Question about Dryers
I cant find the power plug - Dryers
    Problem Solver:
  • 5 Answers
The question is too vague to be specific, so I will embellish on an assumption.
When you say "Power Plug", I am assuming you are referring to the power cord which is located on the back side of the dryer. If the dryer is new and there is not a power cord, most likely the dryer manufacturer shipped it w/o a power cord. This is usually installed by a licensed electrician.
Just a note, if you are a DIY and prefer to do this at your own risk, you can open the back of the dryer panel and install a new power cord yourself. When you go to the hardware store be sure to kow what type of 220v receptacle you have. You can draw a diagram of how the receptacle face plate looks and bring the drawing with you.
If you do this yourself, please make sure that all of the wiring is attached correctly and securely. A loose screw can cause your cord, breaker and heating coil to overheat!
Posted on Feb 05, 2010
Says cant make connection
I recommend powering down your streaming device, computer etc.
Power off the router by unplugging the device, but leaving the cable attached. Leave this powered down for 5 minutes. Plug device back on and allow the all lights to power on. Than attempt to connect to Netflix again.
Dec 27, 2014 | Netflix
I cant find the power cord or where to plug it in at
Behind white label , remove label , insert the power adaptor to proper hole .
Dec 08, 2014 | Duracell Powerpack 300 - Portable Power...
Why my htc explorer wont stop vibrating and cant power on.
your phone have hardware problem so go to the service station to resolve
May 16, 2017 | HTC Explorer A310e Black Android 2.3...
Why my htc explorer wont stop vibrating and cant power on?
dude its a serious problem...let it checked by any harware expert..we can only solve your s/w related problem not h/w...So go to a reparing shop.
May 16, 2014 | HTC Explorer A310e Android 2.3 Unlocked...
I want to use the external usb port cant figure out how
If you are plugging into a laptop USB port you may need an external power supply for the external port. Laptop USB ports have a lower power rating than desktops, to conserve battery power. Generally all you should need to do is plug in the USB device and the operating system should find the required drivers.
Apr 18, 2013 | ASUS Eee Computers & Internet
Cant get the power to turn on,worked fine last night, it got unplugged, this morning plugged in, won't turn on and the power button just flashse
Flashing is either an error code or the set trying to boot up--some of the Mitsubishi sets if power removed will blink for a minute and then stop--then the set can be turned on.
a model number?
Apr 28, 2012 | Mitsubishi Televison & Video
Screen on front lights up but cant see numbers are functions
Try to re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
If that doesn't help, try to plug the printer to a different known working power outlet in the wall to determine if it's a faulty power outlet issue.
If the problem continues, please contact Lexmark Technical Support Center for further assistance.
Nov 28, 2011 | Lexmark Prospect Pro205 Wireless...
Cant get a spark from spark plug
if you have checked or replaced your ignition timing and have power there
trace it back check it from the coil
if no power could be a faulty coil
check for power at the connection to your spark plug lead if its getting power then check it at the spark plug if no power faulty spark plug lead
hope this helps you
Nov 25, 2011 | MBK Skyliner 125 Motorcycles
Cant get a sticker due to the plug under dash
NO POWER TO PCM COULD BE THE FUSE OR THE PCM ITSEL.F
Mar 15, 2010 | 1998 Dodge Caravan
Describe your Black &
I have a black and decker 100 watt power inverter. When the led turns red you are ethier overloading it or it overheated. to fix it unplug it and let it sit for 5 minutes. Plug it in. Plug in an item rated for 100 watts or less. Or try to charge somthing on the usb port.
Aug 23, 2009 | Black & Decker 100 Watt Plug-In Power To...
Dryers Logo
130 people viewed this question
Top Dryers Experts
