Question about Sanyo DP42746 42 in. Plasma Television
The tv just suddenly stopped projecting video and sound. Now can't get tv to come on. When I unplug it from the wall and plug it back in the green light at the bottom is on and when I hit the power button it makes a click sound like it's going to turn on but nothing happens no sound, no picture.
    President:
  • 1,768 Answers
1.You have a power supply issue on the main board of the TV.
Your TV will need service.
2.the inline protection fuse or the rectifier circuit has malfunctioned ( weak or bad) component and need replacement parts.
3. the clicking sound is the start up circuit but the voltage signal sent to the next circuit is not received therefore the system in not activated.
Posted on Feb 05, 2010
Soniq E23213a au 12v and 240v works for 20mins then screen goes green stripes and stops
Unplug your TV hold the power button down on the TV itself for one minutes release the power button plug it back in and turn it on yeah power build up and not yet overpowering of the power supplies you probably have it on power bar not plugged directly into the wall post TV to be plugged directly into the wall the wise Yup Yup mismatched power
Jan 07, 2018 | Car Audio & Video
I have a green flashing light and my tv won't turn on.
This is cause of a power interuption. Try unpluging the TV from the wall, and waiting several min. Then plug it back up, wait serveral min again and the green light should stop blinking.Then turn it on.
Jan 08, 2011 | Mitsubishi WS-65809 65" Rear Projection...
I have 60 inch mitsubishi hd DLP flat panel projection screen model is wb60735.i unplugged it from the wall then i plugged it back in the wall the next day.it came on but the screen was all black but still...
If you see absolutely nothing on the screen then you may have a problem with the Lamp unit. If you can see around the back of the TV look to see if there is a vented opening with a noise of a fan and a rather bright light. If you see there is no light then try a reset (hold power button for at least 10 seconds). Turn the TV back on and the green LED should flash for a bit. If you still have no picture or video of any type (completely black screen) and have sound only you probably have a bad lamp. These lamps are around $125 or so and can be bought on Amazon or other sites that sell these parts. It's fairly simple to replace but make sure that the tv is unplugged and securely re-install the access door. Hope this helped.
Feb 08, 2010 | Mitsubishi VS-60611 60" Rear Projection...
I WAS WATCHIN TV THE OTHER NIGHT AND ALL OF A SUDDEN THE TV TURNED ITSELF OFF AND THE LITTLE GREEN LIGHT IN FRONT STARTED FLASHING VERY FAST -SO I UNPLUGGED MY TV AND THEN PLUGGED IT BACK IN AND THE GREEN...
Some of these sets if you unplug them---The green power light will blink for about 70 seconds before it stops--this is normal as the receiver unit in this set is booting up. Wait for the light to stop blinking and then the set should turn on. Some of these sets develop a problem where the light never stops blinking--usually the receiver is now bad--very expensive to get fixed.
I do this here for free so if this helps you give me a vote here.
SD TECH (San Diego)
Aug 28, 2009 | Mitsubishi WS-48515 48" Rear Projection...
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Whistle noise? POP? Black out
sounds like the lamp has shattered. check the lamp
May 18, 2008 | Samsung HLN5065W 50" Rear Projection...
Blinking green timer light
Check C81A2, C81A3, C81B3 and C81B4 (1000 uFD, 16V, 105C) on the DM PCB.
Check C8F19, C8F21, C8F22 and C8F27 (1000 uFD, 16V, 105C) on the FMT PCB.
If any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C).
May 07, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Oct 12, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Sanyo DP42746 42 in. Plasma Television Logo
208 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
