Question about Refrigerators
Refrigerator and freezer not staying cold enough, but running
Last 3 months unit does not get cold enough...refrigerator about 48 degrees and freezer 30 degrees. On coldest setting. have cleaned the coils in back..good seal..compessor runs...fan inside runs. 7 year old unit..very good condition...would a bad defrost heater cause this...or that little sensor. Frigidaire model FRT21G3A
    President:
  • 1,218 Answers
Good day,
First, on some versions of your machine, there is a fan on the bottom rear, make sure if it has one, that it is running.
If it were a defrost component, as you suggested, then you would see a build up of frost and ice on the rear panel in the freezer compartment.
If so, you would need to defrost it. There are 3 components to a defrost system. The 2 you described, behind that rear panel, and a timer in the fresh food compartment, in the upper housing.
Below is a tutorial on defrost systems. You need a ohm meter to test the components.
If none of the above apply, then it is in the sealed system (compressor, leaks in the tubing or restriction in the lines) and would require a trained tech to sort it out.
http://www.appliance411.com/faq/howdefrostworks.shtml
Posted on Feb 05, 2010
Zis480mnc ge monogram built in refer temp varies from 34 to 48 several times a day.
Try replacing that evap thermistor. The diagnostics on thermistors can be wrong. If it is rounded on the end, replace it. There is a damper between the freezer and refrigerator. There may be a refrigerator fan motor in the damper assembly, It could be bad. It could be a bad control board. When you run diagnostics there is one function that checks all the fans.
Sep 25, 2014 | Refrigerators
I have a GE GSS25QGTABB side by side. Despite the digital thermometer being set at 0 degrees (freezer) & 37 (fridge), my freezer does not go below 11 degrees, and the fridge at 48 degrees. Compressor...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 26, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
My termador side by side built in wont get cold enough. Freezer at 35 degrees and fridge at 47 degrees. Compressor is on, fan is on and air flows through freezer so i assume fan is on there too. Yesterday...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Sep 09, 2010 | Thermador 48 in Built In Side by Side...
Frigidaire top-mount refig. freezer won't get cold ,temp.stays around 26 degrees, refrig. don't keep milk cold enough
check that the evaporator fan motor ,located in freezer is working.it circulates the cold air.also check that the coils behind freezer back panel are not iced up,this would indicate a lack of defroting due to,timer,heating element,or bi-metal.lastly when the refrig is running those coils should get frost over them all,if not you may be low on refigerant
Jan 20, 2010 | Frigidaire FRT17G5CSB Top Freezer...
New freezer not cooling - temp @ 25 degrees and food is defrosted
It is probably the control board and since it's new it's still under warranty so a certified Frigidaire repair man will fix it without charge. There should be a telephone number with the paperwork you received when you bought it.
Aug 29, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
48" ge monogram refrigerator not staying cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
sfjfg
Aug 16, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
Refrigerators Logo
124 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
