Question about Refrigerators
NEED WIREING DIAGRAM FOR THIS FOUR DOOR PIZZA PREP REFER
  • 454 Answers
In order to help you, please tell me the make and model number of your refrigerator.
Posted on Feb 21, 2010
  • 3,230 Answers
Well first of all you can please tell us the model number of your refrigerator..... so we can help you in details...........
Thanks
Posted on Feb 05, 2010
What can i get wiring diagram for TPP-67 pizza table?
TRUE TPP-67 SPECIFICATIONS Pdf Download. - ManualsLib
www.manualslib.com > ... > True Manuals > Kitchen Appliance > TPP-67
True TPP-67 Food Prep Tables: Specifications. TPP-67 ... TPP-67. Solid Door Refrigerator. TPP-67. True's pizza prep tables are ... Heavy duty PVC coated wire.
Aug 06, 2014 | True TPP-67 Commercial Refrigerator
My pizza prep-table freezes everything. I think it might be the thermostat. Could I be right
Hi
Sounds like you are correct, unless the door seals are not in good order, air leaking in can fool the thermostat.
If it has a top section that the pans for pizza ingredients sit in check that the airways are clear and that the tins and lids fit properly.
Regards
Gordon
Apr 27, 2011 | True Refrigerated Sandwich Prep Table 72"...
I need full construction plans on how to build a pizza oven out of brick
http://www.fornobravo.com/pompeii_oven/pompeii_oven.html
this site has alot of different options with plans available for you
good luck sounds like a cool project
Jan 23, 2011 | Master Bilt Pizza Prep Table 20 cu ft...
I have a Randell 5ft Pizza Prep table that's not working correctly and was wondering if someone might be able to help me? The top rail is cooling like it should but the bottom storage area is NOT cooling...
This unit uses Thermostat/Solenoid Valve Combination's to control the temperature
1. Rail 2. Bottom Storage
The way it works is the thermostat senses the need for cooling and energizes the solenoid valve. This allows refrigerant flow which cools the area it is controlling. Once the thermostat is satisfied the contacts open and the solenoid is de-energized closing the valve. If the solenoid is bad, the valve remains closed, no refrigerant flow, warm unit.
Test the solenoid coil (two wires) to see if voltage is present either with a volt meter, or remove the coil off the valve and place a screwdriver (insulated) through the coil hole and you should feel the pull like an electro-magnet (what a coil is).
Dec 05, 2010 | Randell Refrigeration 60'' Refrigerated 2...
Need part number and size of oven door
Page 3 of the manual for part number, no reference to size of the door itself though.
http://www.bakerspride.com/pdfs/PartList/Y-800%20Parts%20List%20U6052A%208-08.pdf
Oct 12, 2010 | Bakers Pride Y800 Pizza Deck Oven 44 in x...
True tpp67 doesnt run. no fan. just dead!
Several things to check. Obviously does it have power going into the machine? Sometimes breakers kick out if you have more than one appliance like this on the same circuit. Next open the door to see if the inside light comes on. Look for the on/off switch. Turn it on and set it to coldest position. Still nothing? There is a termnal block where all the wires come together near the compressor. You will have to check to see if there is power at that point. The inside fans shoud be running even if th compressor is not running. If your unit has a pressure switch instead of a thermostat. it will prevent the compressor from coming on. It has two little windows in it.If you take the cover off and put a jumper wire between the contacts of this pressure control switch and the compressor comes on, you are out of freon.
Sep 17, 2010 | True Pizza Prep - TPP-67
Why is there water pooling in my sandwich make up table? My reach in cooler, also?
During the cooling/freezing cycle condensation forms, this drips into a pan and then is evaporated by a heating element.
One of two things could be wrong.....
Your drip pan is clogged
or
your evaporator unit is bad
Hope this helps
Jun 22, 2010 | Randell Refrigeration 111'' Refrigerated 4...
How do i replace the bushing on the slider door
1. Remove sliding door trim panel , watershield, and access hole cover plates.
2. Unlatch pizza sliding door.
3. Remove latch actuator rod retainer from center door retainer hole.
4. Disconnect pizza rear door latch actuator rod from pizza remote control assembly by opening pizza clip.
5. Open pizza door sufficiently to gain access to pizza three bolts attaching pizza rear latch to pizza sliding door. Remove bolts.
6. Remove pizza sliding door rear latch with pizza remote control actuator rod attached to pizza latch, from pizza sliding door.-------------
First you need to get the right tools for the job and the right parts to fix the problem.There is a hinge pin in both the upper and lower hinges and four brass bushings and there is two different size bushings in each hinge and also two hinge pin retaining washers.as for the tools you need a spring compressor,jack,hammer,punch. First open the door all the way,put jack under door,I like to use a 2by4 board on top of the jack to help spread the wieght of the door out a little,next if the door has a wireing harness in the jamp loosen the rubber insulation form both the door and the body this gives a couble of inches of slack in the wireing.Next use the spring compressor to remove the spring,then use the punch and hammer to drive out the pins.it is very hard to get them to move an first but gets easyer as they start to move.I would recomend having a helper to hold the door upright as it will fall when the pin is removed from the hinge.Onece the pins are out move the door and jack away from the body to gain more axcess room the replace the bushings,two in the door side and two in the body side,then slide door and jack back and align hinge holes and install new pins. I allways grease the bushing and pins before installing.Drive the new pins all the way flush with the hinge and install the retainers.Reinstall the spring and reattach the wireing insulation. ------- Open the door so it is directly above the bench. Observe how all the fasteners, be they bolts or pins with bushings, are aligned. Generally, the bolts and pins point toward the center of the hinge from the top or bottom, The bolts and bushings are on the body-side bracket for the upper bracket and the door bracket for the lower one. This will help. Thanks please keep updated. please do rate the solution positively .thank you for using fixya
Apr 01, 2010 | Mercury Villager Cars & Trucks
Need wiring diagram for 80 vette power door locks
Here is a wiring diagram for the 1980 Corvette power door locks.
Link to: diagram
Hope this helps.
Mar 15, 2009 | 1980 Chevrolet Corvette
Kairak prep cooler
there are defrost heaters in this unit also the fan that is on the top plate could be resting in water. put the init into a defrost and after all the ice has melted clear the drain line thats by the fan on top. while your are looking check the wireing to the axiel fan there.
Oct 25, 2008 | Frigidaire FRS23KF7AB Side by Side...
Refrigerators Logo
16 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
