Question about Xerox CopyCentre C20 Black and White Copier
Open heat Hi.... is there a way to keep the machine working after this error appears, I mean at least ´til the replacement arrives? Thanks
    Scholar:
  • 53 Answers
Short answer is....no
although you haven't given us much information to go on
Posted on Feb 21, 2008
My aeg lavamat 41070 washing machine doesn`t work at high temperature ( more then 50 degrees) . At low temps it is working OK/
In the case of insufficient heating appears error code E60 what means replace the NTC sensor. Exclude heater, PCB or relay malfunction because you indicate that the machine is heated to 50 degrees Celsius.
Dado
Feb 28, 2015 | AEG Washing Machines
I was drying and the dryer shut off and gave an error message of E64
Hi
Error code E64 means Heater Open Circuit. This error appears when the Heating element or wiring to the heating element is defective. To clear the error code (s): Press and hold the far left key under the display and “cancel” buttons simultaneously for 3 seconds. If the error appears again then you’ll need to check heater coils and connections for open circuits. Use a multimeter to check the heater element, use Rx100 setting on the multimeter. It should display 30-33 K ohms as the resistance. If it is less than this or exceeds this limit then the element has gone bad and you would need to replace the element. Hope this helps...
Daniel
Sep 13, 2010 | Electrolux EIED55H Dryer
Error message e64
Hi
Sep 07, 2010 | Electrolux EIED55H Dryer
I get a error code 19 and my laptop DVD player stopped working
Get the DVD driver head cleaned and then try.
Mar 16, 2010 | Computers & Internet
Not working right
Hi
Thanks for using FixYa. E14 error code means water heating error has occurred and failed heating element.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 28, 2009 | Hotpoint Aquarius WD63 Front Load...
Open heat error
From looking at the manual it looks as if you have a faulty thermistor. When warming up, it has to heat up to at least 60 degrees. If it stays lower then 60 degrees celsius for over 35 seconds and doesn't reach 60 within that time frame then that would cause the open heat error that is happening on your machine.
Feb 09, 2009 | Ricoh AficioSP 5100N Laser Printer
Epic 9600 model door will not open machine will not engage code comes on screen dl f
hi there,
this code means you have a door latch error. this is why the door does not open or does not work. the machine automatically shuts down when this error happens to prevent the machine from running endlessly. call a technician to replace the door lock.
thanks
Oct 02, 2008 | Maytag Washing Machines
Brother dcp117c
Hi Jay,
let me guess, your dcp is about 2,5 years old, right? You have used generic ink carts and very often used the manual cleaning, right?
You need a new waist ink absorber,, which can be purchased at any service partner near your home (see brother homepage of your country). When done so you have to open the dcp and to replace the box. At last you have to reset the eeprom:
press menu then start bk-copy then fourtimes arrow-up (quickly after another). machine switches to maintnenace mode. press by help of the arrow-up and after each digit the set key: 8  0 (zero).
Press start bk copy til PURGE64xx appears. Press 2 7 8 3 (Arrow up and set key) and then STOP.
To leave maintnenace press 9 then 9. After machine comes up in a normal stae the error message is disappeared.
Please DO replace the box first before doing the reset. Otherwise you will seriously damage the dcp!
Mar 12, 2008 | Office Equipment & Supplies
Kyocera Mita KM 1500
Still sounds like there is a problem with the fuser unit. The technician that replaced the parts should be able to troubleshoot the problem.
C6 = Fuser error. The unit is not heating up due to a bad Fuser lamp, fuse, or thermostat, or bad thermistor.
The circuit is open, and the machine won't work til the problem is repaired. Once open circuit is repaired/closed, the machine should reset on it's own after you power the machine down and back up.
Does the machine flash the C6 right away as soon as you turn it on OR, does the C6 show up after about 3-5 minutes?
If you get the C6 right away, then the circuit is open, and that needs to be fixed.
If you get a c6 after 3-5 minutes, then there is a good chance the lamp is bad.
Hope this helps.
Good luck
Feb 08, 2008 | Video Cameras
Xerox CopyCentre C20 Black and White Copier Logo
96 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
