Question about Maytag Atlantis MAV6000 Top Load Washer
Switch at the back of lid
What can I do to fix the switch at back of the lid? you have to push lid to the back when it is close for it to work.
    Problem Solver:
  • 15 Answers
There are two screws that hold the switch in place.
You can adjust it to where it should be then tighten the screws.
To get to it (unplug it first), take off the front cover, 2 phillips head screws near the bottom, then tip it up and off ,remove the 2 screws that hold down the front of the top cover on the inside all the way in the front corners, and lift the front up. You'll see the switch.
Posted on Feb 05, 2010
I have a Maytag LA212 AND a Maytag A8120 washers that will both fill but then do nothing else. The A8120 I got first and it just started this behavior last night then then today someone put out the LA212...
I used to have 2 laundromats full of toploader Maytags... these will fill and do exactly what is happening to you if the LID SWITCH is not activating. Open and close the lid and listen for a clicking sound. Look a the rear edge of the lid... there is an indentation that is supposed to activate a small white switch in the that's attached to the top of the machine. Many times the lid will simply get bent.. someone sitting on the lid, standing on the lid... will be enough to throw it out of whack. Close the lid and push on the center of the closed lid... will the machine work? Or carefully push a flatblade screwdriver tip between the lid and the switch to see if you can get it to activate. Solution: Open the lid and apply firm pressure on the lid towards the back of the machine, while with the other hand push DOWN on the back edge of the lid...right where the indentation for the switch is... if you give it a slight tweak...you'll probably be back in business. One other thing, if the lid switch isn't clicking...replace it.
Sep 12, 2010 | Maytag HAV2557 Top Load Washer
Washer wont run unless i forcefully push the lid when closed
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
It is a simple and relatively inexpensive fix.
Jul 09, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Trunk does not completely close
The trunk latch contains a switch which closes when the trunk lid is pushed closed by hand, then this switch sends power to the trunk lid pull down motor which then finishes closing the trunk lid. Often the switch or motor will go bad and the whole thing will stop working. It takes a little testing to figure out which part is at fault but they are usually quite easy to fix.
Jun 10, 2010 | 1996 Lincoln Town Car
Machine stops when it gets to spin mode
This sounds like the lid switch is bad, or needs adjusted. In the center of the lid, on the rear of the lid, there is a little "nubby" that pushes on the switch. Make sure it clicks when the lid is closed. If not, try pushing back on the lid a little to get it to click. If it does, the switch needs adjusted. If not, it may need replaced. If this helps, please rate my answer. Thank you. If it doesn't help, we will take it further and try and get you fixed up.
Jan 06, 2010 | Maytag Washing Machines
Washer filled up and wont drain or do anything!!!
Does it click when closing the lid ? Sometimes , the lid switch arm , will work inserting something into it , but not with the lid closed . Try checking it using the lid itself . Occasionally , the arm wears to where it has to be pushed farther down to work so the actuator on the lid cannot push it far enough down . Have to replace the lid switch for it to work properly or bypass the lid switch from under the console .
Aug 18, 2009 | Washing Machines
Washing machine not spinning
Aug 18, 2009 | Hotpoint VBSR3100GWW Top Load Washer
Frigidare washer will not go into spin mode
Aug 16, 2009 | Washing Machines
Won't spin
Need instructions and Switch for twyford close coupled cistern
i presume with lid of u can flush toilet by pusshing switch with finger if so buttons must be spot on when replacing lid can be adjusted inside systern any probs get back
May 07, 2009 | Toto CST414M-51 Aquia Dual Flush Close...
For weeks now I've had to slam the lid on my washer to get it to work. Now nothing! The same thing happened to my dryer...close the lid and nothing. It wasn't even a year old and someone had to come out...
ck lid screws especially on newer models on these the lid switch is located left rear corner just behind lid hinge if switch is on right side close lid slowly and listen for click if none heard try pressing down on lid at switch location if washer starts replace switch if switch lever broke change switch..on other type switch lower lid slowly and listen for click if none heard and hinge screws ok raise lid and push lid hinge toward back slightly and try again still no click raise console switch is on left and just snaps in place
Sep 04, 2008 | Whirlpool Washing Machines
Maytag Atlantis MAV6000 Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
