UNDI initialize failed no media detected what should i do
Hi if your still having this problem then I have GREAT NEWS!! I have found a solution. Go into your bios screen at startup and enable your hard drive. I just found this solutions. In the boot sequence screen in the bios, apparently my internal hdd (hard drive) had been disable as a boot option. In order for me to enable it I had to press the space bar and made it second in the boot sequence next to the CD/DVD drive. Hope this helps!!
Posted on Jan 07, 2011
How can I fix the error I am receiving at initial start up? See details section for Error and description of what has already been done to try and fix.
It sounds like the hard drive in your machine has failed. It uses a standard 2.5" SATA hard drive (Most likely 9.5mm thickness maximum, most are that.) Hopefully you have made a recovery CD set from the recovery partition on the drive.
Feb 24, 2015 | Dell 15.6" Inspiron 15R Laptop Computer...
I have a fiujitsu hard drive in my acer aspire 5315 my keyboard has no keys just some rubber tips and when i turn on its says broadcom UNDI PXE-2.1 v10. 0. 9 copyright yada yada and then it says: PXE-E61:...
The keyboard needs replacing. Replacement keyboard for your laptop maybe available from this WEB site.
PXE-E61 ERROR
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Dec 18, 2012 | Computers & Internet
Keeps saying boot failure along with Ethernet controller v1.06 and media failure, check cable
What you are describing is a hard drive issue, remove hardware and reseat it back in place sometimes this will restart the hard drive. If this fails have it tested.
Jun 04, 2012 | MSI Computers & Internet
My computer comes on n gives me an error message saying UNDI Intialized failed, no media detected.
Hi, UNDI is a shorthand for Universal Network Driver Interface.
CAUSE OF ERROR: It sounds as if you are having some trouble with your NIC {Network Interface Card}.This error message can occur if no network adapter is detected in your computer or if no connection to the network is detected when the network adapter is initialized.
RESOLUTION: To resolve this issue, perform network troubleshooting on the hardware.Check the network adapter cable, cable type, hub, router and so on.Also check the computer's BIOS settings to make sure that the network adapter is disabled.Try logging in safe mode and then disable your NIC in control panel.Reboot and see if that solves the problem.If it does you can start looking around for an updated driver or perhaps a new card.Enter the safe mode by pressing the F8 keywhile booting up. Also try doing a system restoreto a earlier point.This also fix your problem.
Thanks for using fixya....Best Wishes...Wish you a happy New year..
Dec 31, 2010 | Dell OptiPlex GX150 PC Desktop
Pxe e61 check cable message
"Intel UNDI, PXE-2.1 (build 082)
Copyright (C) 1997-2000 Intel Corporation
For Realtek RTL8101E/8102E PCI-E Ethernet Controller v.105 (071227)
PXE-E61: Media test failure, check cable
PXE-M0F: Exiting PXE ROM
No bootable device -- insert boot disk and press any key"
sounds like a driver issue try to go to toshiba's website and download the latest drivers for the NIC card.
Nov 02, 2010 | Toshiba Qosmio G15 Notebook
Broadcom UNDI PXE-2.1 v11.0.11 Copyright (C)
change your boot priority. press power button then keep on tapping F1 key until your reached to setup utility. go to boot menu and set your boot priority 1 to your HDD. if compute wasnt able to detect your HDD . then there is a problem wth your HDD, you need to call you manufacturer for HDD replacement if unit is still under warranty
Mar 31, 2010 | Lenovo 3000 G530 Notebook
Undi initialize failed no media detected please help!
ok... what's the systems model# and are you trying to burn A cd / DVD? What is the operating system?
ehat is the software your trying to use?
Feb 17, 2010 | Computers & Internet
Computers & Internet Logo
310 people viewed this question
David Payne
David Payne
