Question about Maytag Washing Machines
Maytag washer lat9416aaq belt slips in spin cycle put new belt on and springs
    Problem Solver:
  • 15 Answers
The motor is supossed to walk up the belt to let it slip enough so the pump can run and drain out the water before the drum spins at full speed( that's why it's spring mounted).
Check the pump belt, it should be snug but not tight, you should have some give when you squeeze the belt together, but it should not touch together. Don't use any belt dressing on it, it needs to slip. Make sure the washer is unpluged before you do anything.
Posted on Feb 05, 2010
How can I tell if my washers belt or motor
first get 2 phone books, put 1 under front right foot and put one under front left foot. that will allow u to see the belt running between the 3 pulleys.turn unit to cycle, select low water fill and start cycle. when it is filled to level lie down on floor and u will b able to see belt spinning. please dont put your hand near moving belt do not want any accidents.why do u think your belt is slipping? is it because your clothes are coming out damp?please reply 4 more help if u need it.
Apr 15, 2010 | Maytag Performa PAV2200
Washer tub won't spin. Belt is slipping. Drum seems frozen.
you might have a relay thats shot or the brake solenoid is shot. check both of those, it may fix your problem.
Aug 24, 2009 | Maytag LAT3600A Top Load Washer
Grouling noise in the spin cycle
First, check the belt (located in the bottom of the unit) and if it shows signs of wear (black dust) and shiny sides on belt and black marks on the motor, transmission, and water pump pulleys - replace the belt. The motor is spring loaded and acts as the tensioner up to a point of too much wear on the belt.
You will need to tilt the washer about 45 degrees and prop it to keep it from going all the way over (just makes it more difficult to right it later). Pop the belt off by rotating it while pulling the belt off the edge of the transmission (larger) pulley. Again, the motor pulley is spring loaded and will flex appropriately. Reverse the process with installation of a new (exact replacement part number).
If this doesn't fix the problem, you may have to call the Maytag Repairman. They would have replaced the belt anyway and would probably charge $50 + for the belt and installation.
Dec 21, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag LAT9757AAE,top load washer won't spin.
Sounds like a sticky brake assy. This type of brake is very tricky and should be checked be a service technician
It's possible to do it yourself but not recommended because of the 200 lb. pressure spring. Hope the diagram will help.
Jan 13, 2008 | Washing Machines
Maytag performa washer
Hi Folks,
I'm guessing both of these problems are related to the belt slipping. There are several points to check.
  1. the belt tension. I'm not familiar with the exact details of your machines, but the usually have a an extra pulley with a spring attached to give the belt tension. Alternatively, the motor is mounted on a movable frame that is held by some springs. These springs give the belt tension. In either case check the freedom of movement of the tensioning arrangement and the springs are providing the necessary tension to the belt.
  2. Glazed belt/pulley - if the belt has been slipping it will polish the pulleys and this will reduce the friction necessary to drive the machine. To fix this the belt should be replaced and the pulley surfaces roughed up with some wet/dry emery paper (not too rough or it will wear your new belt out).
  3. Belt is too old - the rubber becomes hard and brittle and ends up with the same effect as Glazed belt/pulley above. The fix is as per 2 above.
Good luck
Bob Thompson
Dec 12, 2007 | Amana NAV5800A Top Load Washer
MAYTAG WASHER SAV205DAWW
i can step you through it in a live chat session
Sep 27, 2007 | Washing Machines
How to replace Maytag Washer belt
I have a model sav2655aww maytag washer. And it needs a new belt but I dont know how to replace it! Can the pump be removed with out removeing the motor ? Also the tub keeps going off center whats with that ?
Sep 03, 2007 | Maytag SAV5710 Top Load Washer
Washing Machines Logo
274 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
