp driver problem or lamp failure. Replace the lamp to resolve the issue. If the issue is not resolved, then service the projector.
  • A flashing Temperature light signals a fan error. Turn the projector off and allow it to cool down. If the light is still flashing after the projector is turned back on, service the projector.
Goodluck..
Feb 25, 2008 | Hitachi CP-X250 Multimedia Projector
Both the LAMP/COVER and FAN/TEMP indicator lights come on, not blinking
with both lights solid. according to the manual all it says is (there is an electrical failure inside the unit, please take to an authorized servicer). if you are able to do this yourself you will need the schematics and a voltmeter to start testing your voltages. your lamp is fine so dont waste your money replacing that anymore. if you would like the service manual send me an email to fixya@markservicepro.com.
Oct 30, 2007 | Sony VPL CS1 Multimedia Projector
Temp and lamp lights flashing
can you let the projector work well
if the projector projects the image,
does the projector light?
if the projector work well ,but the indicator lights flashing,that means the projector is ok ,
you only need to reset the timer of lamp and to reset the timer of the filter,
menu-setting-advance-reset-the timer of the lamp
menu-setting-advance-reset-the timer of the filter
Apr 28, 2014 | 3M S15i 165Watt 2000Hrs HSCR Projector...
Lights flashing
Replace the lamp. The lights flashing will also indicate what is wrong. Watch how they flash. Go to the manufacturers website and they way they are flashing indicates what is wrong (ex. 3 quick flashes, long continuous flashes...etc.) When you change the lamp reset the lamp counter in the menu and clean or replace the dust filters as well.
Jan 11, 2014 | Sanyo PLC-XP200L Projector
Powerlite 82c Projector shut down due to over temperature sensor. Bottom Filter & complete interior were blown clean, bulb re-seated, bulb cover sensor checked but projector still refuses to completely...
HI Clay,Is the green lamp light on fully ie is not flashing.?
There is no reset for overheat, if the problem is like blocked vents when it is rectified the only reset is power on/off and the fatal red or flashing orange error condition should go away
I have seen a simualr model that had the lamp cover open not showing an error but stopping it from working, but I dont think it was the exact same model but worth checking the cover is on properly
How many hours has the lamp done, do you have two of these machines?
If you do please swap lamps between the two again because this sounds like a lamp issue although we should be getting the error code unless the counter has been reset without changing the bulb for new..are you 100% sure your not using 2 dodgy bulbs and thats our issue, because Im suspect on these lamps unless of cause you can swap one into another and see it light, if that is the case then its has to be lamp contacts or a board fault but i need to know more exactly the deal with "known good lamp" and exact lights
Ensure we are fitting the lamp correctly and the contacts for the lamp are clean and fitting tight.Please ensure we have checked the silly things like lens cover, signal is being sent and pc aint asleep etc
It is 2.30 am in Oz, I'm off to bed but let me know some more info if you can and I have a dig deeper at work tommorrow for you and see if i can come up with some solution because all i can see it being now in my sleepy state is bulb, bulb contacts, lamp cover, mis reading lights, silly stuff or a board fault....
Cheers below is your user manual and the error light table
Speak soon
Cheers
Soulvisitor
User manual link
Nov 01, 2011 | Epson PowerLite 82c Multimedia Projector
I've just replaced the lamp on my Panasonic PT-LM2E projector and it will switch on but no light comes out. The previous lamp blew in the projector after around 2000 hrs. The indicators are as...
I'd recommend checking the fans of the projector, and make sure that they're spinning. Since you've mentioned that the lamp blew inside the unit, bits and pieces of the lamp might have lodged itself within the fans. It might also have to do w/ the after-market replacement bulb, which I normally wouldn't recommend.
Aug 08, 2011 | Panasonic PT-AE900U Multimedia Projector
EPSON POWERLITE BULB REPLACEMENT PROBLEMS
ok
look at your users manual.
all epson models need to have lamp life reset befor the lamp will light.
I have had this same problem befor.
Daniel.
Jan 11, 2009 | Televison & Video
InFocus LP 850 Multimedia Projector Logo
164 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
